Question about Microchip MRF24J40MA-I/RM RF MODULE, TXRX, ZIGBEE, 2.4GHZ, 250KBPS, PCB ANT
I have MRF24j40MA zigbee module how can i assign source address and source PAN address for different slaves?
Toshiba bios settings
You may get away with a USB to Com converter from flea bay.
Jan 31, 2014 | Computers & Internet
Http//192. 168.0. 101 :8080
NetName: PRIVATE-ADDRESS-CBLK-RFC1918-IANA-RESERVED
NetHandle: NET-192-168-0-0-1
Parent: NET192 (NET-192-0-0-0-0)
NetType: IANA Special Use
OriginAS:
Organization: Internet Assigned Numbers Authority (IANA)
RegDate: 1994-03-15
Updated: 2013-08-30
Comment: These addresses are in use by many millions of independently operated networks, which might be as small as a single computer connected to a home gateway, and are automatically configured in hundreds of millions of devices. They are only intended for use within a private context and traffic that needs to cross the Internet will need to use a different, unique address.
Comment:
Comment: These addresses can be used by anyone without any need to coordinate with IANA or an Internet registry. The traffic from these addresses does not come from ICANN or IANA. We are not the source of activity you may see on logs or in e-mail records. Please refer to http://www.iana.org/abuse/answers
Comment:
Comment: These addresses were assigned by the IETF, the organization that develops Internet protocols, in the Best Current Practice document, RFC 1918 which can be found at:
Comment: http://datatracker.ietf.org/doc/rfc1918
Ref: https://whois.arin.net/rest/net/NET-192-168-0-0-1
OrgName: Internet Assigned Numbers Authority
OrgId: IANA
Address: 12025 Waterfront Drive
Address: Suite 300
City: Los Angeles
StateProv: CA
PostalCode: 90292
Country: US
RegDate:
Updated: 2012-08-31
Ref: https://whois.arin.net/rest/org/IANA
OrgAbuseHandle: IANA-IP-ARIN
OrgAbuseName: ICANN
OrgAbusePhone: +1-310-301-5820
OrgAbuseEmail: abuse@iana.org
OrgAbuseRef: https://whois.arin.net/rest/poc/IANA-IP-ARIN
OrgTechHandle: IANA-IP-ARIN
OrgTechName: ICANN
OrgTechPhone: +1-310-301-5820
OrgTechEmail: abuse@iana.org
OrgTechRef: https://whois.arin.net/rest/poc/IANA-IP-ARIN
Dec 06, 2013 | Computers & Internet
Printer offline and not printing
Since this is a network printer there are a few potential sources for problems.
  1. IP address conflict. When items on a network are powered on and off sometimes the auto-assigned IP addresses aren't refreshed. The router may think the printer isn't there and re-uses the IP address for a new device on the network, but the printer is still trying to connect with the original IP address.
    1. Log onto your router. See if the printer shows up in the DHCP Client Table of your Local Network - it may have names or just MAC addresses depending on the router. You can print out a test sheet from your printer and see what *it* has as it's IP address and see if that's assigned to something else.
    2. If you do find a conflict, the easiest solution, IMO, is to assign a static IP address to the printer.
  2. Bad cable or hub. Both can go bad and a problem with either will cause the printer to appear to be offline.
    1. Check for lights at both ends of the ethernet cable.
    2. Try a different port in the hub or router
    3. Try a different cable
  3. An recent update corrupted your printer settings.
    1. Uninstall the printer, then reinstall it
Nov 13, 2013 | Brother MFC-7460DN Multifunction Laser...
Difference between VLANs and subnetting?
VLAN- Essentially, you are separating a network into different broadcast domains with a switch by moving some ports on a switch into a separate VLAN other than the default, 1. Switch ports in VLAN X will communicate with any other ports on the network also in VLAN X, but not any other VLAN, unless you so configure it that way.
Subnetting- Subnetting is the breaking up of a chunk of IP addresses into different networks. These subnetworks are generally assigned to each LAN on that network, which all connect to a router, which may connect to the cloud through the ISP, or to another router on the network, or separate network. The addresses on that subnet are assigned to clients on the LAN the subnet is assigned to.
Nov 12, 2013 | Computers & Internet
CANT CONNECT TO PLAYSTATION NETWORK. SIGNS ME OUT WITH ERROR 8002AD3D. PLEASE HELP
try setting up the ps3 using static ip address.
the subnet mask is usually 255.255.255.0 and check your DNS server in your router to input it in your ps3 cause it can vary.
Next, you can open the ports through your router 80TCP, 443TCP, 5223TCP, 3478UDP, 3479UDP, and 3658UDP all assigned to your ps3 static id address.
You can open the ports or use DMZ function(enable), which is alot easier because all you need to input is the static ip address that was assigned to your ps3.
