Question about Ubi Soft Entertainment Prince of Persia: The Two Thrones for GameCube
Setupreg.dat - Ubi Soft Entertainment Prince of Persia: The Two Thrones for GameCube
How to change a Dat file so I can open it on my Samsung tablet
DAT is a file extension that's mostly found on video CD. It is usually used to store MPEG-1 encoded video on VCD. This kind of video file is file format that are not playable in the default Android video player.
But don't worry, there are ways to make it playable. In this article, I'll show you how to play DATvideo file on your Android device.
To be able to play DAT video file in your Android device, you should need the help of a third-partyvideo player app. In this case, I suggest you to use MX player.
MX player is one of the most popular video players that can play almost every video format. It also play all resolutions that supported by your device.
If you don't have one, you can download it for free at Google play store.
Once installed, open the DAT video file with your file manager app and the video should be loaded and played by the MX player. However, you're unable to load DAT video file on 'My files' or 'Gallery' app, as well as 'MX player'. To be able to open DAT video file directly from your Gallery app or MX player, you should rename the file extension from .DAT to .MPG. For example, filename.dat change to filename.mpg. Once you're done, the video will appear on your MX player list and you can now play the video file on your Android device.
Oct 23, 2014 | Samsung Cell Phones
While pening the game the launch button is inactive
GO TO POP INSTALLED PLACE AND OPEN ALLRIP FOR GAME CMD FILES OR A UNKNOWN FILE SETUPREG.DAT OPEN THIS FILE BROWSE THIS TO REG.EXE
AFTER THIS OPEN THIS REG FILE A MESSAGE APPEAR WOULD YOU LIKE TO ADD THIS IN REGISTRY PRESS OK
Aug 13, 2012 | Ubi Soft Entertainment Prince of Persia:...
DAT drive is not working.Tape once we insert comes out abruptly
Clean Tape drive using cleaning tape / Update Dat drive Firmware
Jul 06, 2012 | HP ProLiant ML370 G6 Server
Wont install
After you download from Torrent , Copy the RAR file and paste into a folder ( you can creat a folder under the microsoft game a name it AOC )
UnZip the RAR file in there , then double click those files
1 - setup 2 - SETUPREG 3 - age2upa
Now make a shortcut at desktop for this file ( MYTH-Age2_x1 )
Use that icon to enter the game
Have fun
Apr 20, 2010 | Microsoft Age of Empires 2: Age of Kings...
Deleting files
Im assuming you want to delete browsing history. You can go to Internet options in the control panel and delete browsing history there but to completely remove history files you need to delete the index.dat file.
This file, if you're using windows XP can be found in different places:
C:\Documents and Settings\<username>\Cookies\index.dat
C:\Documents and Settings\<username>\Local Settings\History\History.IE5\index.dat
C:\Documents and Settings\<username>\Local Settings\History\History.IE5\MSHistXXXXXXXXXXX\index.dat
C:\Documents and Settings\<username>\Local Settings\Temporary Internet Files\Content.IE5\index.dat
C:\Documents and Settings\<username>\UserData\index.dat
If you are using a different operating system, just search for index.dat and make note of the locations.
Once you've noted where the locations are you need to restart the computer and log in using safe mode. In safe mode pull up a cmd screen by going to start>run> then type cmd and hit enter.
In the cmd screen change directory by using the command cd C:\Documents and Settings\<username>\UserData for example and then del index.dat (to delete the index.dat file).
Restart and you're good to go.
Apr 06, 2010 | HP Pavilion dv6000z Notebook
It comes up (edge.dat tidak menemukan) as soon as u put it on
Looks like the card dont find the edge.dat.
The edge.dat must be direct on the SD card and not in a folder. Also install the folder Edge with the cheats.dat inside
Jan 26, 2010 | Nintendo DS Console
Insalling m3 resl deal but cant find DS MENU .dat
apparently m3 dont do upgrades now but this might help http://www.m3-forums.net/viewtopic.php?f=4&t=312
basically it converts the r4 ds menu.dat to work on m3 simply (may work for m3 real) so now all you have to do is go to r4 download site and download latest version. 1.18 from here http://www.r4dscart.com/r4-software.html (select the english update) then patch ur dat file replace it back to where you took it from before patching and then copy all 4 files ( _system_ moonshi _ds_menu.dat _ds_mshl.nds) into the root of micro sd card. advise you to copy any files/games you have on your mem card then copy the games over to your newly installed firmware. oh by the way in the link i provided on how2 patch the ds_menu.dat it might be bit vague on where you put the ds_menu.dat file to patch it, all you do is drag and drop it into the PATCH app thats inside the "r4 to m3 patcher" folder. post a reply to let me know how you got on
Mar 27, 2009 | Nintendo DS Lite Console
DAT MACHINE
Hi
What make and model DAT is it you are using. I have plenty of knowledge on older decks.
regards
robotek
Jun 20, 2008 | Audio Players & Recorders
Ubi Soft Entertainment Prince of Persia: The Two Thrones for GameCube Logo
Top Ubi Soft Entertainment Video Game Consoles & Games Experts
Dan Shibata
Dan Shibata
Colin Stickland
Colin Stickland
akigawa
Level 1 Expert
Are you an Ubi Soft Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
