Question about Fisher and Paykel IWL12 Top Load Washer
Simpson ezi sensor top loader 9kg swt902 model lid lock keeps beeping after wash cycle and will not drain the water out or spin
2 Suggested Answers
SOURCE: Simpson ezi sensor 8.0 kg won't spin lid lock flashes and alarms
Hi
To solve the beeping and lid lock light flashing and the machine not doing a spin dry. Do the following.
I have a SIMPSON EZI SENSOR 8Kg top loader. This is what I did.
WARNING HIGH VOLTAGE. switch the power off and unplug the machine.
DO NOT do this if you are not familiar with working with high voltages.
To get access to the lid lock switch,
1. Remove 2 screws at the rear of the washer.
2. Remove 2 screws at the front of the machine located under the lid and covered by small round plastic plugs.
The top cover can now be raised gently from the front.
3. Remove the 2 screws that hold the lid switch.
4. Remove the clear plastic cover from the lid switch.
5. DANGER HIGH VOLTAGE ( Verify that power is off)
6. Find 2 blue wires these go to a magnetic reed switch (25mm long 3mm Diameter).
Cut the blue wires and discard the reed switch. insulate the ends of the blue wires and push them back into the track in different directions so there is no possibility that they can make contact with each other.
7. Find 2 white wires these go to a set of contacts that are mechanically closed by the solenoid.
8. Pull out the contacts and the 2 white wires.
9. Cut the white wires at the contacts, strip 5mm of plastic off the wires and twist them together, The wires will have corrosion, clean them with sand paper, they must make good contact. I recommend that you solder them together.
10. Insulate them and push them back into the track.
11.Reassemble starting with fitting the clear plastic cover.
Your good to go BUT BUT BUT,
WARNING
The Lid safety protecting during the spin dry cycle will no longer function,
So don't do this if you need the safety of the lid closed during the spin cycle.
Remove 2 screws at the back of the machine
Posted on Feb 05, 2012
My machine stops after the rinse cycle, the Lid Locked sensor constantly beeps and it won't advance to spin.
Sounds like the filter might be clogged up.. Not sure what model you have. The filter is usually located on the right front bottom corner. Twist counterclockwise to open and clean ...just replace reverse manner.. Hope that helps..
Nov 07, 2016 | Washing Machines
Changed lid lock on a 750 simpson ezyset washing machine.
most likely a problem program board not moving onto the next cycle and that is why the lid lock is still activated
Feb 08, 2016 | Simpson Washing Machines
Simpson ezi 950 9.5 will not empty, rinse, spin dry.
That sounds like the pump is jammed. Have you checked for hair slides or similar? Once the pump is free to operate, your Simpson should resume normal service.
Feb 20, 2014 | Washing Machines
Lid light beeping and flashing on our 6kg simpson swt605 ezi sensor and won't spin. Any ideas???
Thank you for your advice non3. We have an old Simpson SWT605 that had a similar issue. In our case the lid lock was working but the spin cycle wouldn't start. I followed your advice to take off the lid and have a look at the lid sensor. It turned out that the one of the contacts for the two white wires you mentioned had broken off so when the mechanical pin was coming out no contact was actually made.
I followed your advice and it is currently working (without the lid safety lock) but it will give us a few weeks to decide whether we get it fixed or just get a new unit.
Jan 20, 2014 | Washing Machines
Simpson Ezi Sensor Front Loader keeps pausing during washes, doesn't put through the detergent.
you might be putting the detergent in the wrong part of the dispenser,or you might have the hose on the wrong way,or the water valve has failed. Read up on your user manual to see what happens on this part of the cycle,does the w/m empty ,then try and bring in more water?? The main give away to this fault is,detergent still in the dispenser.Check all your filters on your inlet hose and water valves.
You have to ask yourself what has changed,cheers.
Aug 14, 2012 | Simpson Washing Machines
My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
Jul 14, 2012 | Simpson Washing Machines
Can i bypass lid lock simpsom ezi lock its broken
You have to replace the switch. It has a "failsafe" design which prevents users from splicing the wires together.
Jun 11, 2012 | Simpson Washing Machines
I have a 5.5kg Simpson Ezi Sensor SWT552 Washing Machine. The lid locked light keeps flashing and the machine keeps beeping during the spin cycle - even though the lid it down properly. Could you please...
yes the safty door latch switch is eather loose or going bad. somewhere on your door there is a small sensor or switch that tells the washer the door is closed and its ok to spin, these washers put out alot of force when spinning and thats why the sensor is there it would be dangerous without them. when the washer goes in spin cycle there is more vibration than any other cycle. and thats whats making the sensor or switch wiggle and its getting an intermedate signal. it probily needs replaced these can commonly go bad due to wear buy slamming the door on the washer.. i hope this helps
Sep 09, 2011 | Washing Machines
Hi
WARNING
Jul 30, 2010 | Fisher and Paykel IWL12 Top Load Washer
Fisher and Paykel IWL12 Top Load Washer Logo
186 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
