When my machine is filling up with water the water starts coming out of the front of the detergent case down the front of the machine
  • 3,961 Answers
It is highly likely that your water inlet solenoid valve has failed. This is an electrically operated valve that shuts off the water fill when the level is correct. There is one each on hot and cold, and if it fails open, the machine will overflow.
The other possibility is that the water level sensor is blocked or faulty. This is a tube from the bottom of the bowl up to a diaphragm sensor which sends a signal to the inlet valves.
Posted on Oct 16, 2013
  • 1294 Answers
SOURCE: Hoover Nextra washing machine - water backing up
If this is a front loader see that u use only washing powder for FRONT LOADING MACHINES. Also possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine.
Posted on Oct 08, 2007
SOURCE: he2 leaking from detergent dispensor
We had the same problem, It was a pair of sock stuck behind the seal in the drum blocking the water inlet to the drum. Like others we managed to get our fingers between the metal of the drum and the rubber seal near the detergent dispensor to remove the sock.
Posted on Mar 01, 2008
  • 43 Answers
SOURCE: Leaking Water
try pouring boiling water down soap draw possible blockage due to cheap wash powder take off lid and massage down pipe then put on wash with no clothing
Posted on Nov 10, 2008
barkencoa
  • 3463 Answers
SOURCE: Water leaking through detergent tray of my Hotpoint WF860
It sounds like the washer is not draining properly.
Remove lower rear cover of washer, locate and remove the large black hose fastened to bottom of tub.
remove plastic filter inside hose, and clean same.
Refit filter and hose, making sure it is on properly.
Be careful when you remove the hose, as there will be water in there.
As an extra precaution, remove soap draw,and thoroughly clean all parts, particularly,the conditioner parts
Please rate my fixya solution.
Thanks.
Posted on Feb 02, 2009
  • 57 Answers
SOURCE: Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Posted on Oct 10, 2009
Water leaking from detergent drawer
The first thing to do is take note of what the washer is doing when water leaks out in order to help pinpoint the cause. Does it only leak when filling? Is it leaking during wash or rinses? Or is it leaking only when it goes into spin?
Only leaks when filling
  • Water pressure that's too strong. Some dispensers can't cope with high water pressure. Make sure the washer is level as one leaning forward can leak if combined with high water pressure. Try turning the tap on the washer down. Only suspect this if you know the water pressure is high and it looks like it's gushing in quite fast on fill
  • If there is an optional detergent flap fitted in the drawer for holding liquid detergent make sure it is removed or drawn into the up position if using powder otherwise it prevents detergent running down into the drum
  • A build up of grease and slime in the nozzles at the top of the dispenser where the water flows in causing water to spray at the front and run out when filling. Check this article -black jelly-like substance in soap dispenser and on soap drawer (In extreme cases I've had to replace the dispenser.)
  • A build up of undissolved detergent in the base of the soap dispenser under the drawer (depending on the design). Remove the soap drawer and check the bottom of the soap dispenser for a build up of detergent that could allow water to run over the lip of the dispenser
  • Blocked dispenser hose: Some washing machines can flood water out of the soap dispenser if the hose leading out of the dispenser into the tub gets blocked. Blockages can be something put into the drawer by a child or a chunk of undissolved detergent tablet. Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and it wasn't wide enough. Undissolved powder from a tablet or lumps of detergent through poor water pressure can block this hose solid causing water to back up. Unplug machine, remove lid and feel this hose carefully for obstructions.
