Question about Boss (RDS-630U) CD Player
Error- 12 when inserting any sd card and usb on boss 630u then it goes to tuner
Card error when insert sd card
Firstly backup your sd card on a windows or mac desktop/laptop and then format it. Then try inserting that sd card again and if everything goes well format it through your camera itself.
Nov 04, 2013 | Fuji FinePix S2000hd Digital Camera
I can't get my sd card to work on boss bv8962
make shore you have the right format of music on ur sd card so the player can play it eg avi mp3 mp4
Feb 22, 2012 | BOSS AUDIO SYSTEMS BV8962 Car Video Player
I've purchused a 8gb sony sd memory card and when
It may not be formatted in a compatible format supported by your BOSS Audio system. Check the owner's manual of the unit,it should indicate which format it will support. Copy the data currently on the memory card back to a file on your PC/Laptop and reformat the card to match your BOSS unit. Have you tried other memory cards? It is also possible that the card has too large a capacity for the BOSS unit. T
Feb 13, 2012 | 2002 Nissan Altima
Dont know how to insert sd card
If you notebook does not have a built-in SD card reader, you can purchase an USB SD/memory card reader and connect it to the notebook's USB port.
When the SD card is inserted into the USB card reader the notebook will see the SD card as an external storage device. You can then copy files off this SD card to your notebook etc.
Jun 15, 2011 | Compaq Presario Notebook
Micro sd
Please try to insert it into another computer if the same error prevails uou have to replace your micro sd its bad.
Apr 30, 2010 | SanDisk 1GB microSD Memory Card
I get a card reader error on my printer when i insert my PNY Micro SD card
Has the card worked before.If it is the first time you have tried,is the SD card an SDHC,as some printers will not read these.Try a standard SD card and see if your printer reads that.Hope this helps.
Apr 12, 2010 | PNY 2GB microSD Memory Card
Inserting either a 4Gb or 8Gb SD card results in a "Memory Card Error".
The S4 accepts SD and MMC cards. SD cards max out at 2Gb. The 4Gb and 8Gb cards are actually SDHC (Secure Digital High Capacity) cards, not SD cards, and thus will not work in devices designed for SD cards. Compatibility goes only one way--SD cards will work in SDHC devices but not the other way around.
Dec 27, 2009 | Pentax Optio S4 Digital Camera
I have a sd micro card and i want to load music on it from my computer to put on my phone
This is a relatively easy problem.
You can do so by using a memory card reader.
You can easily get a memory card reader from any local store at a cheap price, depending on your country.
Most of the Memory card readers come in USB type, so what you just need to do is to plug it in any available usb port on your PC, and then insert your
sd micro card in the appropriate port for it.
For SD Micro Cards (The Smallest Types), most times you might need to first insert it in a Small Card Adapter that comes with SD Micro cards, before inserting it in your USB Card Reader.
Hope this helps you out.
Kindly let me know how it goes.
Good luck.
Nov 19, 2009 | SanDisk 1GB microSD Memory Card
I think my Micro BR is broken
It is either that you put an incompatible SD card in it. (Believe it or not, many devices will not work with certain SD cards), or the card reader has failed. Try a Scandisk SD card or other popular brand and see if there is any difference in the messages. Otherwise I would say the card reader is faulty.
Aug 06, 2008 | Boss Micro BR Digital Recorder
Boss (RDS-630U) CD Player Logo
32 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
