Question about Microwave Ovens
Price of a 600t bpl microwave turntable - Microwave Ovens
Microwave wont work
Call the manufacturer about resetting the electronics. If not possible the board needs to be replaced if the price is right.
check here Search Over 2 1 Million Appliance Parts
Sep 08, 2017 | Sharp Microwave Ovens
Turntable
Your turntable motor is most likely faulty at this point. Contact your manufacturer for a price quote on the part, then you're looking at around 1 hour labor.
Jul 23, 2012 | Frigidaire PLMV168 Microwave Oven
The turntable will not work. Help!!!! It is model number mmv4205bas
Fisrt check that there are no crumbs or other obstructions on the floor of the oven that would prevent the turntable assembly from rotating properly. Also try removing the plate and lifting up / checking the drive assembly inside the oven cavity to make sure that the turntable drive mechanism has not become disengaged from the motor shaft underneath.
If your problem is not something inside the oven cavity itself, then it may be the result of a simple loose wire to the turntable motor, or it may be a completely burned out motor altogether. Unfortunately the only way to determine the exact source of the problem for sure is to disassemble the unit and troubleshoot the components and connections inside.
A microwave contains a number of very hazardous components such as the main capacitor which can deliver lethal shocks even after the unit has been unplugged. Extreme care should be taken in the disassembly and maintenance of any microwave oven and should be left to a trained technician whenever possible.
Here is a link to the parts diagrams and price lists for your model:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174676
The turntable drive motor is listed as part number 27 on the diagrams. Here is a link to the part details including price for that item if required:
http://www.appliancepartspros.com/part_details.aspx?part_id=4215435
Hope that was helpful. Good luck and take care.
May 22, 2011 | Maytag MMV4205 Microwave Oven
Turntable won't turn will it hurt the microwave how do I fix it can you help me
If the oven is still heating, but the carousel isn't turning, this problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft, turntable ring or coupler) under the middle of the glass tray. The following link explains how to access and replace the motor:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The price range will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can refer to any of the following websites for comparison:
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
The first three sites listed have helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you may need.
The average price for a motor is about $35 to $45. The coupler is less than $10. If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope this helps you.
NOTE: Even though the carousel may not be turning, you can still use the microwave while awaiting parts. You will need to physically rotate whatever you are heating about midway through the cook time to ensure even heating. Early model microwave ovens were not equipped with a rotating carousel and this was the common routine.
Aug 03, 2010 | Sharp Microwave Ovens
Turntable on Amana microwave does not turn anymore.
repairclinic.com
Jul 24, 2010 | Amana AMV1162 Microwave Oven
MODEL W 201 TURNTABLE DOES NOT ROTATE
repairclinic.com
If the model number is correct, the part number for a replacement motor is 8183954. If the coupler is stripped and needs replaced, the part number is 8206228. The average price for a motor is about $45. The coupler is less than $10. If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope this helps you.
Jul 19, 2010 | Whirlpool MH7140XF Microwave Oven
Turn table doesn't rotate
repairclinic.com
If the model number is correct, the part number for a replacement motor is WB26X10038. If the coupler is stripped and needs replaced, the part number is WB06X10138. The average price for a motor is about $35. The coupler is less than $20. If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope this helps you.
Jul 13, 2010 | Hotpoint RVM1625 Microwave Oven
My microwave does not heat anymore. The turntable works and the light works. How expensive is it to repair?
the heating source is the magnetron and it is not cheap .go to searspartsdirect.com and price the new one. you only need to enter your model #
Mar 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Need replacement glass turntable
looking about $65 from jacobyparts.com and and sears parts
Dec 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
51 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
