Touch screen not working canon irc2880 - Office Equipment & Supplies
WHAT IS IT CODE E000240-0001 THE IR8500
http://www.copytechnet.com/forums/canon/45111-irc2880-e-000240-0000-a.html
Mar 14, 2016 | Office Equipment & Supplies
How do i solve error e000990-000000 on irc2880?
Hi
The webpage here
Error Codes Canon iRC2880 Code E990 0000
suggests that it is the waste toner shutter sensor which may need replacing, or the drum unit reinstalled properly.
This is just one page of a very useful printer website where by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Jan 30, 2015 | Office Equipment & Supplies
Canon touch screen stop working
If the copier still works but the touch display won't respond, you will need to have the touch screen panel overlay replaced. That is a very common problem that happens to those touch displays.
Sep 02, 2014 | Canon imageRUNNER 3035 Black and White...
Canon firmware update
replace the ITB assy will solve this message.
Aug 04, 2014 | Canon Gpr23 Irc2880/2880i Black Copier...
E000990 0000
has to do with the waste toner gate, PS12, gear set attached to locking handle on process assembly. PS12 is remaining blocked. Check the gear mesh, with handle down, the sensor should be open.
or is dirty with toner, clean
Aug 01, 2014 | Canon Gpr23 Irc2880/2880i Black Copier...
Canon irc2880 I can not get to ip section
you need a manual for your product. try google or canon tech support web site.
Jun 04, 2014 | Office Equipment & Supplies
Waste toner box full message after changing the waste toner box
When you removed the waste toner bottle, there is a sensor inside the copier. When you remove the waste toner, look to the opening where the top of the waste bottle was, clean that area and return the bottle and turn the copier OFF then ON. Good Luck
May 04, 2013 | Canon Gpr23 Irc2880/2880i Black Copier...
CANON MODEL IRC2880 error code e000990-000
I have an error code E000990-0000 pliiz help me fix this
Jan 05, 2011 | Canon imageRUNNER iR C2880 Color Copier
How can I correct error Code E602-0001 on my Canon copier?
You can try to reflash the hard drive or replace the hard drive
Sep 27, 2010 | Canon imageRUNNER C3200 Copier
jasbo
jasbo