However, i set them both up and i'm too lazy to go back to check whether it needs both or one of them, but i'm sure one of them will suffice.
Note: If you have DHCP enable, you have to check where the ip address starts and ends. You want to assign your ps3 static ip address within that range. Remember, assign a static ip address that is different from your default router ip address cause it can lead to alot of viruses.
Aug 26, 2010 | Sony Playstation 3 (PS3) Console
Window system error: there is an IP address conflict with another system on network?
The router to which you are connected is badly configured so th same IP has been issued to another pc. Either configure the router to assign the addresses in its network dynamically or manually assign yourself different addresses to every pc.
Jul 24, 2010 | Dell Inspiron™ 600M PC Notebook
When trying to wireless connect my laptop through my desktop pc connection fails. Have tried reconfiguration of both the 'DLINK' modem and the Laptop without success.
Try resetting your desktop back top a static configuration. ie: Do not assign a ip.
You system will assign a ip of 192.168.0.1 most likely.
Now, disconnect your modem from its power source and remove its battery for 30 seconds.
Next, disconnect your power source to the router or hub.
Now, go ahead and hook up your power connections to the router and install your battery and power connection to your modem.
Allow your modem to fully setup before attempting to go further.
Now, reboot your desktop and try your normal internet connection..
If it works ok, leave it and go to your laptop.
Leaving the desktop unit on, startup your laptop.
Your laptop should see the static address from the desktop and assign itself a different number, one that does not conflict with the ip address of the desktop.
Hope this works out well for you.
John
Nov 27, 2009 | Computers & Internet
The segement of the print server you select is different from your computer" on Vista,
Meaning that the IP Address of the print server is different from the computer's IP Address.
If you're computer has a static IP Address, you need to assign a static IP Address for your Print Server. To assign a static IP for the print server, you need to open the PSAdmin utility on your computer, locate the TCP/IP and click the plus (+) sign. Double-click the IP Address and you may change it from there.
Make sure that the IP Address of your computer, router and print server are in the same IP range. And make sure that you could ping the IP of the print server.
Then configure the printer port settings and you should be able to print.
Have a great day!
Jul 03, 2009 | IOGear GPSU21 Print Server
Dont know ip for my Sharp AR_C270 i just bought
Find out what the gateway setting are on your computer and assign an ip address based on the gateway.
For example if your gateway is 192.168.0.1  then a good ip address would be 192.168.0.XXX.  xxx=available ip address to use.
Your copier does have a DHCP setting that allows the router to assign on automatically for you if the copier is connected to one but you should assign that ip address manually after using DHCP because if the power goes out, it could assign a different one than the previous assignment making the IP port assignments to print with on your computer useless without creating a new port.
Oct 19, 2008 | Sharp AR-C270 Color Copier
I cant open an ip address for an assigned webpage.
There are several private address ranges that may be affecting the operations you are attempting to perform see table
IP Address Ranges Reserved for Private Use
Class Networks A 10.0.0.0 through 10.255.255.255 B 172.16.0.0 through 172.31.0.0 C 192.168.0.0 through 192.168.255.0
All addresses in this range in your network are only directly addressable to machines within your network at most by default. The router to your ISP and the internet as a whole maps these addresses onto the IP address assigned statically or dynamically by your ISP to the WAN side of your router using an address translation (NAT) service. So where you are attempting to connect to this device from may be significant. You may need to review your setup guide to see if it references router configuration requirements to support access to the Web_xpander port from devices not attached to your internal network. If you have multiple internal networks (address ranges and not devices) this could also be an issue.
Secondly -- does the Setup software for the device tell you the IP address assuming it is dynamically assigned. Otherwise how would you know what the address is. Static assignment could resolve that issue however you must understand your network to assign your own address. Given a theoretical network where the router gateway is 192.169.0.1 and the network mask is 255.255.255.0 the valid network addresses are 192.168.1.0 - 192.168.1.255. A router or other device supporting DHCP address assignment reserves another range such as 192.168.0.100 for 50 leases (ending at 192.168.0.149) for dynamic assignment to requesting network adapters. Ignoring the 0 and 255 address this leaves open to the network administrator (you in your home) the possibility of assigning static IP address in the ranges of say 192.168.0.2 - 192.168.0.99 and 192.168.0.150 - 192.168.0.254 or so. You as well as the DHCP server are required to assure that there are no duplicate IP addresses assigned on your network. So statically assigning 192.168.0.100 (which is DHCP assignable in our case) could and would most likely result in duplicate addressing and network problems.
Dec 08, 2007 | Computers & Internet
Microchip MRF24J40MA-I/RM RF MODULE, TXRX, ZIGBEE, 2.4GHZ, 250KBPS, PCB ANT Logo
97 people viewed this question
Top Microchip Computers & Internet Experts
David Payne
David Payne
Are you a Microchip Computer and Internet Expert? Answer questions, earn points and help others
