Question about Refrigerators
I have a Maytag refrigerator model no. MT1526PAKS/10 and need to replace the light switch in the refrigerator. How do I remove it and then reinstall the new one?
  • 333 Answers
SOURCE: how do you remove the light switch on a whirlpool refrigerator
The light switch just pops out. Take a butter knife or something of that sort and put it on on end of the switch and poush towards the center of the switch whilr prying it up. It should pop out. I hope this helps. Don't forget to rate my answer.
Posted on Feb 06, 2009
  • 1891 Answers
SOURCE: Maytag refrigerator lights won't work
the bulbs may look good but try a new one or just try tighting them into the sockets tighter. this is a common problem . the rubber prevents the bulb from going in all the way .. silcone grease on the bulb base.. mm
Posted on Dec 03, 2009
Testimonial: "Thank you! Got it fixed!"
BMT60
  • 126 Answers
SOURCE: maytag refrigerator
IF BOTH WATER AND ICE MAKER ARE NOT WORKING YOU MAIN NEED THE MAIN BOARD. THERE IS NO FUSE.
Posted on Apr 24, 2010
jmgldsmth
  • 1906 Answers
SOURCE: How do i replace the light switch in my RTD1900D?
I am guessing that you mean the door switch, so: remove power then using a sharp knife slip it under the switch flange and, pry up gently then: do the same thing on the other side and all around the switch until it comes out; remove the spade wire connectors
Posted on Jul 22, 2010
  • 1891 Answers
SOURCE: I have an older Maytag
can't locate what ? if it the size of the bulb use a 40 w appliance light . very standard . and if this does not ans problem tell me more of what is going on .. mm
Posted on Sep 02, 2010
How do I replace Maytag freezer light
You will need to post your model number. Thanks
Feb 01, 2015 | Maytag Refrigerators
How do I remove the panel on Maytag fridge to replace door switch?
Unplug refrigerator and take a smooth flat head objeck and gently pry the switch out. What is the model number of your Maytag? here is a short clip that explains how, Thanks Sea Breeze
Refrigerator Repair- Replacing the Light Switch (Whirlpool Part # C3680310)
Apr 10, 2013 | Refrigerators
How do i remove the drawers from maytag model mff2258vew2
http://www.searspartsdirect.com/partsdirect/user-manuals/2155/MFF2258VEW2-Maytag-Parts-REFRIGERATOR-manual
Open this link to this manual and go to page 10 for detailed instructions on removing the bottom drawer.
Jan 21, 2013 | Maytag Refrigerators
Jul 22, 2010 | Maytag Refrigerators
Light behind top drawer does not work. I replaced
have you removed the door switch and jumpered it to see if the switch is bad?pry it out with a putty knife and carefully remove one wire and touch the other light switch terminal,if it lights replace the switch
Feb 21, 2010 | Maytag MSD2756G Side by Side Refrigerator
Dec 03, 2009 | Maytag MSD2756G Side by Side Refrigerator
I need to replace the adaptive Defrost Control Board on Maytag Refrigerator Model No. MZD2766GEQ. Where is this board located?
Its Located in the top right inside corner of the refrigerator section near the back wall & to the right of the water filter.Its tough to get out but only takes about 10 minutes to replace the part
Nov 18, 2009 | Maytag MSD2756G Side by Side Refrigerator
How do I install the control board kit Maytag Fridge MBF2258HES
1) unplug fridge2) remove light cover.. 3) pry down control cover( pull hard you will not break it) 4) unplug control mult plug 5 unplug controls connections 6) remove boards from cover 7) install new boards 8) reinstall connection and reinstall cover and light cover
9)program control (instruction should come with new control)
Let me know if you need more help... thanks
Sep 26, 2009 | Maytag MBF2258H Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
