Question about Bear Archery Bear Bow Carnage Right Hand Realtree Apg Hd 70lb
Hi i upgraded the limbs on my bear carnage from 50 to 70lb, but now with 70lb limbs and backed of to 60lb the bow seems to jam about 3" into the draw, even with the twists removed from the string and cable i can draw 70lb but this seems to be way harder
I need to find out what model my bow is. serial # 2307711
look inside the limb pockets or under the grip. most of my hoyt recurves were stamped under the riser grip. You'll find a set of #'s @ the base of the limbs but that's batch ID , draw weight , leanth. for just the bow limbs not the riser, ( talking recurve here) with a compound you'll prob. only find one set of #'s.
you will need a bow press to break down a compound.
good luck & good shooting
Dec 16, 2015 | Archery
Squeaking noise when drawing back Barnett vortex bow
The four rubber grommets where the string is attached to the limbs need some DRY lubricant. When drawing, the grommets 'slip', and that slip 'plucks' at the string creating the creaks. Keep applying dry graphite to these points and the bow will quiet up nicely.
Aug 21, 2013 | BARNETT OUTDOORS LLC 10 Barnett Vortex...
Horton legacy 175 limbs
Ebay if you are lucky, Horton is out of business.
Jul 22, 2013 | Horton XBOW LEGACY 175 PKG 175
When released the bow makes a clacking noise like the string is slapping the limbs.
remove string and check limb pocket inserts and limbs for delamination or coming apart. You can buy string dampners if it is just string slap.
Jan 18, 2013 | Vista Archery
How do I adjust the draw weight on a barnett vortex lite junior bow
There are two bolts that hold the limbs onto the riser. Tighten them all the way tight or clockwise. This will ensure they are the same. Now you have to turn both bolts equal turns up to no more than 3 turns out. The looser the less weight. Never loosen more than 3 turns.
Dec 26, 2012 | Barnett Outdoors Barnett Vortex Lite Youth...
Assembly for pse stalker bow
you need a bow stringer for a recurve bow. $15.00 cabelas
Oct 26, 2012 | Puget Sound Energy PSE Stalker Recurve Bow
Why does the bow length need to match my draw length?
The bow length needs to match your draw length because the bow limb is designed to be used at a particular draw length range. For instance if you use a bow with limbs too long for your draw length, you won't be able to flex the limbs enough to make them efficient.
Aug 26, 2012 | Betsey Johnson Archery
How does a bow work?
A bow is a flexible arc which shoots aerodynamic projectiles called arrows. Essentially, the bow is a form of spring powered by a string. As this string is drawn, energy is stored in the flexible limbs of the bow; the energy is transferred to the arrow when the string is released, projecting it much farther than a weapon could be thrown.
Jul 30, 2012 | Archery
What is 'stacking'?
This isthe amount of increase in weight as the bow is drawn. It occurs in all bows,but can be intensified in three ways. First, the bow may be too short for thedraw length. A longer bow could help this problem. Second, the ratio offiberglass weight or thickness should also be increased. Third, the moreradical the limb design the more the stack will increase. This means that at agiven limb length the bow weight, a more pronounced recurve design, will stackmore at full draw. The use of multiple tapers in a limb can also causestacking.
Jul 09, 2012 | Archery
Bear Archery Bear Bow Carnage Right Hand Realtree Apg Hd 70lb Logo
Top Bear Archery Archery Experts
Tom Chichester
Are you a Bear Archery Archery Expert? Answer questions, earn points and help others
