SOURCE: my pool sand filter pump isnt filtering the water
could possbly be a bad gasket on the vari-flow valve. When is the last time you backwashed?
SOURCE: Hayward sand filter needs primed every time
The problem is a malfunctioning check valve. It'll be somewhere in the line on the pump output side. If it's not a separate fitting it'll be in the line, probably in an elbow.
Need further info, let me know...
Charlie
SOURCE: water dripping out of backwash port when handle is on filter
You might have it overfilled with sand. It's getting into the seats of the valves.
SOURCE: hooking up filter to pump and pool
This website contains a copy of the owners manual for the S180T pool filter. It should have all of the information that you need.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
It is in PDF format. let me know if you have any trouble opening it.
