Question about HP Office Equipment & Supplies
Fix heater The light is not glowing while printing any document,also the the written texts are easily erased.The documents view is also not good,one black line is coming .
  • HP Master
  • 1,121 Answers
The printed matter is erasing because of faulty "Fuser Assembly".Fuser heater is not producing the specified temperature to fixup the image on the media. Replace it..
Posted on Oct 17, 2013
Bubbabear64
  • 2794 Answers
SOURCE: my Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Posted on Jul 20, 2008
leroyal
  • 2120 Answers
SOURCE: Horizontal white lines through the text
Your ink cartridge (s) is dried up, even some new ones are dried up, even tho' they're sealed.
Some self-tests don't use black.
Posted on Sep 21, 2008
SOURCE: Black lines through documents
When printing from the printer we have 2 black lines. It prints fine from the computer. How do I get the black lines to go away?
Posted on Sep 28, 2008
jonb3838
  • 237 Answers
SOURCE: HP Laserjet 3390 Prints a Black Line on papers
make sure you check and make certain there are no scratches clean both the top of the scanner and the scanner bed itself and wipe down with a lint free cloth
Posted on Feb 12, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Black lines down on printed page
This is caused by dirt/debrise on the ADF (automatic document feeder) scanner glass. You need to open up the feeder where your originals are fed in and look for a strip of glass that runs from front to back. It is about an inch or so wide. You need to clean this glass to get rid of the lines. Some models have this glass just to the left of the large main glass, but in your case I beleive it is in the feeder itself.
Good Luck.
Posted on Apr 23, 2010
Make font larger on HP1510 printer
What font are you referring to? Have you prepared a document in a word processing program, or added text to an image file, and are disappointed because you want to see the text printed larger? If so, your best solution is to edit the document or image and change to a larger text size. For example, most text documents will normally default to either a size 10 or 11 text which is readable but small. Changing to size 12 or 14 will make the text look larger onscreen, and the text will also print larger. The font name and font size should be displayed on one of your processing program's toolbars, and is easily changed to a different font name or size. If you are simply copying an already printed document and want the text to appear larger, you should refer to your printer's User Guide. If you don't have the User Guide, you can download a free copy at this link:
HP PSC 1510 All in One Printer User guides
Nov 15, 2014 | HP PSC 1510 All-In-One InkJet Printer
Remove header footer
In both MS Word and Excel you go to the View Menu and select Header and Footer. It is simple to Delete any unwanted text from them.
In Word, In print layout view, you can quickly switch between the header or footer and the document text. Just double-click the dimmed header or footer or the dimmed document text.
To view a header or footer, switch to print layout view. To edit or format a header or footer, you need to display the header or footer you want.
Jan 12, 2014 | Microsoft Office Professional 2007 Full...
Hacer documentos
Create a New Document
There are several ways to create new documents, open existing documents, and save documents in Word:
  • Click the Microsoft Office Button officebutton.gif and Click New or
  • Press CTRL+N (Depress the CTRL key while pressing the "N") on the keyboard
You will notice that when you click on the Microsoft Office Button and Click New, you have many choices about the types of documents you can create. If you wish to start from a blank document, click Blank. If you wish to start from a template you can browse through your choices on the left, see the choices on center screen, and preview the selection on the right screen.
Opening an Existing Document
  • Click the Microsoft Office Button officebutton.gif and Click Open, or
  • Press CTRL+O (Depress the CTRL key while pressing the "O") on the keyboard, or
  • If you have recently used the document you can click the Microsoft Office Button and click the name of the document in the Recent Documents section of the window Insert picture of recent docs
Saving a Document
  • Click the Microsoft Office Button officebutton.gif and Click Save or Save As (remember, if you're sending the document to someone who does not have Office 2007, you will need to click the Office Button, click Save As, and ClickWord 97-2003 Document), or
  • Press CTRL+S (Depress the CTRL key while pressing the "S") on the keyboard, or
  • Click the File icon on the Quick Access Toolbar
Renaming Documents
To rename a Word document while using the program:
  • Click the Office Button officebutton.gif and find the file you want to rename.
  • Right-click the document name with the mouse and select Rename from the shortcut menu.
  • Type the new name for the file and press the ENTER key.
Working on Multiple Documents
Several documents can be opened simultaneously if you are typing or editing multiple documents at once. All open documents will be listed in the View Tab of the Ribbon when you click on Switch Windows. The current document has a checkmark beside the file name. Select another open document to view it.
