Question about Heavy Machinery
How to remove impeller assembly on a yard machine chipper shredder model 24A-465E
  • 3 Answers
SOURCE: need set of 4 impeller vanes for Troybilt chipper model 47261
You can get the impeller parts at:
http://www.thefind.com/garden/browse-troy-bilt-chipper-vac-parts
Good luck,.,
I just purchased a used 47261 yesterday for $200 .. It is like new, but I may need a new bag from this site and I will need to find a manual somewhere.
MrBill
Posted on Jun 25, 2009
mowerman1857
  • 389 Answers
SOURCE: How to remove impeller assembly from chipper
You can download a PDF2.gif manual for your chipper at ( www3.sears.com ) Type your model number like this ( 247.795890 ) It will show you a parts list for it and also there will be a place that says "Manuals" click on that and it will download to your computer2.gif where you can either save it or print it out or both
Posted on Sep 16, 2009
mowerman1857
  • 389 Answers
SOURCE: Troy-bilt Model 47279
I really hate to be the "bearer of bad tidings" but Troy Bilt, as a company, in no longer in business, MTD bought out the name and design rights for a lot of their tools but they are not manufacturing or stocking any parts for the older GardenWay/ Troy-Bilt machinees. My best suggestion would be tostart looking for a good used one or one with a blown engine, broken frame or whatever, buy it and canibalize it for spare parts
vincob
  • 718 Answers
SOURCE: I have a yard machinne 6.5hp chipper/shredder -
The blade(s) should have usually two bolts on them depending how many blades you have. Mine only has one blade held on with two bolts and that is only on the side that cuts the larger branches up to two inches in diameter and should be sharpened on a grinding wheel because it has a specific angle to it. The other side that chips smaller branches and twigs it a type of flailer, meaning pieces of metal just swinging around to mash up the sticks and do not need sharpening.
Posted on Oct 09, 2009
bbreton
  • 437 Answers
SOURCE: replace flails on 5.5 Yard Machine
Go to www.ordertree.com. The flailblade is p/n 719-0329, The shredder blade is p/n 942-0571, The chipper blade is p/n 981-0490.
Replace them you have to take casing off the unit to get to them.
Posted on Jan 23, 2010
Testimonial: "I have the casing off,and have penitrating oil on the pins and screws ----- tomorrow is an other day!"
Need owners manual for 2001 yard machine chipper schredder model #24A464B131
I have a operator's manual for 24a 463b129 5.5 hp. I also have an operator's manual for the engine (Tecumseh). I purchased the chipper new from Home Depot back in 2002. I think you will be disappointed at the lack of information. If still interested, e-mail me your e-mail address, and I can send you a PDF copy of these manuals. (wchan@bushbros.com)
Mar 27, 2010 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Replace flails on 5.5 Yard Machine
Jan 22, 2010 | Yard Machines 24a 452g729 5.5 Hp Chipper...
24a-020d700 won't start, new gas & replaced air filter
Hi
First you need to check for spark at the plug if you have spark remove plug put a tea spoon full of gas in the plug hole reinstall the plug and try to start. If it starts for a sec the carb or fuel line is clogged and needs to be cleaned.
Sam
Jan 02, 2010 | Yard Machines 24a 021h700 4.5 Horsepower...
5hp chipper will start and run only with the choke on and has no power, please, help.
sounds like the carb is gummed up. You probably need to do a complete carb cleaning.
Aug 07, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Yardman Chipper/Shredder won't run
I had this same problem after letting the machine sit for a couple of years with gas in it. What finally solved it for me was taking the screw out of the bottom of the carburetor bowl and cleaning it. I mean clean it. Carburetor cleaner or some other solvent helps but you've got to get the gunk out of that screw. It probably has an obvious "feed" that runs across the bottom part of the screw shaft. The "feed" that runs from this up to the carb is the tricky part. I needed something very fine and finally settled on a combination of strands of wire from a lamp cord. Try two or three strands twisted together and work it up and down with some carburetor cleaner.
May 06, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Briggs & stratton chipper wont start
I believe it is part of the systen shut off. Should be connected to the motor (ground).
Hope this helps you
Kurt
Mar 18, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Craftsman Chipper-Shredder Model No. 247.775870
If a small engine wont start its usually one of two problems, its not getting gas, or its not getting spark. easy way to find out if its getting a spark is to remove the plug, put it back back in the connector and just let it hang down while you try to start it. you should see a bright blue spark, if you dont try changing the spark plug. if its getting a spark come back on this site and i'll help you trouble shoot it.
Nov 02, 2008 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Heavy Machinery Logo
50 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
