CANON iR 2520 UFRII LT
Ir 2520 UFRII LT 1-sided printing setup as default (2-sided is curently default)
  • 10 Answers
SOURCE: Canon MF4100 Series UFRII LT print problem
sounds like an error with the printers ink cartridge reader
Posted on Jun 18, 2009
SOURCE: canon IR C3220 cannot print multiple pages..ONLY able to print one page
I had same problem with my Canon pixma ip4600 and 4300, it works fine on one of my laptop that has XP but will only print one copy at a time on my laptop with Vista. After a long time playing around with it I found if i set the printer setting range to print pages 1 to 1 ( or 1 to "number of pages in doc"), then put in how many copys you want and click collate.
It worked for me so hope this helps :)
Posted on Oct 11, 2009
canontech
  • 1219 Answers
SOURCE: Solution for canon ir 2520 error code E000020
E020 0000
The path between the sub hopper and the developing
assembly is clogged with toner.
1.Check the rotation of hopper motor gear. (If rotating, false
detection by the sensor is doubted. Feed the toner to the
developing unit in service mode: CLEAR>ENGIN>TNRINST.)
2.Replace the Developing Assembly Toner Sensor (TS1).
3.Replace the Sub Hopper Toner Sensor (TS2).
4.Replace the DC Controller PCB (PCB4).
SERVICE MODE:
* 28 * or MENU and #
Posted on Jul 01, 2010
  • 140 Answers
SOURCE: canon iR 2520 toner install problem.
u can go in service mode by pressing additional function + 2+8 then go in clear by pressing scrolling, then go in engine. after press ok in tnrinst. machine will process for 2 minutes. for toner installation.
Posted on May 09, 2011
abdulkarimap
  • 149 Answers
SOURCE: default Id & Password ir 3300 canon
I suggest you read the manual book canon IR3300.
Manual book, you can download here
Canon imageRUNNER 2200_2800_3300 Reference Guide
For additional materials, the solution to the problem IR3300 ID & password, you can read here
I hope this information helps
Posted on Nov 18, 2011
After installation of canon IR 2520 its give me an E000716
E716 Erroneous communication with optional cassette or 2-way unit 0000 After the presence of a cassette pedestal or a 2-way unit has been detected, the communication fails to be normal for 5 sec. 1. Check the cable.
2. Replace the DC Controller PCB (PCB4).
3. Replace the Cassette Pedestal Driver PCB.
4. Replace the 2-way unit driver PCB. 0010 When the communication with the 2-way unit is faulty after detecting the connection with the finisher. 1. Install the 2-way unit.
2. Check the cable.
3. Replace the DC Controller PCB (PCB4).
May 20, 2015 | Canon Office Equipment & Supplies
Canon ir 2520 printing problem the machine does not print the image on paper is one side blank and one side very faint
It sounds like your cartridges are nearly empty. Also, you might want to remove each one and use a !-Tip with alcohol and gently soak the print nozzles to see if that will clean up the problem.
Sep 05, 2014 | Office Equipment & Supplies
Canon IR 2018 Drivers
You can either write to them for assistance or give them a call - they don't bite.
Aug 28, 2017 | Office Equipment & Supplies
Canon iR 2520 toner install problem.
May 09, 2011 | Canon iR 2016i Black and White Copier
What it a finisher for canon ir 2520
it is the "device" which is mounted on ir 2520 or any other copier, with purpose to stack, collate or staple the copies. :-)
Hope that helps!
Jan 10, 2011 | Office Equipment & Supplies
Today I start my printer canon ir 2520 and i see dept id and password prompt screen, I did not reset any id and password earlier, I cannot go inside the menu or i can't take any copy. Please give solution...
oday I start my printer canon ir 2520 and i see dept id and password prompt screen, I did not reset any id and password earlier, I cannot go inside the menu or i can't take any copy. Please give solution for disable or reset the same.
Oct 23, 2010 | Canon iR 2022 Printer
What do we need to purchase to make our IR 3025 network capable?
You need to buy UFRII printer kit for net. printing, and send kit for Scann to e-mail, scan to folder,...
In Europe we cant order any more kits for this product!
Jan 13, 2010 | Canon ImageRunner 3025 Black and White...
42 people viewed this question
jasbo
jasbo
