Question about IBM xSeries 346 Server
Serveraid 7k 0e00h
When copying configuration from hard disk to RAID 7K after copying shows code 0E00h
4 Suggested Answers
  • 121 Answers
SOURCE: "how to change write through to write back in 7k" Problem Now!
You need to use download, boot from and use the ServeRAID Support CD and the RAID controller tools on that disc. You cannot modify RAID controller features on the 7k while it is operational and/or in use.
See ServeRAID support page at http://www-947.ibm.com/systems/support/supportsite.wss/docdisplay?brandind=5000008&lndocid=MIGR-62462
Posted on Feb 20, 2010
  • 4234 Answers
SOURCE: Troubleshoot ServeRaid problem on IBM x335 Box
The likelyhood that 2 drives fail at the same time is remote. I would first look to teh controller as the problem. Also, check the power supply. The only common things are the 5V and12V supply.
Dan
Posted on May 12, 2010
  • 20 Answers
SOURCE: raid 7k controller not responding properlly error 2807
This could be an issue with the Raid backplane. If under warranty I would replace the backplane.
Even if no warranty you might be able to find one cheaply used.
regards,
Mike
Posted on Oct 26, 2012
Hi, within the previous 12hrs my e-series server bombed out - there are two issues (1) Memory DIMM malfunction (2) serveRAID-7k error 2807... I removed the faulty memory DIMMs, but the RAID error still...
You can recover RAID data from hard drive with RAID recovery software easily.
Tenorshare Data Recovery Enterprise is a comprehensive data recovery software that supports RAID recovery for RAID 0 and RAID 5. Lost data in RAID 0 and RAID 5 can be deeply scanned and restored immediately. Meanwhile, files and folders in RAID 0 and RAID 5 can be copied to other partitions directly. http://www.any-data-recovery.com/product/datarecoveryenterprise.htm
Aug 29, 2011 | IBM ServeRAID-7k Controller (71p8642) SCSI...
ServeRAID-7k Controller SCSI Controller error code 2807
Hi dude,
i already answer the same problem as yours, on my case it's because swollen battery push the RAID memory and make it bent, so the contact point become loose, if you want more detail see on:
http://hubpages.com/hub/IBM-error-code-2807
Apr 05, 2011 | IBM ServeRAID-7k Controller (71p8642) SCSI...
I have a problem with onboard ServerRAID-7K controller. Status is not responding properly - Error code is 2807 pls sugesst.
I found the same problem with you and found the solution. Open your server casing and try to locate a battery attached to RAID memory. On my case the battery swollen and make the card bent. For the more detail i wrote on http://hubpages.com/hub/IBM-error-code-2807
Jan 27, 2011 | IBM ServeRAID-7k Controller (71p8642) SCSI...
I have IBM eServer with ServeRaid-7K on board controller and have 3 SCSI 73GB hard drives configured in RAID-5 array. Hard Drives are running critically low on space and I bought 3 300GB scsi Ultra320 hard...
First, buy an external storage device, at least 80GB (although it's currently difficult to find any _smaller_ size!) and make a file-by-file, folder-by-folder, backup of your 73GB of "data".
Second, buy another external storage device, and do a Google-search for "drive image freeware".
Pick one of those applications, and do a "image" backup to this second external storage device.
Third, disconnect the 3 "old" drives, carefully label them, and set them aside.
Fourth, connect the 3 "new" drives, delete the old RAID-5 array definition,
and create a new RAID-5 array definition.
Fifth, do an "image restore" from the second external storage device to the new array.
If you have any problems, all you need to do to "back-out" is to:
* disconnect the "new" drives
* reconnect the "old" drives
* delete the "new" array definition
* redefine the "old" array definition
and you're back to the "old" configuration.
Dec 07, 2010 | IBM ServeRAID-7k Controller (71p8642) SCSI...
IBM Serveraid 7K onboard not responding properly error code 2807
Have you updated the raid controller firmware? 7.12.13 is the latest, search ibm.com for migr-62540
Aug 06, 2010 | IBM ServeRAID-7k Controller (71p8642) SCSI...
Feb 11, 2010 | IBM xSeries 346 Server
IBM xSeries 346 Server Logo
533 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
