Question about Jacuzzi Pool & Spa
I am currently have a WINER mod#AMC-2300 hot tub that uses 3-Mod#TDA200 pumps to power the 33 jets of the 6 man spa.What I need is owners manual for the pumps, that show detailed re-build diagrams
  • Andy Knight Apr 16, 2017
    Hi I keep seeing your post unfortunately I am no able to help you with your problem but I'm hoping you might be able to help me I am looking for an owner manual for the same Amc 2300 hot tub would you have one regards Andy
  • 248 Answers
SOURCE: Need an owners manual or a relay wiring diagram
should be able to pick up one online
Posted on Oct 03, 2009
SOURCE: Hot tub maintenance
Posted on Oct 24, 2009
  • 366 Answers
SOURCE: just looked at 2000 coast spa hot tub with 1 6.5hp
a 6.5hp motor produces quite a bit of force. It should be able to support 30 jets just fine. Most spas range from 2hp to 7hp. Depending on your preferences, the 6.5 should be plenty but if you really want a powerful therapy jet, two 7hp pumps should be more than sufficient. They will also kick your electric meter up a few notches...
Two pumps give you more options, you don't have to have half of the jets turned off so one area can have more power, the dual pumps give you the option to run nearly all of the jets at the same time if you have more than just a couple people in the spa a once.
Posted on Nov 09, 2009
  • 1378 Answers
SOURCE: hot tub no heater or pump heater light flashing
Thank you for posting your question here on
Start with the pump. If it is bound up and not starting nothing else will work. Close off your valves and disconnect the pump unions. Once free, reach in with the pump unplugged and try to turn the impeller by hand. Will it turn? If not, you'll need to free it or get the pump repaired. Once the pump is working and water circulating your heater should start working.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
Posted on Mar 10, 2010
  • 331 Answers
SOURCE: hot tub not heating need owners manual to reset
You need to provide the exact make and model of your spa
Posted on Apr 14, 2010
Want manual for Marquis spa ME-33-B-Y-082212
hot tub manuals ' guides ' Marquis - Marquis Spas
Marquis has indexed our hot tub manuals and hot tub guides. ... 2010 US OwnersManual · Wish Insert · Euphoria Insert · 2010 EDHT Owners Manual. 2009.
Failure to use, maintain or install the spa in compliance with this owner's manual could result in ... This symbol indicates the need for separate waste collection of ...
[PDF]owner's manual - Marquis Spas
Dec 30, 2015 | Cars & Trucks
What does error 1 mean on my winer amc 2210 hot tub
Is this one of those Internet hot tubs?
An import from china?
don't know about the fault code, maybe check the owners manual?
As far as the spa, what is it doing or not doing, besides the fault code?
Apr 06, 2015 | Pool & Spa
Need specs for Apollo Mod.#AP72R
Try Googling (Apollo)(AP72R)(manual) without parens.
Aug 11, 2017 | Home
How do you winterize a hot tub? QCA Jewel Model SUV M7
this is taken right from a jewel series QCA hot tub manual.....Winterizing
In very cold weather you may not want to venture outside to use your spa. In this case, you may move it to a heated area, or leave it as is until the weather warms. If you do leave the spa unused for a long period of time in severely cold weather, you should winterize the spa to avoid accidental freezing due to a power or equipment failure.. Follow these easy steps: Turn power to the spa OFF. Drain the spa. Use a wet vac to **** or blow out the air injectors, water jets and water suction fittings. Add 1-3 gallons of RV antifreeze, depending on the size of the spa, to all the air injectors, water jets, suction drains, and filter. Caution: Any lines not receiving adequate antifreeze are subject to freeze damage!
Dec 29, 2011 | Qca Spas Jewel Series Topaz Plus Hot Tub
2005 Yamaha TTR 90 E poor high-speed performance
Hi, Pete7971 and the usual suspects are:
1. Inlet system air leak.
2. Enrichener valve not seated or leaking.
3. Damaged or restricted fuel tank vent system.
4. Restricted fuel supply tract.
5. Dirty or damaged air cleaner element.
6. Plugged bowl vent or overflow.
7. Worn or damaged needle or needle jet.
8. Vacuum piston assembly malfunction.
9. Loose or plugged main jets or passages.
10. Improper float level.
11. Accelerator pumps inoperative.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha TTR90 Air Box Mod High Performance Flow
Yamaha TTR90 Carb rejet carburetor re jet clean High performance mod
YAMAHA TT R90 Owner Service Manual
OEM parts for Yamaha
YAMAHA TT R90 Owner Manual
Jun 04, 2011 | 2005 Yamaha TTR 90 E
Need manual for a vita bijou hot tub
Vita Spa is now out of business, so contacting the factory isn't a option. You can try googling for an online manual download. They usually cost between $10 and $15.
Jun 14, 2010 | RTO 2 Person Spa Hot Tub 8 Hydrotherapy...
Hot tub not heating need owners manual to reset
Dec 12, 2009 | RTO 2 Person Spa Hot Tub 8 Hydrotherapy...
Hot tub has power but nothing else works
MY control panel was replaced ,it cycles but, no lights ,no jets,no heat works..What's the problem .
Oct 01, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Just filledd up an old dakota hot tub model126-dkn-4248-2 and ita been running for about 4 hous and wont heat up i would also like an owners manual for one but dont know were to look
it may take longer to heat to desire temp. if nothing chang have you adjust the temp higher . if everything check ok check high limit switch next to the control box ussualy red bottom push soft in
Sep 13, 2009 | RTO 2 Person Spa Hot Tub 8 Hydrotherapy...
Hot tub won't stay at set temperature
I have a 2002 Infinity 6 man spa that I just got from a friend. I am also an Electrician. I had to replace the Spa pack because it wasn't working. Once I replaced the Spa Pack and used the tub it got up to temp no problem but once I got in the temperature slowly dropped and it couldn't keep up. After some research and discussion with a pool tech I found out that there is a jumper on some spa packs. It is a LC (low current) / HC (high current) jumper. It limits the current (amperage) that your tub draws. If you are running it on the LC setting it keeps the tub at low current by not running the heater when the jets are on. (this way it keeps the current low by running one only at a time) If you set it for HC it will allow high current to be drawn and let the heater and the jets be on at the same time. On my spa pack it is P26 Jumper. I have found it is also listed as Jumper 4 on some spa packs. the jumpers are located in the lower right of the circuit board. Make sure you shut off the power to the tub and know what you're doing before you attempt changes. you can also google "Gecko Spa Pack Service Manual" and you will find the manual for your tubs spa pack. Good luck.
Nov 11, 2008 | Sport & Outdoor - Others
Pool & Spa Logo
105 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
