My nexxtech multination travel adapter specifically says on the label that it will convert 240/220 V to 120/110 V, but when i plug it into a 220 V wall outlet its output is still 220 V. (I know this since only my device that will run also on 220 will work, while my 120 V only devices will not.) I have no idea what to do
  • ian murray Oct 19, 2013
    but then why does it specifically say on the label of the device that it 'converts 240/220 V to 120/110 V'
    Novelist:
    Scholar:
  • 100 Answers
It seems your adapter is not a converter for Voltage, but just a plug-converter so it will fit all type of sockets. There's a varistor for safety-protection, but that's all there is. At least, that's what I make up, based upon your description and the manual. See http://downloads.thesource.ca/273/2731445/manuals/manual.pdf
If the converter also should have converted 220/240 V AC into 110 V AC, than the electronics inside is damaged. Actually I think it's just a plug-converter, because there are many devices operating with an internal switched powersupply. The advantage of such technique is it can operate at various AC-voltages, whil only an adapter for the correct plug is needed.
Posted on Oct 18, 2013
Testimonial: "but then why does it specifically say on the label that it 'converts 240/220 V to 120/110 V'?"
  • B.Boelens Oct 19, 2013
    I've re-read the manual, and it there's indeed mentioning the max. Wattage. This would assume, this device is not purely a plug-converter, but also Voltage-converter. In such case, the interior electronics is damaged. If there's just a transformer inside, there's shortcut in the wiring. If there are other type of electronics inside, there's some serious damage. In both ways, it's not safe to use this adapter anymore and try to get a replacement from the store you bought it.
SOURCE: HOW TO FORMAT A WRITE PROTECT USB DRIVE
MY KINGSTON DATA TRAVELER SAY WRITE PROTECTED HOW CAN I FORMAT IT CAUSE WHEN I FORMAT IT DIRECTLY IT SAY DEVICE IS WRITE PROTECTED BUT MY USB DEVICE DOES NOT HAVE THAT KIND OF SPECIFICATION TO HAVE A WRITE PROTECT DISK.
I had same problem. I fix it with suggestion of 1st guest. I download program from site http://www.apacer.com/en/support/downloads/Repair_v2.9.1.1.zip, and program formated USB and he work fine now. TY for advice.
Posted on Jul 24, 2008
  • 7 Answers
try this tool HP USB Disk Storage Format Tool!!
Posted on Feb 25, 2009
  • 10406 Answers
SOURCE: MY KINGSTON 4GB DATA TRAVELER
Click Start
Click Run
Type CMD
Press Enter
Type CHKDSK q: /F <--- where 'q' is the drive-letter assigned by Windows to your Kingston.
After "check-disk" has repaired all the errors, your device can be formatted.
Posted on Nov 13, 2010
  • 10406 Answers
SOURCE: I HAVE A 4 GB
Click Start
Click Run
Type CMD
Press Enter
Type CHKDSK q: /F
where 'q:' is the drive-letter assigned by Windows to your Kingston.
Press Enter.
When "check-disk" has completed, Windows will remote the "write-protect".
Howw do you make a Samsung bd-F5700 blue ray player operate on a 240 volt power supply
You'll need to bring the voltage down to 110-120 volt. Travel converters do this cheap and effective. The player only uses 12 Watt according to the manual. You could use an old 3 prong extension cord to cut of the connector to connect to your power supply. Get the converter below and plug it into the adapter, who then will fit in the extension cord.
25361686-pcx3svhkvlazjixsdsr3jt1v-2-0.jpg New 220V to 110V Step Down Voltage Converter 50W Travel Power Transformer 25361686-pcx3svhkvlazjixsdsr3jt1v-2-3.jpg Generic Round Europe to USA Plug Adapter
Jan 09, 2015 | Samsung Televison & Video
I got a NexxTech force feedback sterring wheel, the model is 261-8107, is there a driver compatible for windows 8
Have you tried the 32 bit driver? Many things will not have a specific 64 bit driver. You may need to install in compatability mode.
Jul 25, 2014 | NexxTech Computers & Internet
How much does a travel converter cost?
A simple adapter, to only change the size or shape of the plug, is much cheaper than a voltage converter. The former could cost between less than a dollar, to about 7$, it it has a lot of shape and size options. The latter can cost between 10$ to more than 30$, according to quality, brand, size and amounts of options it provides.
Nov 21, 2013 | Luggage & Travel
Do i need a travel converter to use my American appliances in Europe?
Yes. You need a travel converte that will both physically adapt your plugs to the sockets, and convert the socket's voltage to one that is good for your appliances.
What is the difference between an adapter and a voltage converter?
An adapter is usually a travel converter that simply allows one kind, size or shape of plug to physically fit the socket.
A voltage converter is a gadget that stands in between the plug and the socket and converts the voltage released by the socket so that the plug and therefore the device itself don't get ruined by the wrong voltage.
These two kinds of converters can be combined and have different converting options, to allow its use in multiple regions.
