Question about HP Photosmart 3310 Printer
Error 0xc19a0040 when turned on it displays 'paper jam' when touched ok it displays error code 0xc19a0040 and 'turn off and then on'.i have done that but the problem keeps repeating itself'
  • 300 Answers
SOURCE: After clearing a paper jam,
One of the paper flags is either stuck down or broken (from the area of the jam)
Posted on May 17, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Always paper jam.
Check to see if something isn't blocking the paper path.
You could try cleaning the feed rollers as well.
Posted on Jun 12, 2008
mosesclive
  • 191 Answers
SOURCE: HP Photosmart 8250 Paper jam error
plz refer to the link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00386753&lc=en&dlc=en&cc=us&lang=en&rule=8662&product=443024
Posted on Dec 04, 2008
rockfixya
  • 679 Answers
SOURCE: error - carriage jam message
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Posted on Feb 03, 2009
  • 24 Answers
SOURCE: Printer keeps saying ''carriage jam error''...
Friends,
The encoder strip may also be dirty, this causes the printer to believe that the carriage moves less than it actually does and tries to compensate by moving the carriage even further - slamming into the left side of the printer as a result.
Carefully leaning the encoder strip with a lint-free cloth wetted with luke warm water (it should not drip!) can fix this problem.
If the carriage stays in the middle of the printer and doesn't move, the carriage drive belt may be broken. Usually this is not replaced so the printer unfortunately has to be scrapped. But contact your local HP support for further advice.
//Al
Posted on Mar 08, 2009
C-0102
The 1xx code refer to main body papre tray lift motor error.Check the paper jam in rear side to open the trays.To reset press the Utility key and hold on and turn ON the copier,wait will appaire Trouble reest on the display,release the Utility key,touch the screen and turn OFF the machine.Wait 2 minutes and turn ON.
Mar 05, 2013 | Konica Minolta bizhub Office Equipment &...
C-3423
The error code means there is some thing wrong the fixing unit. I believe it for to many paper jams in the fixing unit. Remove all of the paper jams and to rest it > Turn the Main power Off and when turning the copier back ON, press and hold the utillity button till the screen changes and the Trouble rest show on the display screen. Press the "OK" and let it do it's thing & then turn it off and back ON. Good Luck
Jul 08, 2012 | Konica Minolta Bizhub c203 Copier
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
When turning on my Picture Mate,it says ERROR: Paper is jammed in the printer, remove the jammed paper, then Press (OK). I have done this many times and still get that message. What do I do?
I own a PictureMate Epson personal photo lab. It has been sitting on my desk for over 1 year with the message Error:Paper is jammed in the printer. Remove the jammed paper, then press (OK). I have done this, many times, I have talked to a "solution Person" and unfortunately they have told me it can't be fixed. I am just warning anyone else, not to buy this product. I have printed less than 100 pictures and it now doesn't work anymore. Just DON'T BUY THIS EPSON PRODUCT
Dec 30, 2009 | Epson PictureMate (C11C556001) InkJet...
Paper jammed
Paper Jams
Cause 1 : Paper jams in the paper output slot/Auto Sheet Feeder.
Action : Remove the paper according to the following procedure.
a) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will be ejected automatically.
b) Reload the paper into the machine and press [OK].
* If you have turned OFF the machine in step a), you will need to retry printing, because this operation cancels any print jobs in progress.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, contact a Canon service representative.
Cause 2 : Landscape Credit Card-size Paper Jams inside the Machine.
Action : You cannot load Credit Card-size paper in the landscape orientation.
If <PAPER JAMMED> or <E3> is displayed on the LCD/LED, remove the paper following the procedure below:
a) Load Credit Card-sized paper in the Auto Sheet Feeder one sheet at a time.
Do not load it in the landscape orientation.
b) Press [ON/OFF] on the machine to turn OFF the power.
c) Press [ON/OFF] again on the machine to turn ON the power.
The paper is fed and the jammed paper is ejected accordingly.
If you cannot remove the jammed paper or the error still persists, contact a Canon service representative.
Hope this helps
Please rate my response.
Thanks
Have a good day.
Dec 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error code 6A00 what is it how do you fix it? this is what is displayed on the printer. I had a paperjam last night. I removed the paper and it worked ok. This morning it displayed this error message and...
6A00 is AP position error.
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Oct 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
DP 3530 error code E04-02
Hello sir; You have to look at heating unit you havv paper jam over there!
Aug 23, 2009 | Panasonic Workio DP-3530 Copier
Paper jam
First I would request you to provide the name and the model of the printer which would helps us to provide you more specific troubleshooting steps for your type of printer. I am providing you some of the trouble shooting stpes which should be ideally done in cases like papaer jam:
* Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
* Turn off the printer.
* Remove any paper trays. Inspect them for wrinkled or damaged paper.
* Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
* If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
* If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly . The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
* If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
* Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
* If the printer paper jam message still appears, then there is still some paper in the printer.
Hope this would resolve the issue.
Thank you for contacting Fixya.
Jul 10, 2009 | Office Equipment & Supplies
HP Photosmart 3310 Printer Logo
66 people viewed this question
Seeker5211
Seeker5211
