Question about BafoTech BAFO BF-810 Serial Adapter
Win 7 64 usb driver - BafoTech BAFO BF-810 Serial Adapter
Logithec attack3 devices not detected
Disconnect the divice uninstall the driver restart the laptop and then reinstall the driver again restart the laptop then connect the device it works.
Apr 03, 2014 | Video Game Consoles & Games
Instal xp on panasoc cf 71
had same problem with loading win xp proff on cf 74 toughbook mk1.
soution for me was downloading sata hdd controller from panasonic toughbook support site, loading the driver onto floppy drive, using usb floppy with driver ready to use, loading win xp profesional and on first loading win screen pressing f6 when prompted at beginning of win intallation, when on screen instructions to load sata driver appeared, i followed on screen instructions and loaded 3rd option from floppy sata drive mobile driver, left usb installed untill xp loaded and running, do not remove usb floppy untill win loaded, i really hope this helps you
Mar 25, 2013 | Panasonic Toughbook CF-27 Notebook
Usb port on presario F500 quit working, they are seen by device manager but will not reconize a flashdrive when incerted, a mouse or any thing else. Using win 7,64 bit t3500 cpu.
This should be pretty easy to fix. I have seen this many times before. Here's what to do:
Go into device manager and expand 'universal serial bus controllers'.
Start at the very bottom, and start deleting the usb root hubs one by one. You will lose your touchpad control at some point, as the touchpad is actually a usb device. One of thwo things will happen.
1. The usb hubs will automatically be re-detected and re-installed.
2. You will just lose touchpad control after deleting one of the root hubs. If this happens, then shut down using the power button, and restart. Th usb hubs will be reinstalled once you log back into windows. Please let me know if this doesn't fix it.
Joe
Apr 07, 2012 | Compaq Computers & Internet
Why its not working on window 7 and xp, drivers its not compatable or what
the win xp drivers are not compactable with win 7 you will have to download the drivers for win 7 to work fine
Apr 23, 2011 | Edirol HI-SPEED USB (USB 2.0) Audio...
Usb not recognized
if you use it on win 95 or win 98 or vista you need specfic drivers for you usb disk
if you get this on win xp please change the usp ports and use another port to insert the disk one of the ports has to recognise.
if the problem persists the usb port controllor on motherboards needs to be checked for faults or uninstalled drivers ,
if nothing works try a pci to usb internal card and dont forget to loaad drivers . this card has 3 to 6 ports for usb
Jun 10, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Connect laptop to cpu and use laptop as monitor
go to "tiger direct" and purchase a usb to usb interconnect cord. the software they supply will install an ansi and unicode driver so you can use two machines with win xp, win me or win 98. xp and me use the unicode driver while win 98 uses the ansi driver.
Dec 27, 2007 | Compaq Presario 5000 PC Desktop
BafoTech BAFO BF-810 Serial Adapter Logo
37 people viewed this question
Top BafoTech Computers & Internet Experts
pankaj rautela
pankaj rautela
J John
Are you a BafoTech Computer and Internet Expert? Answer questions, earn points and help others