I bought sony icf cs10ip from us how do i make it work in india which adaptor to buy please help
Hi,I believe that your unit dual voltage as 110/220 VAC capable..if so you only need an adapter that can be obtainable easly on eBay.. as British standard BS 546.here is a link for an example..Hope this helps! Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :) Thanks
US/EU/AU to UK AC POWER PLUG ADAPTER TRAVEL CONVERTER
http://cgi.ebay.com/US-EU-AU-UK-AC-POWER-PLUG-ADAPTER-TRAVEL-CONVERTER-/220804228457?pt=LH_DefaultDomain_0&hash=item3368f52569
BS 546 (United Kingdom, 5 A/250 V grounded), equivalent to IA6A3 (India), rated at 6 A / 250 V 220px-d_plug.jpg magnify-clip.png D Plug India and Pakistan have standardised on a plug which was originally defined in British standard BS 546.
Jun 25, 2011 | Audio Players & Recorders
To convert Nespresso C100 coffee machine 110 valt device to 220 valt-
use a travel converter plug
one that converts the voltage, not just an adaptor
have you looked at the label and specifications on the coffee machine?
many things are designed to run on both 110 and 220
if so you could just change the plug or use a $1 adaptor
Jan 02, 2010 | Nespresso Essenza C100 Espresso...
I'm going to Europe and wanted to know how to convert electricity so when I plug in my computer it won't fry the computer
This is a copy from the Radio Shack site. The quick answer is go to pretty much any electronic store or most travel stores and buy a Foreign Power Converter.
AC to AC Power Conversion (Foreign Voltage Converters) Purpose of Converter / Explanation of Operation AC-to-AC voltage converters, or travel converters, are designed to convert the voltage used in a foreign country to the voltage required for a particular AC device. These converters are either transformer-based or solid-state, and this affects what type of devices the converter can power. In addition to converting the power, you will often need to also use a plug adapter. Plug adapters are generally either built into the converter, or provided as separate parts. They are also sold separately, for use with multi-voltage devices that are designed to convert the power internally.
Selecting a Converter These are one of the more confusing of the power conversion devices. Because of the range of voltages, plug types and converter designs, many customers find that they need help determining exactly which converter they need. To aid in that process, we have put together a short worksheet to help you determine what type of converter is needed: We recommend that you print out thi sheet when taking a number of different devices to a different country.
First, you should determine the electrical requirements (voltage, frequency, and wattage) for the device(s) you will be taking with you. This information is generally on a label or embossed into the back or bottom of the device. Make a note of the voltage(s), frequency or frequencies, and the wattage indicated for each device.
  • The voltage may be given as either V, VAC or VDC. The standard voltage for US devices is 120 V. Devices that are designed to operate using different input voltages will be labeled, such as 110/120 V, or 120/240 V.
  • The frequency will be given in Hz. The standard frequency for US devices is 60 Hz. Devices that are designed to operate using different frequencies will be labeled, such as 50/60 Hz.
  • The wattage will be given in either watts (W) or volt-amps (VA). If the wattage is not listed on the device, you will need to contact the device's manufacturer for this information. If you have the maximum current consumption (in amps), you can calculate the wattage by multiplying the voltage (V) times the current consumption (A).
Next, you will need to know the electrical requirements for the country you are going to be visiting.
Next, you will need to compare your equipment requirements to the country's information to determine whether you need a Step-up or Step-down Voltage converter.
  • If your equipment accepts the voltage and frequency provided by the country you will be visiting, then only a Plug Adapter will be required.
  • If the voltage of the target country is higher than the voltage required by your device(s), you will need a Step-Up Voltage Converter.
  • If the voltage of the target country is lower than the voltage required by your device(s), you will need a Step-Down Voltage Converter.
Once you know what type of converter or adapter you need, consult our list of travel power conversion products to find one that meets your requirements.
Cautions
  • The AC outlet in many foreign bathrooms is for low-wattage devices only. To avoid damage to your converter and/or attached device, check with your host or hotel before powering a high-wattage device (such as a hair dryer) from this plug.
  • Do not use a voltage converter with electronic devices such as televisions, VCR's and computers unless the device indicates that it can handle both 50 Hz and 60 Hz.
  • Do not use heating appliances, such as hair dryers, irons and coffee-makers, on a transformer-based voltage converter.
  • Do not use non-heating electronic devices, such as calculators, electric razors and portable audio players, on solid-state voltage converter.
  • Do not use 110-120 VAC Surge protectors or Uninterruptible Power supplies on a 220-240 VAC system. Even with a step-down power converter, damage could occur as the two power systems are wired differently.
Sep 22, 2009 | Toshiba Satellite L305D-S5895 Notebook
Can I use a DC adapter on my new Toshiba Satelite laptop for travel. If I can what kind is best.
Your power adapter is most likely a multi voltage adapter. Check the label on the bottom of the adapter, probably 110-240V. If so all you need is an international mains adapter plug so you can plug the power adapter into the mains socket in a foreign country.
Aug 24, 2009 | Toshiba Satellite Pro S300M-S2403 Laptop
Is there an AC Adapter for an Aspire 5735?
Most laptop adapters are suitable to operate between 110 volts to 240 volts and all you need to purchase is an international adapter plugs that convert the adapter to fit your mains socket. These adapter plugs are available in most travel shops.
The range of operating voltages that suits the adapter is printed on the label on the adapter.
Apr 10, 2009 | Acer Aspire 5735 Notebook
Computers & Internet Logo
128 people viewed this question
David Payne
David Payne
