Question about Boss (RDS-630U) CD Player
Error 12 on boss 630u when inserting sd card and usb
  • healedmichae
    healedmichae Oct 18, 2013
    sorry on my boss 630 u when i insert a usb or a sd card it think for one sec and then it said error-12 then it switches to tuner every time i try to play from usb or sd card
  • healedmichae
    now i have this cd player is in my room plug into a 220v to 12v adapter
I can't get my sd card to work on boss bv8962
make shore you have the right format of music on ur sd card so the player can play it eg avi mp3 mp4
Feb 22, 2012 | BOSS AUDIO SYSTEMS BV8962 Car Video Player
I've purchused a 8gb sony sd memory card and when
It may not be formatted in a compatible format supported by your BOSS Audio system. Check the owner's manual of the unit,it should indicate which format it will support. Copy the data currently on the memory card back to a file on your PC/Laptop and reformat the card to match your BOSS unit. Have you tried other memory cards? It is also possible that the card has too large a capacity for the BOSS unit. T
Feb 13, 2012 | 2002 Nissan Altima
Dont know how to insert sd card
If you notebook does not have a built-in SD card reader, you can purchase an USB SD/memory card reader and connect it to the notebook's USB port.
When the SD card is inserted into the USB card reader the notebook will see the SD card as an external storage device. You can then copy files off this SD card to your notebook etc.
Jun 15, 2011 | Compaq Presario Notebook
How to remove write-protection
Dear Friend,
  • There is a write-protection tab on the mini sd card HOLDER. Every time you insert this into your PC or card holder, this tab slides to the write protect position. Either keep resetting, inserting & reinserting until it doesn't slide or tape it down.
  • There is nothing wrong with the mini sd card. Simply locate the write protection key and push it.
  • The mini sd card has some error: Go for a low level formatting.
  • The card has virus: Remove the virus.
  • Change the Usb Port(Recommend you to Use Backside Port)
  • Change the Cable
  • Restart PC
  • Still have Problem Change Card Reader..
Hope this Helped you..Thanks for Contacting FixYa...........
May 14, 2010 | PNY 2GB microSD Memory Card
Micro sd
Please try to insert it into another computer if the same error prevails uou have to replace your micro sd its bad.
Apr 30, 2010 | SanDisk 1GB microSD Memory Card
I get a card reader error on my printer when i insert my PNY Micro SD card
Has the card worked before.If it is the first time you have tried,is the SD card an SDHC,as some printers will not read these.Try a standard SD card and see if your printer reads that.Hope this helps.
Apr 12, 2010 | PNY 2GB microSD Memory Card
Saying Insert SD Card When Its Inserted
well i had the same problem so i took it to tmobile and the guy on the register inserted a new SD card and he said that my old SD card was ful. so i ask him how can i clear it out and he showed me this lil usb SD card reader that they sell at the store and it was 9.99. but other then that basiclly it means that your SD card us full and you just hook it up to the usb SD card reader and plug it to any computer and go back and clean your files and re-use it again. thats about it. hope that help! : )
Apr 23, 2009 | HTC G1 Smartphone
LG KC550
kk to add music make sure you syn the phone and the cp do the data and all then put .mp3 on all the media files and see if it works. Then if that doesnt go to computor format the card and then put it in the phone. Otherwise you need new stuff.
Mar 13, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
What is the usb port for and how do you work the sd port
Ok basically the USB port is so you can plug a USB memory stick into it and it will play mp3 music files off the USB Stick, or will play off any other USB Mass Storage Device, you can buy these on ebay very cheap. The SD slot is so you can plug an SD Memory card into it and it will work the same as the USB port, SD Memory cards are also very cheap nowa days and are often used in digital cameras. Hope this helps
Mar 12, 2009 | Boss AUDIO SYSTEMS BV9455 Car DVD Player
I think my Micro BR is broken
It is either that you put an incompatible SD card in it. (Believe it or not, many devices will not work with certain SD cards), or the card reader has failed. Try a Scandisk SD card or other popular brand and see if there is any difference in the messages. Otherwise I would say the card reader is faulty.
Aug 06, 2008 | Boss Micro BR Digital Recorder
Boss (RDS-630U) CD Player Logo
60 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