  • Overfilling: If the washer starts to fill and never stops it will flood out of the drawer eventually - Washing machine overfills
Leaks out of drawer during the wash or rinse cycle
  • Too many suds? If you can see the door glass is white with foam up to the top it could be foaming out of the dispenser. Too much foam in the washing machine
  • Overfilling: If the washer starts washing but the water doesn't stop coming in it will eventually fill the drum so much it will start to pour out of the soap drawer and other places. If this is the fault you should be able to see the drum is so full of water it's making a different sound, maybe labouring under the load, and the door glass full to the top with water. You should also hear that water is still running into the machine and be able to detect it by opening the drawer. However, in most cases an over filling washing machine should trigger an error code long before it gets to this stage but if you suspect overfilling check this page - Washing machine overfills
  • Surging: There are (often intermittent) faults that can cause the motor to spin out of control on wash or rinses. Instead of turning slowly the fault causes the motor to surge into spin instead which throws the laundry and all the water about violently. Water can then be forced out of the soap dispenser drawer. This fault should be relatively rare these days but if you observe this behaviour call an engineer to diagnose the cause.
Leaks from drawer only when spinning
  • If it only comes out on spin it can be caused by a partial blockage preventing the water being pumped out fast enough resulting in excess water being thrown around on spin and backing up into the dispenser. This fault is similar to the surging fault described in the last list but different in that the problem only occurs when it's on a proper spin cycle and much of the water has been pumped away. Troubleshooting this fault is all about finding out why it isn't emptying the water properly which is usually due to a partial blockage. Follow the same troubleshooting as described for a washer not pumping any water out at all - Washing machine won't empty water
  • If water is being forced out of the drawer when the washer is spinning but it is on wash or rinse and shouldn't be spinning follow the procedure for surging in the previous section above
Dec 23, 2016 | Washing Machines
Water is coming outof the detergent/conditioner
is the machine still filling may be as simple as to much water pressure turn the tap down a little
Mar 29, 2010 | Washing Machines
I have the kenmore HE2 front loader. when you turn it on now water comes pouring out of the detergent filling compartment and flooded the house... any ideas
there is a water inlet on the right side of the detergent filling cup to flush out the dry detergent. take out the fill and it is midway back on the right(little rubber hose) once you locate that take the top panel off and follow the hose, should lead to a silinoid. this is most likely sticking open, or the line is broken and dumping water into the washer cavity instead of in the detergent cup. hope that gets you started in the right direction.
Jan 17, 2010 | Kenmore 43142 Front Load Washer
Whilpool front end loader leaks water after done filling
theres a hole in gasket (bellows),,,,now also check your detergent draw if water pressure is to high it will splash over and come down inside of cabnit...
Dec 24, 2008 | Whirlpool AWM5125/1 Front Load Washer
Leaking Water
Nov 10, 2008 | Samsung WF337AA Front Load Washer
Water leaking out slightly from detergent dispenser draw and is starting to rust down left hand front side of machine,checked all water supply and drain hoses but leak appears to be coming from high up...
Your water pressure may be a liitle too high for the machine to handle. Try turning the water valves for the hot and cold water down a bit to reduce the pressure and try it again.
Jun 21, 2008 | Whirlpool Washing Machines
Water leaking
There is a small plastic "gate" that is left down for liquid detergent and moved back and up for powder detergent. If this piece is left down and powder detergent is used, the water leaks and the detergent won't go into the washer properly.
Oct 13, 2007 | Whirlpool Duet GHW9150P Front Load Washer
He2 leaking from detergent dispensor
Plug off the wall, etc. Remove the rear cover. There is a thin tube coming from the control panel area to the base where the water exits, this should not be blocked, remove from top and blow to check, refit. Next clean out your outlet filter, it could be clogged, refit. This tube controls the water level. Another thing that could be the problem: Try to take the top of the machine off; there are three tubes coming into the dispenser box, these may hv come loose or something. Connect well.
Sep 12, 2007 | Kenmore 46462 Front Load Washer
LG Front Loading Washer overflows at detergent dispenser
you mean where you put the regular HE soap in? That slot is normal to overflow. The water carries the soap down (Lift the little doohickie up, it's removable for powder deterg.), and it carries it all the way to the tub...Unless i don't get it...but I'm reading the phrase "Its like the water will not go down to the tub.", and it makes me think the whole tray is overfilling with water..if this is the case, I can't help you, but filling over of the Main HE Soap tray is normal. (Just a little, if the whole thing starts filling uncontrollably, hit the power button.)
Feb 10, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
