Question about RoboBuilder Audio Players & Recorders
A red light is blinking continuously in my robot though it is fully charged for 4 hours and because of this it is not moving also.what should i do now?
  • 422 Answers
Is the battery seated correctly?
Posted on Oct 16, 2013
What are these 2 blinking lights on my irobot roomba?
"The Charge Indicator Light is located immediately to the right of the power button on Roomba Red and Roomba (sage). On Roomba Discovery and Discovery SE, the Charge Indicator Light is incorporated into the power button. Please refer to the table below to determine what the Charge Indicator Light is telling you.
* Pulsing Amber - Charging
* Green - Fully Charged
* Amber - Partially Discharged
* Red - Almost Fully Discharged
* Flashing Red - Fully Discharged"
At the end of a cleaning mission, Roomba will tell you if it has successfully completed it's mission or not:
GREEN = MISSION COMPLETE
YELLOW = MISSION ABANDONED (Check robot's brushes, etc.)
YELLOW RED POWER BUTTON = BATTERY DEPLETED (Scheduler Models)
RED YELLOW POWER BUTTON = BATTERY DEPLETED (Discovery Models)
number of beeps after ?uh-oh? :
No beeps: A wheel is stuck or is not touching the ground. Pick up the robot, place it down securely on the floor and touch the clean button to restart the cycle.
1 beep: The main brushes cannot turn. Turn over Roomba and remove the brush guard by pushing the two yellow tabs. Remove the brushes, clear any obstructions, and replace them again.
2 beeps: The side brush cannot turn. Turn over Roomba. Look to see if something is wrapped around the side brush. Remove the side brush with a screw driver and check for string or hair that may be wrapped around it.
3 beeps: The vacuum cannot run Remove and empty Roomba?s bin.
4 beeps: A wheel motor cannot run Your Roomba may be stuck or something may be wrapped around a wheel. Look for something wrapped around the wheels. Push them in and out and make sure they turn easily.
5 beeps: The cliff sensors have failed or are blocked. Turn over Roomba and clear any debris that might be caught underneath the front bumper in the cliff sensors. You can also use compressed air to clean them out.
6 beeps: Wheel obstruction or robot attempting to drive over an obstacle. Turn over Roomba and remove any obstructions that prevent the wheels from seating all the way up into Roomba?s body. Also, remove any obstacles that Roomba could drive over.
7 or 8 beeps: Not applicable Roomba?s beep codes do not include 7 or 8 beeps. If you are getting an error with 7 or 8 beeps, try counting again or contact iRobot Customer Care.
9 beeps: Sensor error Please contact iRobot Customer Care.
10 beeps: Roomba is stuck Pick up Roomba and start it again somewhere else. Use a virtual wall or other barrier to keep Roomba away from the
place it got stuck.
Your Roomba may be experiencing an issue where the battery is deeply discharged and may need to charge longer than the standard 3 hours. (or 7 hours if you have a standard charger)
Even with the charging light showing green (this indicates a fully charged battery) the robot is still charging. If your Roomba exhibits behavior where it charges for a short time then runs for a short time you will need to do the following.
1. Plug the charger into Roomba (if you have a home base be sure to plug directly into Roomba instead of using the home base, this will ensure the robot's charging cycle is not interrupted.)
2. After the Roomba's charging indicator goes to solid green please keep the Roomba on the charger for an additional 72 hours. (3 days)
3. After the 72 hours (3 days) has passed, turn your Roomba on and begin a normal cleaning cycle. If this works successfully it may take several uses for the battery to get back up to the performance it once had.
If this does not correct the problem, please call customer support at 877-855-8593
Nov 22, 2012 | Vacuums
My roomba appears to charge and has a solid green light when finished, but when I take it off the charger and try to turn it on I get the 4 note song and blinking red light like the battery is low even...
This is totally happening to me too. It apears to charges, works for about 2 minutes then stops and the red light is on as if its not charged. I am thinking to buy a new battery but they seem to be about AUD$50 and if thats not the problems I have wasted my money. The repair centre in Melbourne was so rude on the phone I wont send it to them as they cannot say how much it will cost me
Feb 13, 2011 | Roomba Robotic Floor Bagless Vacuum
Purchased Norelco shaver 7810XL. Instructions state to charge for 4 hours prior to first use. Green lights began blinking, indicating full charge, after less than 2 hours. Do I continue charging after...
Simply follow the instructions and charge for a full 4 hours the first time. On subsequent charges, unplug when the light blinks after about 1 hour
Dec 26, 2010 | Norelco Health & Beauty
The light on my Roomba flashes amber very quickly when plugged in directly with the adapter. what does this mean? it usually flashes slower when docked.
If Roomba senses that its battery has been significantly discharged, Roomba will enter a special 16-hour refresh charge cycle. When the 16-hour refresh charge is initiated, the CLEAN light will quickly pulse red/amber. Do not interrupt the cycle once it has begun. The 16-hour refresh charge cycle is initiated by the robot and cannot be started manually.
For long-term storage, always remove the battery from Roomba and store in a cool, dry place. Blue or black batteries should be stored after Roomba has been used. Yellow batteries should be stored after being fully charged.
Battery capacity reduces overtime and usually the battery will need to be replaced each year.
May 14, 2010 | Roomba Robotic Floor Bagless Vacuum
The green light is on as though the battery is fully charged, however, when I start a cleaning cycle, it beeps and goes to red immediately without moving.
Remove the battery, hold down the POWER button for ten seconds, then put the battery back in and charge overnight. If it still tells you it's out of power as soon as you start it, it's time for a new battery. http://store.irobot.com
Aug 23, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Scooba battery light turns red as soon as irobot starts
Do you leave the battery on charge long enough? Try 4-hours up to overnight. If so, then the battery is probably at the end of it's useful life. Getting a new battery depends on cost versus life expectancy of the robot and whether it does the job you want it to do.
Jul 19, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Blinking green
You may have the battery light reminder on...so you will need to take it off
Aug 30, 2008 | Verizon Communications BlackBerry Pearl...
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
63 people viewed this question
Top RoboBuilder Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a RoboBuilder Audio Player and Recorder Expert? Answer questions, earn points and help others
