Question about MSI Starcam Computers & Internet
I can't view my ip cam or VS starcam? - Starcam MSI Computers & Internet
I ned too instal may camera starcam clip MSI i ned cd fore instal it on vista
Hi
For Installing the driver of MSI camera starcam click hear and download the driver, after download the driver, click the setup file and install the driver, when installing finish reboot your computer, enjoy to using you CAM.
Cheer
Jul 10, 2011 | MSI StarCam Mini Webcam
How to install camera.. my cam is delete how can i fixed it
Hi there, please follow the steps.
Hi there follow the instruction below.
1**. Double click my computer then double click USB Video Device.
You can see your self then. If the USB Video Device not showing
there then you have to install the cam first.
2. Power On the laptop/PC & after ready your OS for work just put
your Webcam driver disk in DVD/CD RW/ROM. when its open, that
time just select webcam driver and install it as per your operating
system(Vista or XP). So do it, and after finish installation ,restart the
laptop. Your will see your cam is ready for use.
Then follow again the first instruction.**
3. When you confirm after viewing your self in cam , then stop it. Now login on messenger & click to connect the cam from messenger. If any doubt then then ask me a again. Thanks & waiting for your feed back.
Thanks & waiting for your feedback.
Feb 01, 2011 | MSI Starcam 370i Webcam
I WANT TO CONNECT WEB CAM BUT I HAVE LOSE MY
You can Download the Cam Drivers from this link :
http://www.nodevice.com/driver/StarCam_370i/get37594.html
Enter the Verification Code and click download and later install the Software
Jun 25, 2010 | MSI Starcam 370i Webcam
MSI starcam 370i only shows black and white
You can change your lighting to fluorescent lighting the brighter the fluorescent lights are the better your cam will show up the colours, it worked for me.
Aug 02, 2008 | MSI Starcam 370i Webcam
My guard live wont work on my MSI Starcam 370i. Have proper driver that came with it.
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jul 05, 2008 | MSI Starcam 370i Webcam
VeoNetwork Web cam
You can view your Veo Observer web cam at home by either of two methods. The first is to use the Observer Studio software that came with the camera. When you configured the camera, you selected a local (private) IP address for each Veo Observer, and set the address specific to each camera. You then put the same IP address into your Observer Studio Software.
Depending on the brand of router you use on your home network, your Veo Observer camera probably has a local (private) IP address in the format 192.168.0.xxx or 192.168.1.xxx where "xxx" is the actual address assigned to your Veo Observer (by you) and configured to display on the LCD window on the side of the Veo Observer.
You may need to log into your router to see which of the two local (private) IP address formats is used. Your router's user manual will show you how.
To view your Veo Observer, just type the exact local (private) IP address in your IE browser. for example, if you assigned address 100 to your cam, you would enter http://192.168.0.100 or 192.168.1.100 into your browser. Veo Observer will display the Language selection screen. Choose the language, then you log in and view your camera.
To view your camera from outside your home using another computer, you use the same method, but you have to substitute your WAN (public) IP address.
You can log into your router and select its STATUS tab to view your WAN (public) IP address. See you router's set up guide if you do not know how to do this.
An easier way to determine your WAN (public) IP address is to visit Gibson Research Shields Up! web page:
https://www.grc.com/x/ne.dll?bh0bkyd2
and scroll down to the last paragraph where you will find your WAN (public) IP address.
For example, if this address is 123.456.789.100, then you would enter http://123.456.789.100 on your IE browser. You should see the Language select screen, choose your language, then log in and you are now viewing your Veo Observer from outside your home.
Note: when you view your Veo Observer at home, you probably have a fast frame rate and smooth video motion. When you view your Veo Observer from outside the home, the frame rate is certain to be less, and your moving image quality will be choppy. This is normal, as viewing from outside the home is less efficient and the image suffers. There is nothing you can do to boost the frame rate.
Jun 15, 2008 | Veo Observer Network Camera
My cam is blurry
Hi Farrah from Trinidad. What country is this??? Any way I want you to take your cam in one hand and with the other one I want you to turn the lens with your finger. The black ring around the clear part. Now turn on your camera and do it again but real slowwwww. Hope I could help...PS send us a picture sometime James Jessee
Jan 12, 2008 | MSI Starcam 370i Webcam
MSI StarCam 370i
quiero los driver de instalacion de la camara msi starcam 370i
Nov 10, 2007 | MSI Starcam 370i Webcam
Computers & Internet Logo
29 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
