Question about Sony VAIO VGN-CS118E/P NoteBook
Touch sensor - Sony VAIO VGN-CS118E/P NoteBook
Vgn-cs26g touch sensor not working
my vaio VGN-CS26G' touch sensor panel doesn't work after install Windows 7
please help the basic is Windows Vista after i change it in to Windows 7 touch sensor panel doesn't work
Aug 10, 2012 | Computers & Internet
Touch screen sensor is not working. plzzzzz help me
Hi bonnie1786,
Have a nice day
There are two major causes of malfunctioning of touch screen,the phone fell on a hard object or in water which could damage the sensor board , or either the sensor board is weak and needs to be calibrated or replaced. The sensor board is what makes the touches read on the main board of the phone.
You have to calibrate the screen, but since it is not responding to touch, then it means you have to replace the sensor board of your phone and it will be alright.
Hope it helps.
Thank you for using fixya.
Adieh
Sep 14, 2011 | Cell Phones
Touch screen not working
Hello there,
If the touch screen of your phone is not working, then it means there is a problem somewhere, the problem is that the sensor board is weak and need to be replaced. The sensor board is what makes the touches read on the main board of the phone.
You will have to calibrate the screen, but since it is not responding to touch, then it means you will have to replace the sensor board of the phone.
Have the sensor board replaced and the phone will be okay.
Caseytech
Jul 06, 2011 | Samsung B3410 Cell Phone
My samsung S5233A mobile the touch screen doesnot work? Any solution to this is most welcomed Suddenly my touch screen is not responding. So i m unable to go to menu and use applications
sir the touching sensor of your cellphone has been failed. service your cellphone in the samsung service center to change the touching sensor device [or] the will install any new softwares to work the touching sensor.............
Nov 22, 2010 | Samsung Star GT-S5233 Cell Phone
The touch screen does not respond to any touch even after restart.
the touch sensor has been failed you give to the service center and reinstall the new touching sensor to activate the phone and the you can use your cellphone in normal mode.............
Nov 19, 2010 | Cell Phones
I have a Maytag super capacity range and I am getting an F9 error message on the display. I can't find the model number and it is not where maytay said it would be on the range (according to the site)
The F9 fault code means door latch problem. Check door latch hardware. Here is a list of the Code Description for your unit. Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components. DON'T FORGET TO RATE THIS POST!!
Sep 18, 2010 | Maytag Kitchen Ranges
Oven is displaying f1-8 error code what is it
F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3 or F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
May 04, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Maytag MER5730ACW Stove.F3 fault code.
hello there
Please go thru this list of the fault codes for this appliance it will tell lyou what to do for the fault or what part needs to be replaced
MAYTAG FAULT CODES
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components. Find Parts clear.gif
Jan 13, 2010 | Maytag MER5730 Electric Kitchen Range
When operating the oven I will get a beeping with the error code F-5, F-1, and F-3 should I replace this range
or
Oct 03, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Error message and alarm
These are the fault codes for your unit
or
Hope this helps, Please take the time to give this solution a fix ya rating
clarkco
Feb 27, 2009 | Maytag MGR5870 Gas Kitchen Range
Sony VAIO VGN-CS118E/P NoteBook Logo
13 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
