Question about Quantegy 456 Tape Reel(1/2 in. x 10 1/2 in. x 2500 ft.)
Tascam 22-2 no sound
I was given a Tascam 22-2 and some reels to evaluate. I threaded the reel, it appears to feed and uptake correctly. But there is no sound, does this machine require external speakers? I have tried changing settings in different combinations.
  • 4 Answers
Yes you need to hook it up to an amplifier and speakers through RCA cable on the back. And or you can use headphones if there is a headphone jack?
Also make sure there is something recorded on the reel tape in the first place. You can do a test recording of something like a CD from your CD player or record something, then play it back, make sure you turn the record input volume knob up and make the RCA connections on the back of the reel unit and connect to your playback source you want to record. When you playback the reel tape, the db meters should be moving on the front of the reel deck, if they move then you most likely have some sound recorded on the reel tape.
If you still can't hear any sound and the db meters are moving, then check all your connections again and volume output knob on the reel deck. Hope this helps?
Posted on Jun 21, 2008
I picked up a reel to reel deck to play tapes that are about 30 years old. It plays fine, but I noticed the take up reel is about 75% full, but the play reel has about 40%, so it won't fit. Thoughts?
Logically, if the full tape reel and the empty reel are identical the second must fill at the same rate the other empties and all the tape from the first will fit on the second.
What does happen, however, is at the start the second reel seems to fill much quicker than the first reel is emptying, which is understandable when for any given tape length the second reel will revolve between at least twice as fast as the first reel and probably even faster.
A tape reel that appears to be half full will have much less than half the available tape capacity filled.
Sep 02, 2018 | Teac Audio Players & Recorders
Sony camcorder dcr-1p7e
Here is the only solution:
CODE C:31:22 Symptom/State T reel fault
CODE C:31:22 Symptom/State S reel fault
Correction: Load the tape again, and perform operations from the beginning.
Trying different brands of DV stock does not solve your problem. If this problem continues you could have a tension problem. Replacement of the S & T reel tables will solve your problem.
Nov 11, 2007 | Video Cameras
Behringer connect
Try taking direct feeds from your 8 mic channels by connecting leads from the insert jacks to the inputs of the recorder. In order to not interrupt the signal path on the mixer channel push the jack all the way in and then pull out gently until you feel it click. Then you should get a direct signal going to the Tascam and still have control over the level via the fader.
Apr 01, 2014 | Behringer XENYX X2222USB Mixer
Why does my sony reel to reel tape deck make no sound when playing a tape?
Are you playing the tape "right-side up"? I used to screw that up a lot at my radio station.
Jun 01, 2012 | Sony Audio Players & Recorders
How to thread a Shakespeare fishing rod and reel
feed the line down through the eyelets on your pole ,now open the bail on your reel tie the line on the spool,and start reeling(keep tension on the line,prevents line from tangling) when i resting mine I only go about two thirds on my spool.
Jun 05, 2010 | Shakespeare Agility Spinning Reel 6825
How do I thread the tape on an Akai GX210D reel to reel tape deck?
When facing the deck, the feed reel goes on the left and the take-up reel goes on the right. Make sure to secure each reel by engaging the reel locks on each of the spindles. Place the feed reel with the free end of the tape on the left and hanging downwards (like the letter "P"). Pass the tape to the right of the tension spindle (which is above and to the left of the play/record heads unit. Pull the tape down and pass it underneath the heads from left to right. Then on the right hand side of the heads unit pass the tape between the guide wheel and the first guide spindle to its left and just above. Then pass the tape over the top of the second guide spindle. Finally, loop the tape under the right hand tension spindle and pull it up and feed onto the take-up reel from the right in an anticlockwise direction (like the letter "g"). Once you have it through the slot in the centre of the reel, hold the tape end there with your finger and wind the reel around a few times to hold the tape in place and ... Voila!
Feb 19, 2009 | Audio Players & Recorders
Electronics - Others Logo
420 people viewed this question
Top Quantegy Electronics - Others Experts
Marvin
Marvin
Are you a Quantegy Electronics - Other Expert? Answer questions, earn points and help others
