Question about Nokia 701 Dark Steel
My mobile phone nokia 701 is not detected my idea simcard why solve it and tell me
Raysagem
  • 1017 Answers
SOURCE: No Signal detected on Nokia 6030
Try selecting the 'band' for that country manually.
Posted on Dec 30, 2007
manojro
  • 495 Answers
SOURCE: My nokia 5700 not detecting the memory card.
Check if your memory card is corrupted or not. If its not then just restart your handset once.
Posted on Dec 31, 2008
  • 28 Answers
SOURCE: formatted memory card of nokia N72 not detecting in the phone
See if the phone detects a different memory card. If it doesn't detect any cards at all, try to reset/update the phone firmware.
If that doesn't work the card slot might be damaged, maybe dust and dirt?
Posted on Feb 04, 2009
statione1khi
  • 35 Answers
SOURCE: Unable to connet mobile phone to PC
because you have no pc suite try to install software like pc suite or connect it via blutooth,,,
Posted on Feb 06, 2009
nonontech
  • 4737 Answers
SOURCE: after flash nokia 6300 by
Do you mean it's dead right after the Flash or while flashing? If it's dead after successful, you'll need to re-flash it, in the same way, if it was dead while updating, you will still need to re-flash it. But things you need to note before flashing, make sure you have the compatible flash file installed i.e. RM-217, latest version recommended. Reconnect the phone to your Jaf Box and make sure it's detected in it's Local Mode, if so, you will be able to flash it without any problem. If it's not, then there must be hardware failure eg, damaged ROM or Cpu failure or power supply issue (not likely if the problem started only after it was flashed). It's also important to note the condition of the handset before it was flashed, suppose if there was hardware issue (for which you tried to flash it), then it's possible that the hardware fails to function anymore (just in case).
Have you tried charging it when it's Off? If it's ok, then do you see any message on the screen, eg. Test Mode or Contact Service (perhaps these messages might display in dark screen mode).
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Posted on Jul 19, 2011
Start up phone without simcard?
I am using nokia 2700 classic mobile, some times it shows no sim card available in display. so i switch off my mobile to switch on means it shows Start up phone without simcard?
Apr 30, 2012 | Nokia Classic 2700 Cell Phone
How to reset nokia 701 security code
my nokia 701 forget security code
Mar 31, 2012 | Cell Phones
I HAVE NOKIA C6-00 FROM AUSTRALIA SHEN PHONE WITH SIM CARD "SIMCARD NOT VALIDE" ERROR BUT WITHOUT SIMCARD PHONE WORK OK..PL. SOLVE MY PROBLEM..
it mean, the phone is still lock and need to be unlock or openline thru:
* online code service thru paypal
* or visit any mobile service shop near you so they can help you unlock the phone
hope it helps...please rate me ...thanks
Jun 03, 2011 | Nokia C6 Smartphone
Tell me about the cu920lg phone net i dont know
Hi!
In order for you to surf the internet using your mobile phone, first, you will need internet settings save on your phone. These files are usually sent to your phone once your service provider detect your phone is not yet setup to be used as internet browser.
If you are in Afghanistan. The service provider is the one who made your simcard. (make sure this simcard is 3G) Once you insert the simcard, your network provider will send Phone Settings on your phone. Just save this files. If it don't, then, you will need to call them and ask for the phone settings for your mobile phone.
Hope this helps!
Dec 27, 2010 | LG Computers & Internet
I forgot my nokia 2700c security code tell me how am i open it my mobile no .is 9999289907
sir please call to the related simcard customer care to get the pukcode number. you should say the last 6 digit number which is present before the simcard to the customer care.then they will give the puk code number to unlock the simcard........................
Dec 07, 2010 | Nokia Classic 2700 Cell Phone
I have nokia 2690 handset. but i want to copy my inbox messages to memory card or pc. so can u give some inputs to solve my problem
sir in nokia 2690 phone.in the inbox message right click and mark the messages u want to copy.and then copy the message to the simcard [not in the memorycard will not accepted pc also not accepted] u copy the message in simcard
Nov 18, 2010 | Nokia 2626 Mobile Phone
Hey hi i recently returned from USA. there i had a nokia 2610 from ATT. While i inserted some indian sim in it, it says no smartchip detected. Can u pls help me with this as i dont want to spend any...
Solution for your case is cleaning the simcard connector. If the phone says :phone restricted or simcard not valid ,you have to unlock the simlock with nokia box flasher.
Nov 20, 2009 | Nokia 2610 Cellular Phone
How to unlock any nokia mobile
Unlock codes are a code that is created for the Nokia 3500 phone and is unique to its IMEI (serial number) usually one code is supplied, once it has been entered into the Nokia 3500 mobile phone the phone is unlocked and able to use any simcard
Aug 11, 2009 | Nokia BNIB NOKIA 3500 Classic Unlocked/Sim...
Hang problem
sir the only solution to this problem is take it to a repair shop & have the firmware flashed with a higher version if this doesnt solve the problem have the sim IC replaced if it doesnt solve then the issue is serious TAVHO IC needs to be changed.
cheers
Aug 24, 2008 | Nokia 1600 Cellular Phone
Nokia 701 Dark Steel Logo
29 people viewed this question
Top Nokia Audio Players & Recorders Experts
Vernon Taylor
ray gallant
Outback Jack
Outback Jack
Are you a Nokia Audio Player and Recorder Expert? Answer questions, earn points and help others
