Question about Refrigerators
I have a kenmore refrigerator model106-57577791. It's real old. Anyway, how do I replace the water filter? I don't know where I should look at.. It's not below where the grille is.
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: Trying to remove the water filter and front grill
To change the filter rotate counter clockwise. To remove the grill at bottom grab bottom lift up and out. also here is the manual.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=ET1FHTXMQ04&siteCd=WHRCOM
Good Luck and please rate FixYa!
Posted on Apr 11, 2009
Low water pressure & ice maker problem
Hi! you don't say how old the refrigerator is, but if it has a water filter, the problem may be that the water filter needs replacement. If there is a water filter, it may be inside the refrigerator side, usually up top towards the back.
If you see a filter, you can buy a replacement at Sears. While your there, check out their water filter subscription. They'll send a water filter to your house on schedule, so you can replace it when needed.
Oct 28, 2013 | Kenmore Refrigerators
How do I replace the water filter on my refrigerator?
The filter has either a screw on connector where you can screw the old filter off and screw the new one back in, or it has a push connector where you just push the old filter to pop out and push the new filter in. Here are filters that are compatible with your Kenmore refrigerator.
Aug 07, 2013 | Kenmore Side by Side Refrigerator
My water filter was not clicked in all the way so water leaked and filled up the drip pan under the refrigerator and started leaking out onto my floor before I noticed anything was wrong. I put the water...
Hello Terri,
The pan there is for the defrost water that drains into it durning the defrost cycle,that water eveperates automatically so this water too will evaperate as well may take a bit longer since its more but it will evaperate. Also as you know there is no way to remove that pan,but tomorrow it will be empty anyway
Gene
Aug 08, 2011 | Kenmore Side by Side Refrigerator
Changed water filter, and now no filtered water comes out. Water had slowed, and it stopped making ice, so replaced the filter like always, and now no filtered water comes out at all Bought the same...
Don't know which filter you use, so this might not work. Try reversing the filter to see if it got installed incorrectly.
If not, make sure the the water line didn't get kinked and that the valve is open.
Jun 08, 2011 | Kenmore Refrigerators
I need to know which is the Serial or part number of the Water filter of the Kenmore Refrigerator Mod 106.58953800 I need to replace it and get a great price Where?
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Refrigerator-Parts/9030/0046/046/Model-10658953800/0582/0165000?keySuffixId=&productTypeId=&searchModelNumber=10658953800&blt=06&subCompDesc=CABINET%20PARTS
Sep 05, 2010 | Kenmore Refrigerator Replacement Water...
Kenmore Fridge - Bad Testing Water
Your refrigerator definitely has a water filter. If you have gone 5 years without replacing the filter, you and your family have probably been drinking contaminated water, for some time. Water filters should be replaced every three to six months. On some refrigerators, and in cases of higher water consumption, the filter must be changed every 60 days. Sears sells replacement filter cartridges for Kenmore refrigerators.
The water filter on your refrigerator is located at the front base of the unit, in the grille, below the freezer door. There, you will see a round cap. Turn the cap counter-clockwise, until the handle is vertical.Then, pull it out of the grille. The filter cartridge is attached to the cap. After removing the cap and filter, slide the cap off from the existing filter cartridge. Slide the cap on to a new cartridge, and re-insert with the cap handle in a vertical position. Push it in, firmly. Then, turn the cap clockwise, until the cap handle is horizontal.
Oct 24, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bad water & ice cube taste
then change your filter. the new filter could be different with the old filter. check the new filter, see if there is odor removal and taste removal with it.
if not then get the filter with carbon filter, odor and taste removal.
then with a new filter, run about 5 gallons of water before using the water for drinking.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore refrigerator filter
Tell me,the filter is it brazed on or is it on with a copper nut?
If you fix a filter remember that silver solder gets real hard if its exposed to cold air the hole time.
Let me know and i can help you with this problem..
Regards....
Sep 09, 2008 | Kenmore 53542 / 53544 Side by Side...
Kenmore refrigerator leaking at water filter
I am having the same problem, it leaks with a filter and without a filter, I even tried making it really really tight. What else could it be?
Dec 08, 2007 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
