Question about Siemens Washing Machines
F21 shows in my siemens washing machine. i dont know what to do. i cant use it anymore.. what to do???
  • 84 Answers
SOURCE: unlock washing machine siemens wd 5125
hold the buttun down for three seconds
Posted on Mar 30, 2010
jsrock516
  • 5911 Answers
SOURCE: My whirlpool washing machine is showing an error
"F21" is a Long Drain error code. This is usually an indication that you may have an obstruction somewhere in the drainage system. Most commonly, this is an indication something is lodged in the drain pump or the inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608588-f21_error_code
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing such as socks or under garments can become lodged in this area as well causing the drain cycle to fail.
NOTE: A "SUD" error code can also often occur in conjunction with the "F21" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error (if displayed) should go away.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
These are very simple repairs that you can perform yourself without the assistance of a repairman.
If the washer door remains locked and you still cannot open it, there is a manual release you can use to retrieve items left in the wash tub. The following link explains:
http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_
If the wash tub is full of water, you may want to use a wet/dry shop vac to pull a vacuum on the drain line and drain the wash tub. This will minimize any potential mess you may have to clean up. NOTE: The error codes are not listed in the owner's manual. For an explanation of all the error codes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and if you have questions, please post back and let me know. I hope you find this information helpful.
Posted on Jul 07, 2010
SOURCE: my siemens washing machine S14.39 keeps stopping a...
Hi
It is your pump that is failing / bolked with hair and treds behind the impeller. The pump is not the best design as ther can enter smal treds and hair behind the impeller into the paking ring (seal). There is only one sollution that help - change the pump. Can be don from the fron of the mashine. Only one screw on the right side has to be removed to remove the plastig cover and the one screw to losen the pump.
Posted on Aug 22, 2010
supernova278
  • 1932 Answers
SOURCE: Users manual for a Siemens combined washing
You can get your user guide from below website
https://www.2instructions.com/search.php?cmarque=SIEMENS&modele=SIWAMAT%20PLUS%205431
Thank you
Posted on Oct 14, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Bosch Classixx
F21 is a motor or control board fault.
This also can be caused by voltage spikes or surges...
To reset it.
Turn the appliance knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position.
Press and hold the spin button.
While holding it, turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds.
Release the button.
Turn the knob to off.
When your turn it back on it should have cleared the error code
If the problem continues then check the motor...
heatman101
Posted on Nov 29, 2010
What is an F21 error means in Siemens extraklasse WM14E391 washing machine?
its a motor tachometer fault, basically the tacho on the motor (you cant get it as a spare part it comes with the motor) is faulty or the control board is faulty and the machine is unable to detect the speed of the motor, the motor may work but if the board cant detect it moving you will get this fault, fun thing about this kind of fault is theres no easy way to determine whether its the board or the tacho
Feb 07, 2017 | Siemens Washing Machines
I want to know how can i cleare the erro f21 about siemens washing mechine.
Error f21 happens when the machine does not drain in an appropriate time. This can be caused by a blockage in the drain or a faulty pump. There is a previous post in relation to resetting this error. have siemens washing machine that says f21 what does that mean
Jan 14, 2017 | Siemens Washing Machines
Siemens washing machine display F21 flashing. Fault is not resetting after power off.vario perfect iq 300.
Try this, unplug it and press and hold down the power button for 10 seconds and then plug it back in and see if the error code has cleared.
Aug 28, 2016 | Siemens Washing Machines
How can I reset alarm F21 on Bosch washing machine type WIM40?
Dear Sir,
it is requested you that we have a washing machine Type: WIM40 & RN # WAE20463tr/12 it has still showing error on display as "F21 alaram" Kindly resolve it or tell us solution that what will be.
Best Regards,
Imran Khan Nawab
May 13, 2012 | Bosch Washing Machines
I have a siemens washing machine that says f21 what does that mean
Many thanks. For F21 fault everyone was talking about the drain valve but found one answer related to power supply n board this helped. Resetting by turning program switch to 12 o clock then turn to 6 o click then keep spin button pressed n move knob to 7 o clock position. Then release spin n move knob to 12 o clock. This way F21 got resetted.
Aug 31, 2011 | Washing Machines
Comes up on readout the pump blocked cant find type siemens washing machine(S 16-74)
This video will show you how to check the pump and we have other videos on how to change the washing machine pump if it needs replacing
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 24, 2011 | Siemens Washing Machines
Cant get child lock off
Hello,look for a button with possibly a lock emblem beside it ..usually has to be held down 3-5 sec to unlock.
Thanks
May 23, 2010 | Siemens WM14S794GB Front Load Washer
Kenmore elite front load washer
I HAVE A KENMORE ELITE WASHER AND IT STOPS IN THEN MIDDLE OF THE CYCLE AND DOESN'T RISNSE. THE DISPLAYS SHOWS F21. CAN YOU LET ME KNOW WHAT THIS MEANS?
Sep 22, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
53 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
