Question about IBM xSeries 226 Server
I have raid-5 in my imb eServer. Server can't load, because ServeRAID-7k show me 4 disk "Defunct". In mini-configuration menu i choose "Restore to factoruy settings" and disks drops to "RDY". But my RAID not rebuild. Pls help, what should i do?
  • Andy
    Andy Oct 16, 2013
    IBM*
    Scholar:
  • 143 Answers
You are not supposed to reset Raid Controller as it may delete present raid configuration. What you can do is
1: Insert Raid Support CD and boot server using it
2: Once it loads, you can view raid arrays which is offline
3: Right click Raid Array and make it online
Note: Raid Array won't come up if more that 1 hdd got faulty.
4: Once Array is online, make sure array status is optimal.
Note: If any hdd is faulty, Raid array is in degraded stage and you need to replace faulty hdd ASAP.
5: Now Reboot server normally.
OS will load
Thanks
Posted on Oct 21, 2013
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 65 Answers
When you restored to factory setting you have reset the RAID configuration & probably lost all the data
Posted on Oct 16, 2013
  • 17 Answers
SOURCE: xseries 346 wont boot
You don't say whether or not your os is on the RAID 5 partition. Assuming that it is (for performance reasons, this is not recommended) then you should check to see if you have the option of configuring a separate raid configuration on your raid card (e.g. do you have a card with more then one RAID channel?) If this is so, I would create a separate RAID 1 array and install the OS just on that. Then you can mount the RAID 5 array with your data intact. Once you're up and running, you can remove the old OS partition, as it's no longer needed.
Posted on Nov 06, 2008
  • 17 Answers
SOURCE: Upgrade IBM Xseries 346 Server
You can add drives to the array through the scsi management software, then you can extend any dynamic partitions that don't have the OS on them. I don't think you can extend the array if it contains the OS. You may need to use the disk management utility in windows to make the partitions 'dynamic disks' before you can extend the data partitions
  • 13 Answers
SOURCE: server doesnt boot
First create a floppy disk with your RAID driver for W2K3 Server. Next boot the server with the W2K3 Server CD, and hit F6 when prompted, and S to add the specific driver for your RAID and using the floppy to get the driver installed.
Next boot to the recovery console of W2K3 Server. If it finds your hard disk, it will even ask for your Administrator's Password to continue. If this works, then you are probably home free.
Get to the command line of the W2K3 Server Repair console and perform some directory searches to see if the data is there and intact. You can also perform a CHKDSK from that console.
Once you have made sure your data is there and intact, type these two commands: FIXMBR and FIXBOOT
This should solve the problem and when you EXIT out of the console, it should reboot. Remove the CD and it "should" re-boot from the hard disk.
If you still have problems, let me know with how far you got with the steps above. I have another solution but need to know your RAID controller's model (ServeRAID 5i, 6i, etc).
-Chip
Posted on Nov 26, 2008
  • 9 Answers
SOURCE: defunct of HDD in netfinity 7100 RAID
Download IBM ServeRaid , this software will allow you to see whats going on and correct issues
Posted on Jun 09, 2009
  • 4234 Answers
SOURCE: Troubleshoot ServeRaid problem on IBM x335 Box
The likelyhood that 2 drives fail at the same time is remote. I would first look to teh controller as the problem. Also, check the power supply. The only common things are the 5V and12V supply.
Dan
Posted on May 12, 2010
I have IBM eServer with ServeRaid-7K on board controller and have 3 SCSI 73GB hard drives configured in RAID-5 array. Hard Drives are running critically low on space and I bought 3 300GB scsi Ultra320 hard...
First, buy an external storage device, at least 80GB (although it's currently difficult to find any _smaller_ size!) and make a file-by-file, folder-by-folder, backup of your 73GB of "data".
Second, buy another external storage device, and do a Google-search for "drive image freeware".
Pick one of those applications, and do a "image" backup to this second external storage device.
Third, disconnect the 3 "old" drives, carefully label them, and set them aside.
Fourth, connect the 3 "new" drives, delete the old RAID-5 array definition,
and create a new RAID-5 array definition.
Fifth, do an "image restore" from the second external storage device to the new array.
If you have any problems, all you need to do to "back-out" is to:
* disconnect the "new" drives
* reconnect the "old" drives
* delete the "new" array definition
* redefine the "old" array definition
and you're back to the "old" configuration.
Dec 07, 2010 | IBM ServeRAID-7k Controller (71p8642) SCSI...
Steps to configure raid 5 on ibm xseries 232
hi,
which material have you ? : CD
which server ? xseries xxx model type ?
If this is the unique SCSI adapter in your system
or the unique seen, you must:
0) download
90p2772.iso 505,085,952 IBM ServeRAID support CD v6.10
or use what you have.
1) Boot from cd (linux) to configure RAID , before install W2K Server
2) run 23k4684.exe (previous site) in another pc and make a floppy
3) boot from W2k CD and press F6 when proposed
4) insert floppy previously made
5) when OS is installed, or from CD or using 23k4687.exe,
install "IBM ServeRAID Manager", to see activity.
Oct 28, 2010 | IBM eserver xSeries 232 8668
Dan
May 12, 2010 | IBM eServer xSeries 336
"how to change write through to write back in 7k" Problem Now!
You need to use download, boot from and use the ServeRAID Support CD and the RAID controller tools on that disc. You cannot modify RAID controller features on the 7k while it is operational and/or in use.
See ServeRAID support page at http://www-947.ibm.com/systems/support/supportsite.wss/docdisplay?brandind=5000008&lndocid=MIGR-62462
Feb 11, 2010 | IBM xSeries 346 Server
Data recovery
Unfortunately, a three disk RAID 5 can only tolerate a single drive failure. Is it possible that disk 0 and disk 1 were reversed? If so, then you might be dealing with only one failed drive and might be able to rebuild the RAID if you get disks back where they belong.
Otherwise, you will need to send the disks off to a data recovery service and hope for the best. This is only viable if the data is very valuable as this will be very expensive. Typically more than $1000 just to evaluate and diagnose.
Jul 09, 2009 | IBM eServer xSeries 225
Defunct of HDD in netfinity 7100 RAID
Mar 16, 2009 | IBM Netfinity 7100 8666 Server
Defunct drive
You could rebuild the defunct drive with the raid program on your server.
i don't know your type and model of your server.
8488 or 8648 and the model 3 digits.
for this you need serveraid manager
http://www-304.ibm.com/jct01004c/systems/support/supportsite.wss/docdisplay?lndocid=SERV-RAID&brandind=5000008
please do not update your firmware or drivers at this point if applicable.
if rebuild of a defunct drive doesnt work you'll need to change the drive. remember in a raid 5 you need min. 3 drives.
Dec 06, 2007 | Computers & Internet
IBM xSeries 226 Server Logo
190 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
