Sub zero 690 model side by side fridge . I did everything but keep on flashing VACUME CONDENSER. Both side working fine. thanks
Most likely that light is caused by a refrigerant leak somewhere in the fridge system. Most likely the fridge evaporator, but you would need a leak detector to confirm this. It could also be that the fan to cool the compressors is not running all the time, or that the compressor itself is weak. Do you have any error codes? Is there a ball of ice forming on the back wall of the fridge section on the left side towards about halfway down from the top? what is build date on the serial tag, located on the frame of the fridge inside the freezer door at the top. Good luck, hope this helps.
Testimonial: "Hi Douglas Randleman There is not any ice anywhere in the Fridge . There is flashes vacum condenser service."
