Question about Tools & Hardware - Others
Given the time in number of seconds, find out how many hours have been completed toHours(22125) = 6 toHours(3598) = 0
Change date sharp el-2630PIII
"GT": Grand Total
"•": Neutral
" ": To set up date, time, conversion
rate, and tax/discount rate, place the
switch at the "RATE SET" position.
Date:
• Enter in the order of month, day
and year, then press to
complete the entry.
• Use to separate month, day,
and year.
• When is pressed, the number
entered is evaluated and displayed
as "date" if the value is within the
following range; "Error" is
displayed otherwise, and the
previously set date is restored.
Month: 1 - 12; day: 1 - 31; Year:
2000 - 2099 (in 4 digits) or 00 - 99
(in 2 digits)
Time:
• Enter in the order of hour, minutes,
then press to complete the
entry.
(There is no entry available for the
seconds value. The clock starts at
zero second.)
• If the hour/minute digit is less than
10, it is not necessary to enter the
first digit "0".
• Use to separate hour and
minute values.
as "time" if the value is within the
previously set time is restored.
Hour: 0 - 23 (24-hour system for
the hour entry), Minute: 0 - 59
Dec 19, 2010 | Sharp EL-2630P Calculator
No watch instructions
- CHARACTERISTICS
1. Stopwatch: Measures up to 9 hours, 59 minutes,
59 seconds and 99 with 1 ¤ 100 second readout.
• Lap time measurement: Up to 9 lap times
can be measured. The lap time difference and
the fastest lap time are calculated and displayed
during the measurement.
2. Time/calendar display: Hour, minutes, seconds,
month, date and day of the week.
• Automatic calendar adjustment: Calendar
adjusts automatically for odd and even months
including February of leap years, but not for
February of common years.
• Time indication: Changeover between 12-
and 24-hour indications is possible.
3. Daily alarm: The alarm can be set to ring on a
24-hour basis.
4. Dual time: Time of a different time zone can be
set and displayed.
5. Stroke function: The watch can be set to beep
at a selected rate to serve as a pacemaker in
jogging, etc.
6. Countdown timer: Up to 9 hours 59 minutes
and 59 seconds can be set in seconds.
• “Lap time” refers to an elapsed time required to
cover a given section of the whole distance.
1. At the start of the activity, depress button “D” to
start the stopwatch.
2. At the end of the first lap, depress button “A”.
The first lap time and lap number are displayed,
though the second lap time is being measured
internally.
3. Depress button “A” to release the lap time before
the end of the second lap. The first lap time and
lap number disappear, and the measurement in
progress and “0” are displayed in place of the lap
time and lap number, respectively.
4. At the end of the second lap, depress button “A”.
The second lap time and lap number are displayed,
though the third lap time is being measured
internally.
5. Measurement and release of the lap time can be
repeated by depressing button “A”.
6. At the end of the activity, follow either of the two
methods below.
a. To display the final lap time, depress button
“A”. Then, depress button “A” to release the
lap time, and depress button “D” to stop the
measurement.
* The time displayed when button “D” is depressed
is not the total elapsed time of the
activity, that is, the time that elapsed from
the start until the end of the activity but the
time that elapsed from the start until the
stop of the measurement.
b. To display the total elapsed time of the activity,
depress button “D” to stop the measurement.
7. Depress button “B” to reset the stopwatch.
Stopwatch operation
Depress button “C” to show the stopwatch display.
Start Stop Restart Stop Reset
Accumulate repeatedly by
depressing button “D”.
Accumulated elapsed time measurement
D D D D B
Notes:
1. When a lap time measured is the fastest among
the lap times previously measured, a short beep
rings to signal that the memory has been updated
with the new fastest lap time.
2. The lap number counts up to “9”. After “9”, the
number returns to “1”.
• While a lap time is being displayed, depress button
“B”. With each depression of the button, the
difference between the displayed lap time and the
previous lap time is displayed in the following
order.
Latest lap time ® Lap time difference
Fastest lap time ¬
The selection of the display can be made in the
following order with each depression of button “C”.
* A flashing display mark indicates that the corresponding
function is in use.
- HOW TO USE THE STOPWATCH
• The stopwatch can measure up to 9 hours, 59
minutes, 59 seconds and 99 in 1¤ 100 seconds.
* Even if the stopwatch display is changed to another
while the measurement is in progress, it continues
counting properly. After the stopwatch is used,
however, be sure to reset it as the battery energy
is consumed enormously to shorten the battery
life.
Stopwatch display mark
Stopwatch operation
internally.
internally.
methods below.
measurement.
Notes:
Lap time difference and the fastest lap time
order.
• The lap time difference is displayed without a plus
or minus sign. Instead, the lap number of the
faster lap time is always displayed at the right of
the “–” mark.
Ex.)
Notes: 1. While the measurement in progress is shown
on the display, the lap time difference
and the fastest lap time cannot be shown
by depressing button“B”.
2. While the latest lap time, lap time difference
or the fastest lap time is shown on
the display, the display cannot be changed
to another by depressing button “C”.
* With each depression of button “A”, month and day
are displayed alternately.
* With each depression of button “D”, the display
changes over between the 12- and 24-hour indications.
1. Depress button “C” to show the time/calendar
display.
2. Depress button “B” to show the time/calendar
setting display. The second digits start flashing.
3. Selection of the digits to be adjusted (flashing)
is made in the following order by depressing
button “D”.
4. Depress button “A” to set the flashing digits.
One digit is advanced with each depression of
button “A”. Digits except seconds move quickly
by keeping button “A” depressed.
