Question about Philips HDD1630 MP3 Player
My mp3 does not start the song even when i press play
When the mp3 suppose to start a song it stays at 0.00 out of a 3.24 second song
  • 8,596 Answers
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Posted on Feb 11, 2008
SOURCE:
Music wont play?
try connecting it to itunes 9 and restoring factory settings
Nov 21, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
The ma933a nextar model skips over songs every 10 secs!
you have the play mode set to "intro",
how to solve this;
1) start playing a song.
2)Press the "Mode" button quickly, don't hold it down, just press it quick.
3)Select Play Mode by pressing the Mode button
4)Select "N" normal
all done.
Nov 14, 2009 | Nextar MA933A MP3 Player
Mp3 on intro mode only plays 2 seconds of song
ya..thts what its supposed to do...intro mode means just a preview of the second...change the mode to normal and it will play the whole song..
Aug 19, 2009 | Audio Players & Recorders
Mp3 plays few seconds of song.
Do you mean it plays a few seconds then skips onto the next song? If that is the case then most likely you have "Intro" play set which only plays a few seconds as a introduction then skips to the next time.
To fix this, during music playback, press the [menu] button, then there should be an option there to change it from "Intro" to "NORMAL" instead.
Hope that helps.
May 18, 2009 | Konaki MP4-NS MP3 Player
How to start the mp3 player to play
The player has to be reset. To reset slide the on switch to on and hold for 10 seconds. The player will reset, then just turn it on.
beaterman
Mar 12, 2009 | SanDisk Sansa e260 MP3 Player
MP3 not playing the songs and gets restarted
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Oct 15, 2008 | SanDisk Sansa e270 MP3 Player
My computer doesnt recognize my MP3
How to get rid of the "synchronize to continue music subscription" message if it just appears out of nowhere on your player- this fixed mine when it gave me that message:
delete the STORE.HDS file in the system/wmdrmpd directory of your sansa (optional)
import your protected songs into WMP, and resync your protected music (with WMP) in MTP mode
play a protected song and let it rebuild the store.hds file (you will experience severe lag for about 15 seconds as it rebuilds) and the music should play.
I got this from anythingbutipod.com
Source:
http://www.anythingbutipod.com/forum/showthread.php?t=11233
Aug 20, 2008 | SanDisk Sansa e250 MP3 Player
Songs
The WMA songs that you have are DRM-encrypted, and they do not have "transfer rights" - as in, you cannot play them on your Mp3 player (either that, or they are only sample songs)
Solution 1: Upgrade your music service subscription
Solution 2: Convert the Songs to Mp3 format
Read up on DRM encryption - you can find more info in my 2-part "Tips & Tricks" under my profile - on song formats
Jun 20, 2008 | SanDisk Sansa c240 MP3 Player
Only plays ten seconds of songs
I HAD A VISUAL LAND MP3 PLAYER. ONLY PLAYED FIRST 10 SECONDS OF SONG. IT IS SET TO INTRO. WHILE THE SONG IS PLAYING PUSH THE BUTTONS AND YOU WILL SEE THE OPTIONS COME UP. SONG HAS TO BE PLAYING. CHANGE FROM INTRO.
May 31, 2008 | Centon Electronics MP4-001 MP3 Player
My Mp3 wont play certain songs
Sounds like you have two problems here. First my guess is your files bought from walmart are corrupted some how. just delete the ones that are giving you fits and call it a day. Second you mentioned it wont even sync music,,,, Are you saying none of your music or just the walmart ones ?
Nov 17, 2007 | SanDisk Sansa e260 MP3 Player
Philips HDD1630 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
