Question about Lands Phones
The problem that G'FIVE W23 model do not work in keypad and the error message 34'H, WIB comment error message
Sorry Terry - I'm not used to this site! Question was - anyone know what the error message E34 means on an Ariston Boiler MicroGenus 24HE please?
The information I have found states it is a problem with the pressure switch. A faulty pressure switch will prevent ignition from occurring. Here is a Youtube video link showing the issue. Reading the comments below may assist you in isolating your problem. Hope this helps!
Ariston microGENUS 24 HE MFFI Error 34
Oct 21, 2015 | Washing Machines
My mbleoven had a E2-F2 code what is the oro
The F2 class of error messages means that the keypad and the control unit aren't communicating properly. First turn off the circuit breaker to the range for a minute. Check if the error recurs after you clear the PF message. If the error recurs, turn off the power again. You need to check the wiring between the keypad and the control unit. Make sure that all of the wire harness connections are fully seated and all the wires are undamaged. It's not uncommon for one wire to get broken so check the continuity.
If that doesn't help, you probably need a new keypad. If you add a comment with the model number of your oven, I may be able to point you to a supplier.
I hope this helps.
Nov 22, 2014 | Whirlpool Ovens
What is error code 34 and where may i locate a troubleshooting guide?
Do you mean Check 34? Fault 34? Either of these indicates a problem with zone 34, which the location should be displayed by your keypad, such as Kitchen Glass, or something of that nature.
Jul 30, 2014 | Honeywell 6160PX Custom Alpha Prox Keypad
Kenmore microwave displaying SE error message. How do I fix it?
That error indicates a bad keypad. You will have to replace the keypad/control console assembly.
Apr 22, 2014 | Kenmore Microwave Ovens
What is an F1 error?
Hello there and thank you for choosing fixya
On Magic Chef ranges, F1 usually indicated a defect in either the keypad or the electronic control. If the error shows when the keypad is disconnected from control, the problem is usually in the control. If the error ceases with the keypad disconnected, the keypad is usually the cause.
On some models the keypad and electronic control are 1 integral part in which case the whole control assembly usually has to be replaced to correct the problem.
ok i hope this is very helpful for you please post me a comment and i can help if you need assistance with parts support or disassembley ok
Best regards Michael
Feb 27, 2011 | Magic Chef Ovens
Have error message F2EO,oven not working
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 21, 2010 | KitchenAid KESC307 Electric Kitchen Range
Controls won't work. Displays message: E0 -F2-
Hi
Thanks for using FixYa. Error F2-E0 on your kitchen aid means that the keypad is shorted and to resolve this issue you’ll have to replace the electronic range control/clock (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 20, 2010 | KitchenAid KERC607 Electric Kitchen Range
How do I reset the remote door unlock code?
For "delete" your personal code, first be sure that you have the factory keypad code...
1. Enter the factory set 5-digit code.
2. Within five seconds, press the 1 - 2 on the keypad and release.
3. Press and hold the 1 - 2 for two seconds. This must be done within five seconds of completing Step 2
All personal codes are now erased and only the factory set 5-digit code will work.
Hope this help (remember comment and rated this help).
May 11, 2010 | 1999 Ford Explorer
Kitchenaid YKGRT607HS6
F2:E0 is shorted keypad, and F2:E1 is no keypad connection, you need to replace the keypad.
You can find schematics and find replacements by entering model number here.
Dec 14, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Oven on our electric kitchenaid stops working and f2e1 error message comes on. It does this frequently
F2E1 is a fault code that indicates the keypad my be unplugged or has failed.
Jun 22, 2008 | Kitchen Ranges
Lands Phones Logo
24 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