5. After all the adjustments are completed, depress
button “C” to return to the time/calendar display.
Seconds setting
When the seconds digits are flashing, depress button
“A” in accordance with a time signal. The seconds
are reset to “00” and start immediately.
Note: When setting the hour digits in the 12-hour
indication, check that AM/PM is properly
set. Only “PM” is displayed and there is no
indication for the AM setting. In the 24-
hour indication, there is no indication.
Jun 29, 2008 | Sportline 1000 Memory watch
What keys are associated with Time Set AM/PM
GRAND TOTAL / RATE SETTING MODE SELECTOR:
"GT": Grand Total
"•": Neutral
"RATE SET": To set the date, time, and tax rate, set this switch at the "RATE SET" position.
Date:
• Enter in the order of month, day and year, then press to complete the entry.
• Use to separate month, day, and year.
• When is pressed, the number entered is evaluated and displayed as "date" if the
value is within the following range; "Error" is displayed otherwise, and the previously set
date is restored.
Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits)
Time:
• Enter in the order of hour, minutes, then press to complete the entry.
(There is no entry available for the seconds value. The clock starts at zero second.)
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit "0".
• Use to separate hour and minute values.
• When is pressed, the number entered is evaluated and displayed as "time" if the
time is restored.
Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Dec 16, 2010 | Sharp EL-1801P Calculator
To change the Date and Time on my Sharp EL-1801PIII Calculator your instructions refer to a faceplate, which I do not have. What keys are associated with "Time Set," "AM/PM,"...
"GT": Grand Total
"•": Neutral
Date:
date is restored.
Time:
time is restored.
Dec 16, 2010 | Sharp Office Equipment & Supplies
How do I change the date on a Sharp EL-1801V calculator?
Below is the step by step directions on how to update the date/time/tax rate. To set the date, time or tax rate, set the "Grand Total/Rate Setting Mode Selector (GT . RATE SET) to "RATE SET" position.
For Date:
1) Enter in the order of month, day and year, with the decimal point in between each set of numbers. Month 1-12, Day 1-31, Year: 2000 - 2999 (4-digits) or 00-99 (2-digits).
Example 04.10.2010
2) After the year, press the button with the clock/calendar symbol to complete the entry. When this button is pressed, the number entered is evaluated and displayed as "date" if the value is within the following range; "Error" is displayed otherwise, and the previously set date is restored.
For Time:
1) Enter in the order of hour, minutes with a decimal in between the hour and minutes, then press the button with the clock/calendar symbol to complete the entry. (No seconds value is entered) When this button is pressed, the number entered is evaluated and displayed as "time" if the value is within the following range; "Error" is displayed otherwise, and the previously set time is restored. Hours must be represented with 0-23 (24-hour system for the hour entry), Minute: 0-59.
FYI, This calculator uses CR-2032 lithium battery.
Enjoy!
Apr 10, 2010 | Sharp EL-2630P Calculator
How to change date and time on a sharp EL - 1197P calculator
Found Instructions for EL-1197PIII Calculator, think its the same thing
To set up date, time, conversion rate, and tax/discount
rate, place the switch at the "RATE SET" position. Date: · Enter in the order of month, day and year, then press to complete the entry. · Use to separate month, day, and year. · When is pressed, the number entered is evaluated and displayed as “date” if the value is within the following range; “Error” is displayed otherwise, and the previously set date is restored. Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits) Time: · Enter in the order of hour, minutes, then press to complete the entry. (There is no entry available for the seconds value. The clock starts at zero second.) · If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”. · Use to separate hour and minute values. · When is pressed, the number entered is evaluated and displayed as “time” if the value is within the following range; “Error” is displayed otherwise, and the previously set time is restored. Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Apr 06, 2010 | Sharp EL-1197P Calculator
I need to change the time on my Sharp EL-1750PIII calculator
You can access the .pdf manual for your particular calculator here:
http://www.sharpusa.com/files/cal_man_EL1750PIII.pdf
Page 1 for how to set date/time:
“RATE SET”: To set the date, time, and tax rate, set this switch at the “RATE SET” position.
Date:
• When is pressed, the number entered is evaluated and displayed as “date” if the
date is restored.
Time:
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”.
• When is pressed, the number entered is evaluated and displayed as “time” if the
time is restored.
Apr 27, 2009 | Sharp EL-1750PIII Calculator
Need to change the time on calculator
Date:
Enter in the order of month, day and year, then press date/time button
Use ▪ to separate month, day, and year EXAMPLE 3▪13▪2009.
When (date/time) button is pressed, the number entered is evaluated
Time:
Enter in the order of hour, minutes, then press date/time button to
complete the entry.
Use to separate hour and minute values EXAMPLE 8▪15
When is date/time button is pressed, the number entered is evaluated
When settings are complete place the switch back to GT
Mar 11, 2009 | Sharp EL-1197PIII Calculator
HOW TO SET A CLOCK AND CALENDAR ON SHARP EL-1750P CALCULATOR
GT •RATE SET GRAND TOTAL / RATE SETTING MODE SELECTOR:
“GT”: Grand Total
“•”: Neutral
Date:
date is restored.
Time:
time is restored.
Aug 22, 2008 | Sharp EL-1750PIII Calculator
Action script
I tried your script and it all checked out fine when I ran it. Make sure you click on the first frame of layer action and open the Action Script Panel (F9). Once this is accomplished. Click on the second frame of layer action and press F6 key. Like I said everything worked out when I tried using the script you posted so, if anything I would suggest starting from scratch.
Aug 24, 2007 | Macromedia Flash MX
Tools & Hardware - Others Logo
44 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
