Question about Dell E773C 17" CRT Monitor
BLANK SCREEN on booting the screen goes dark after the splash screenbut will come on iff booted into safe mode. I tried the moniter in a different pc with the same result.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Screen goes dark I tried the moniter in a different pc with the same result. i think there might be problem in monitor adjustment. 2 if it is ok then the problem in video section. 3 also check for loose connector 4 crt base might be loose.
Posted on Sep 26, 2007
Asus 1015cx will not boot at all
I would open it up, remove the hard drive and memory. Then see if you can get into the BIOS. Then put back the memory and try again.. Do you hear any beeps at startup?
Mar 08, 2014 | ASUS Eee PC 1015Cx
Boots up but then goes blank when it is suppose to go to login screen
Can you boot into safe mode? Press F5 or F8 key before Windows Splash Screen.
Do you have an external monitor you can connect to the laptop?
These steps will help to determine what is causing the problem.
Apr 01, 2011 | Computers & Internet
Screen goes blank after afew second on ac inly
Try booting to the Safe Mode (F8 at boot) see if you get any further. Also, does the system complete boot (DO you hear windows sounds?) or is the system just hanging after the Splash screen (You can also try an external monitor and press Fn+F8 to enable the external display) If you can get video externally, then is it likely a LCD or video card failure. If you can't boot to the safe mode and you do not hear the Windows Welcome sound that normally plays at the desktop, then the system is not booting and you have either a hard drive failure and/or an operating system failure.
See if you can boot to the BIOS (F2 at boot), then reload the default settings and reboot.
If you suspect the OS is a problem, boot to the XP CD, then run CHKDSK /R and see if that helps
You can also run system Diagnostics by pressing Fn+the Power button
Dec 21, 2009 | Dell Latitude D800 Notebook
What can i do for my laptop, when i turn it on the XP splash screen displays, and then it just goes blank, no cursor, but it is still running
try booting into safe mode. hit the f8 key during bootup to get that option and see if safe mode works fine. If it does, then the problem is a bad or corrupt video driver. The display itself could be going bad, also, but that seems less likely if you can see the splash screen every time. If you cant boot into safe mode, you may have corrupt OS and need to do a repair install.
Oct 05, 2009 | Toshiba Satellite A105 Notebook
Screen goes black. the power light is on, but the picture goes out. if i turn the power off, then on again it comes back for about 5 seconds, then goes black again.
Check to see if this problem follows in safe mode. Reboot and when the Dell splash screen comes up tap F8 until you see the multiboot options. Scroll to "safe Mode with Networking" let the machine boot up and see if you have a screen. If you do, right click on the desktop and set the resolution to 800 X600 and reboot normally. Usually when a screen goes blank in normal mode but shows up in safe mode means you have an incompatible resolution for the monitor or graphics adapter. This may be a driver issue or hardware. If the screen boots up in normal mode at the lower resolution, then try and go to properties again and bump the resolution up a bit, if it blanks again, try to go online and update the driver for the graphics chip.
Sep 08, 2009 | Dell Dimension E510 PC Desktop
Won't boot - brief blue screen
Press F8 while booting but before it goes into SAFE mode select "Temporarily disable restart." Now you should be able to read the Blue Screen. If this doesn't work it's likely you have the GenericFX virus and you'll need to repair the operating system.
May 30, 2009 | Computers & Internet
No screen after Boot
Try booting to the safe mode (f8) and see if there is any difference. If there is no difference, the video adapter is most likely failing.
If you can boot into the safe mode, then reboot and try the vga mode on the same menu, if you can boot to the desktop, then try to increase the resolution. if it fails, try a new video driver.
Jun 01, 2008 | HP Compaq Presario V2000 Notebook
My Toshiba laotp's screen goes half blank help!!
Well try to boot into the safe mode.hit F8 on the startup and see if you get the same acreen.If its working fine in safe mode than you need to reinstall the video driver and that should resolve the issue.If it is still not working try connecting a external moniter.If you get the same display on the external moniter than its an issue with the video card and if you get a normal display on that than its an issue with the Laptop screen and you would ahve to get either of thses replaced by contacting the manufacturer.
Hope this helps!
Sep 17, 2007 | Toshiba (225EXTR5)
Dell E773C 17" CRT Monitor Logo
127 people viewed this question
Clive
Clive
Alun Cox
