Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
Deck is too low - Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
My rider craftsman model 917280083 the deck sits too low it drags the ground even at the highest settting
most craftsman have a bar that goes from the deck to the front of the frame that raises or lowers the deck in your case you will want to tighten it up to make the deck higher.
May 02, 2017 | Craftsman Garden
My John Deere D110 is cutting the grass to short on the highest deck level. How can I fix it.
level the deck off as a tilted deck will cut lower on the low side
adjust the deck mounting bars or deck pilot wheels
check that the cutter/pulley spindles are in good condition and not falling down
Sep 15, 2016 | John Deere Garden
Model 56145. How can I remove mower deck?
Look, lower deck as low as it will go, look above deck, under the tractor and pull any pins holding deck to the control arms etc., and remove belt sufficiently to slide deck out from below tractor, I advise you to take pictures to make assy. easy.
How to remove the mowing deck from lawn tractor
Craftsman Deck removal How to
Removing and attaching mower deck
How to Remove the Mowing Deck From Toro eHow
Jun 17, 2012 | Toro Garden
I purchashed a used 26 54 husqvarna 2007 model rider and it will not cut low enough.My murray will scalp ground if i lower deck to ground.It looks like the blades are designed to be set higher off...
Low under the steering wheel there may be an adjusting knob. If it is there are you turn it, it should adjust the height of the deck. If you lower the deck and try to turn the knob it will be difficult to turn and you will know that is what it is for, the deck lower stop. Then pull up the deck and adjust a bit and lower the deck and see where it is, repeat until satisfied with the deck height when lowered.
Sep 20, 2011 | Husqvarna Lawn Tractor - 54in. Deck, 26...
How to adjust lawn deck it too low on one side its 20 hp 46 deck
attached you will find instructions for this task on a DLT-3000, 48" deck. It should be quite similar.ae27863.jpgea7530a.jpg
May 09, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Adjusting John deere ''Sabre'' model deck
Move machine to flat/level surface,with deck raised put a 2x4 between rear of deck and ground.Make sure that the 2x4 goes all the way under deck from one side too the other.Once that is done lower deck all the way and make sure lift lever is all the way forward.Then on the rear top side of deck loosen bolt that holds arm to deck bracket,pull bracket as far down as you can then retighten bolt.This is also the point where you can level deck side to side.
May 03, 2010 | John Deere Tractor 1020, 1520, 1530,...
My deck is way too low. How do I adjust it?
Your mower should have a lever on it that you move to raise or lower your deck. The lever will normally have the slots that it locks into numbered like the trans gears if yours is not automatic.
Nov 06, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Need to know how to adjust deck Tracker mower, cutting low on one side.
There is a nut on each side on the high side loosen the nut or on the low side tighen the nut it is located on the deck hangers.
Aug 22, 2009 | Husqvarna Garden
Uneven cut
1-----------tire pressure? 14 front 10 rear
start with a level mower on a level surface
2------------deck level side to side?
3------------deck level front to back? (front can be 3/8 lower than back)
4-----------deck hangers bent or hung up?
5------------blades even when pointing at each other? no more than 1/8 high or low
6------------blades dull or upside down? turned up ends go towards deck
7---------------incorrect blades for mower?
8------------deck lifting mechanism should pick up deck evenly and drop evenly?
9-----------under the deck need cleaning because it is packed with grass?
Jun 15, 2009 | Garden
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
19 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