Document Views
There are many ways to view a document in Word.
  • Print Layout: This is a view of the document as it would appear when printed. It includes all tables, text, graphics, and images.
  • Full Screen Reading: This is a full view length view of a document. Good for viewing two pages at a time.
  • Web Layout: This is a view of the document as it would appear in a web browser.
  • Outline: This is an outline form of the document in the form of bullets.
  • Draft: This view does not display pictures or layouts, just text.
To view a document in different forms, click the document views shortcuts at the bottom of the screen documentviewsshort.gif or:
  • Click the View Tab on the Ribbon
  • Click on the appropriate document view.
Close a Document
To close a document:
  • Click Close
Jan 04, 2011 | Microsoft Office Computers & Internet
My teacher give us assignment..the question is what is ms word and what it is not?
Word is the most popular word-processing program in 2009 not only because of the marketing juggernaut that is Microsoft, but because it simplifies document creation. The program is simple enough to make quick personal letters and comprehensive enough to produce complex technical manuals.
WYSIWYG
1. What You See Is What You Get (WYWIWYG) with Word. The Word document on the screen looks exactly like the printed version, which saves time and effort in defining the appearance of the hard copy. With Word, you can view hidden fields and formatting codes, and change bars to help in creating the document. To see what the final will look like, all you have to do is to turn all these options off and view the document in "Print Layout" view.
Custom Interface
2. You can customize the look and feel of Word so it fits exactly the way you work. You can add, change or move toolbars to any part of the screen. Menu commands can be similarly managed. Text entry guides such as the status bar, scroll bars, rulers and screen tips can be turned on and off as needed.
Flexible Documents
3. Because Word is the PC's dominant word-processing program, its document format can be opened directly by or easily imported into external programs such as Adobe Pagemaker and Corel WordPerfect. Conversely, Word can easily bring in many types of file formats, including pictures and sound.
Tables
4. Word offers many ways to create tables, by specifying the number of rows and columns in a form or by dragging a single cell into several. However, the most intuitive method involves a pencil icon. By moving this pencil on the screen, you can draw the full table, create cells of varying sizes and specify borders of different colors and thicknesses.
Macros
5. Macros feature one-click access to complicated and repetitive text by recording keystrokes you can then assign to a menu option, key code or button. Whenever you need to repeat the entry, simply choose the menu option or click the macro button. More complicated macros, programmed in a subset of Visual Basic, can duplicate functions of stand-alone programs with dialog boxes, forms and data checking.
Automation
6. Word automates many previously mundane tasks. You can check and correct spelling and grammar as you type. Text in headers and footers can automatically change to reflect new chapter titles or section numbers. After you define Table of Contents formats and text references, the page numbers of those features automatically update whenever you generate a printed copy.
Jun 30, 2010 | Microsoft Windows XP Professional for PC
Adobe 7.0 : The highlighting tool is erasing my text and just
if you do not save it ...just go to edit ..in the left upper corner ...and roll back a few times..it will fix..also reloading the original document will do that too
Nov 13, 2009 | Adobe Acrobat 7.0 Professional
This may sound trivial, but my husband has written a WordPerfect document and needs to add a title page at the very beginning. We can't figure out how to insert the page without messing up the whole...
Well, I don't know wordperfect very well, but if the document is going to be delivered in printed form, you could always just create a new, one-page document as your title page and print the two documents separately.
Nov 13, 2009 | Corel WordPerfect Office 12 Home Edition...
How do I print a document written in Office 2007 Word ?
Open your MS Office 2007 document, look in the top left of the window for a large round button that glows, if you click on that all your print options are there.
Regards.
Aug 03, 2009 | Microsoft Office Professional 2007 Full...
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
Scan views fine; prints fuzzy
Try to change the dpi to the maximum, maybe 600 dpi. This will make the picture more defined.
Nov 19, 2008 | Brother MFC-7820N Printer
Scan to Microsoft Works document is SMALL... tried settings... nothing works
I've always been told with text recognition, etc. that the OCR is only as good as the spell checker and formatting capabilities of the application you import to. Works is unfortunately only a step up from using Wordpad and I believe this is probably an issue with MS Works not your printing software. Make sure you are in "Print View", but bottom line... you may need to scan to scan some documents to another application first and import the file after.
May 25, 2008 | Lexmark X4270 All-In-One InkJet Printer
mukhtar21 shaikh
mukhtar21 shaikh
