Question about Water Heaters
How to replace the anode rod in a Rheem 81X52D
3 Suggested Answers
  • 252 Answers
SOURCE: cant locate anode rod on rheem gaas water heater
It looks like a plug screwed into the top of the water heater (it IS plugging the hole so turn off water and release pressure b4 removing)
Posted on Oct 01, 2009
SOURCE: Rheem ap12938 anode rod installation
No No No. Turn off power,drain tank,unscrew two pipes,power cord should be long enough to alow you to put the tank on its side if needed,replace anodes located under plastic covers in the top of tank.I have just replaced my rheem heater after twenty five years because of rot from the outside cover causing it to fall over.Worked fine.
Posted on Feb 10, 2010
Rheem anode rod replacement
replacing the anode will increase the life of the tank. it is the large nut on top of the tank. it is a sacrificial material that helps prevent tank rust through.
Jun 01, 2014 | Rheem Water Heater Anode Rod AP12938
I am looking for a magnesium anode for a Rheem natural gaz water heater PV75
There are two types magnesium anode.
1) Hex-head that screws into separate port on top of tank, and comes either 44" long or 12" sausage links.
2) Combo-anode that connects to Hot water nipple, and comes in solid or combo.
Contact guys at following link to purchase anodes
http://www.waterheaterrescue.com/pages/WHRpages/English/OrderPages/XCart/sales-through-XCart.html
General instructions and types of anodes
http://waterheatertimer.org/Replace-anode-rod.html
Rheem 'preferred parts'
http://waterheatertimer.org/pdf/2011_Rheem-anode-rods.pdf
Purpose of resistorized anode is supposedly so magnesium performs as well as aluminum.
Rheem however had 'resistorized elements' years ago, and that turned out to be promotional gimmick so people would buy rheem-brand products.
Nov 02, 2012 | Protech Rheem/Ruud SP13901B - Anode...
My sacrificial anode is leaking
Copy following link to identify anode rod:
Re-install new anode rod with 6 wraps teflon tape to ensure it will not leak.
Additional resources.
http://waterheatertimer.org/Leaking-water-heater.html
Oct 12, 2012 | Rheem Water Heaters
How to how to install the anode rod - for extended warranty - in a new Rheem waterheater?
You are installing a combo anode rod that replaces hot water outlet nipple. This means you will have 2 anode rods, which doubles the anode capacity of tank, which can cause extended life of water heater, assuming that both anodes are inspected each 2-5 years.
Sounds like a heat trap insert is in the way.
Look at parts sheet that comes with product manual.
Pull insert out since it will cause clogs.
Same insert is on cold side nipple.
I want you to contact the Tank forum since they are anode experts:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Tank will recommend magnesium anode and not aluminum.
My understanding is that Rheem water heaters are made so only Rheem brand anodes fit their tanks. While other companies use generic anodes that are sold at any plumbing supply, and also sold at Tank website.
You can configure pipes to make heat traps that save save $2-4 per year on gas water heater operation.
http://waterheatertimer.org/images/Heat-trap-install-900.jpg
http://waterheatertimer.org/How-to-maintain-water-heater.html
Sep 08, 2012 | Water Heaters
How do i clean my anode in my rheem optima
Is this a tank-type water heater?
Anode rod is usually replaced:
Tanks that have odor, because of bacteria reacting with anode metal, can be flushed with 2 pints of hydrogen peroxide.
Sep 23, 2011 | Rheem Water Heaters
Where is anode located mdel no. 82yp30-1
Question posted under Rheem water heater.
Model number does not describe water heater.
Model number posted in question does not appear at Rheem, and does not appear in a web search for water heaters.
Here are options:
1) Add a comment and describe water heater in detail so expert can access more information
2) Contact Rheem.
http://www.rheem.com/Contact.aspx
3) If this is tank-type water heater, the anode is located on top of heater.
Look for 1-1/6" hex nut located under a plastic plug.
Some anode rods are connected to the hot-water nipple.
Sometimes the top cover has to be removed to find anode hex nut.
I have used impact wrench on anode, and could not remove in some cases.
4) More resources:
Sep 17, 2011 | Rheem Water Heaters
I need anode rod for my rheemglas fury model # 81V52DT. do you know what the part # is or maybe the dementions. There seems to be several diffrent ones out there. Thanks
Anode rods are generic and available from local plumbing supply store or internet.
Just cut it off so it drops into the tank without touching the bottom or sediment on the bottom.
If there is not enough room above the tank to install new rod, then buy anode rod with sausage links.
Open following link for Rheem parts: page 7 shows anode rods
http://waterheatertimer.org/pdf/Rheem-parts-list.pdf
Jul 02, 2011 | Rheem 81VP6S/430126 Water Heater
Where is the anode rod located on the rheem 81VP20s
Anodes are located on top of water heater.
There are no hard fast rules for location, either by model number or brand.
Most times the manual is likewise vague.
1) There is hex head visible on top of tank.
2) Hex head is located under a plastic cover
3) Hex head is located under metal top, so remove screws holding top, and lift top off to view hex head
4) Anode is connected to hot water nipple.
5) With 9-12-15-and lifetime tanks, you can have 2 anode rods, and each has to be made of same material to work properly. Usually magnesium-aluminum instead of aluminum.
But if you inspect and change anodes frequently to prolong life of tank, then one is as good as the next.
Open following links shows Rheem anode rods
http://waterheatertimer.org/pdf/Rheem-Ruud-anode-rods.pdf
http://waterheatertimer.org/pdf/Rheem-Ruud-water-heater-parts-guide.pdf
Tech resistor anode rod has resistor added to prolong life of anode.
You can cut rod off to fit size of tank. You want anode 5-6" from tank bottom so sediment build-up doesn't reach anode.
Anodes are standard 1-1/16" hex head.
http://waterheatertimer.org/images/Water-heater-anode-006-200.jpg
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 01, 2011 | Rheem 81VP20S/430157 Water Heater
Where is anode rod located on 100 Gallon rheem water heater natural gas
Anode rods for tank-type water heaters are located on top of tank.
This is true since anodes are about 44" long.
Top of anode is standard 1-1/16" hex nut.
Anodes can be located in 2 different places: either directly screwed into top of tank -or- attached to hot water nipple.
Most times the exploded parts diagram in manual simply shows 'anode rod' without specifing exact location. If your tank has long warranty, then it can have two anode rods, and 1 will be on top and the other probably attached to hot water nipple, or there could be two anodes screwed into top of tank.
If anode is screwed into top of tank, then it will be under a plastic cap -or- it will be concealed under the top cover of tank.
Look for plastic cap, and if none shows, then remove screws holding down metal cover and look there for 1-1/16" hex nut.
Lastly, remove hot water nipple and check for anode located there.
If you have 2 anode rods, then replace with same metal for each.
Add a comment for more free help.
Mar 22, 2011 | Rheem Water Heater Anode Rod AP12938
Cant locate anode rod on rheem gaas water heater
Sep 30, 2009 | Water Heaters
Water Heaters Logo
22 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
