Question about Toastmaster Heating & Cooling
IS IT POSSIBLE TO REPAIR A QUARTZ HEATING ELEMENT
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 92 Answers
Yes. length, current/watts/resistance
then google "spare parts quartz heating element" in your local area
Posted on Oct 18, 2013
  • 422 Answers
Yes. but it may not be cost effective.
just buy the elements from ebay
Posted on Oct 16, 2013
Testimonial: "BUYING THEM IS NOT REPAIRING THEM"
2 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: Heating Element
try this url link
http://www.infraredheaters.com/quartz.htm
Posted on Dec 25, 2007
My Boekamp quartz heater model 101 needs a replacement of 1 of its heating elements.
Replacement quartz elements are available for many heaters of the type so if you can't source a replacement as a spare part for your heater, perhaps by an internet search, you might be able to find one of the correct dimensions and wattage on ebay or Amazon.
The general advice is to remove the old element first in order to measure it.
Mar 26, 2018 | Heating & Cooling
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Jan 19, 2016 | Patton PQH307UM Electric Utility Heater
Why did it suddenly stop working?
The Auto Head Quartz Control or the quartz heating element failed.
Nov 29, 2015 | Bosch Styline Collection Toaster...
Test heating quartz heating element
put an ohm meter across the end terminals of the element. If you get a low ohm reading the element is good. If you get no reading the element is bad.
Feb 15, 2015 | Heating & Cooling
Bulbs burnt out
i would check with the manual to see if it can be replaced it look like heating elements not bulbs
Mar 16, 2013 | Pool & Spa
The upper heating element of my Marvin Quartz Steam 'n Heat Model # 5060 electric heater does not heat. Where do I get a replacement?
You can buy these elements from Quartz Infrared, Inc. at their online store.
http://www.quartzinfrared.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=Marvin
Dec 07, 2009 | Kitchen Appliances - Others
Quartz heating elements problem in Krups toaster oven
you can touch the element but be carefull the glass is thin .... so scrape it and do what you can . THEN USE A COTTON BALL AND ALCOHOL and clean the element that will get rid of the oil you left behind ,you will be fine ......Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 02, 2009 | Krups FBC2 1600 Watts Toaster Oven with...
Error 50.6 in hp laserjet 9500hdn
  • HP II/III series most likely cause is the ac power module is defective. Order the HP II/III Service 50 Error Repair Kit. If the quartz fuser lamp is burned out, order the replacement fuser on specials page. Slight possibility of loose connector on DC controller. See tweaking page DC controller could also be defective, but this is very rare.
  • HP IIP/IIP+/IIIP most likely cause is burned out quartz lamp. Order the HP IIP/IIIP 50 Service Error Repair Kit. Could also be a failure of the power supply.
  • HP 4/4+/5 most likely cause is burned out quartz lamp. Order the HP 4 Service 50 Error Repair Kit. Could also be a failure of the power supply.
  • HP 4L/4P/5L/5P/6L/6P most likely cause is a bad ceramic heating element.
  • All other printers most likely cause is burned out quartz lamp. In rare instances the ac power supply has failed. Even rarer, the DC controller is defective
Jan 22, 2009 | Office Equipment & Supplies
Marvin Quartz heater element
Very simple to install the replacement element. Insert one end of the element into the bottom receptacle on either side, press the element down (it's spring-loaded), then slide the top of the element into the center opening of the top receptacle, push to appropriate side (the side of receptacle, same as the bottom), then release. Then do the same with the other element (if both are out).
Mar 03, 2008 | Marvin 2060 Compact Heater
Heating Element
try this url link
Dec 24, 2007 | Lakewood LAKQTV22 Utility Heater
Heating & Cooling Logo
114 people viewed this question
Top Toastmaster Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a Toastmaster Heating and Cooling Expert? Answer questions, earn points and help others
