Question about Coffee Makers & Espresso Machines
Cimbali m32 showing fault code E58 - Coffee Makers & Espresso Machines
3 Suggested Answers
bunnydawg
  • 5158 Answers
SOURCE: hi, I need to download or buy an operation manual for La Cimbali
http://www.home-barista.com/espresso-machines/la-cimbali-m30-classic-manual-i-have-got-it-pdf-t6127.html
parts diagram there too
Posted on Mar 22, 2009
  • 5 Answers
SOURCE: la cimbali m32 bistro overheats How do i fix this?
Hope it would help by follow the step on this link: http://www.hwl.dk/product-images/mespres32_man.pdf
Posted on Apr 14, 2012
Red light flashing 4 times what is the problem
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Apr 09, 2015 | Shure Sony Kdl-40Ex720 40 Bravia 3D...
What is E58
Good Afternoon Friend,
I understand you are receiving an E58 code on your Frigidaire Affinity washer, model# ATF8000FE. The E58 states that it is a high current on the motor phase. This could possibly be a false code, as well. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 19, 2014 | Frigidaire Affinity ATF8000FE
Error code e58
Hi Grace, thank you for allowing me to assist you. Regrettably, an error code E58 could mean a number of issues, but primarily that the motor is overheating or a higher-than-usual motor current caused by other issues. Typically, an experienced technician would remove the belt to check the motor and motor pulley to ensure all is in working order first. Their next step would be to check the tub pulley and tub bearings. Last items they would examine would be the drive motor and speed control board by ohm measurement. Once the tech has ruled out a number of possibilities, he or she can pinpoint the exact problem and the necessary part to fix the issue. Since parts can often be quite costly, I would personally recommend reaching out to a qualified tech who can accurately diagnose the issue your unit is experiencing.
Aug 04, 2013 | Frigidaire GLTF2940ES Front Load Washer
La cimbali m32 bistro overheats How do i fix this?
Apr 14, 2012 | Coffee Makers & Espresso Machines
What is fault code 67 on a cimbali m53 coffee machine
Hi, error 67 is a lack of water flow through the water sensor during a dispense. proberly due to a blocked piston or dispense nozzle (small hole on the right under the coffee head cover)
cheers
midman
Jan 07, 2011 | Kitchen Ranges
Hi i have a m32 bisto 2 group that is leaking from relief valve
Replace and or check the pressure stat, it will be on the right side of the machine with 2 small wires going to it, you will also have to replace the safety.
Feb 24, 2010 | Espresso RMI La Cimbali Espresso Machine
I have a La Cimbali Domus classic servicing required
check cimbali.com for current contacts.
youtube; ukeboy57
Nov 10, 2009 | Espresso RMI La Cimbali Espresso Machine
Much loved old J.V.C. unit
Sounds to me like the belt drive is slipping!
Need to open her up and check tightness of belt and probably try to buy another one which will be tighter!
Mar 21, 2008 | Audio Players & Recorders
Coffee Makers & Espresso Machines Logo
181 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
