Question about Hamilton Beach Black & Decker Smartboil KE1020S Electric Kettle
I need replacement filter for ke1020s tea kettle?
Is it okay to use glass whistler tea kettle on ceramic stove top range
I've seen mixed results across the internet on this one. From personal experience, for some reason, my glass teapot left some sort of stain on my ceramic stovetop. It also took longer to heat. I then went out and bought a simple metal one and have been pretty satisfied. If cosmetics are a concern, it's not too difficult a step to pour the water into your teapot after the fact, right?
Jul 23, 2014 | Frigidaire Ffed3025ls 30 Smooth Top...
THE element does not get hot
Sounds like your tea kettle may have exceeded it's useful life. Don't know about Cuisinart, but generally these kinds of parts are not replaceable. I am afraid you may be looking at a new appliance. Sorry.
Apr 14, 2014 | Cuisinart Cordless Automatic Tea Kettle
Dead cuisinart electric tea kettle
Your tea kettle has a thermal fuse inside that more that likely got over heated, it happens all the time with irons, coffee makers, most small appliances that are electric. you have to take the bottom off to find it and replace it. does it have an indicator lamp?
Sep 18, 2012 | Cuisinart Tea Kettle High Quality...
How to clean the inside of tea pot (scale deposits)?
Vinegar is very good at removing scaly deposits. Heat white/clear vinegar just as you would normally heat the water for your tea. After heating the vinegar, pour out and rinse thoroughly with water. If there are still deposits after this first attempt, use vinegar once again. Once you are satisfied that all the deposits have been removed, heat water in the tea pot 2-3 times to remove any smell or taste from the vinegar (before using for tea).
Jul 07, 2010 | Breville "Ikon" Tea Kettle Electric Kettle
Will not whistle
It is possible the reed valve broke.
Aug 02, 2009 | Electrolux CHANTAL Loop Tea Kettle -...
I would like to know where I can purchas a filter for my T-Fal Avante electric tea kettle
Thanks for the offer, but i no longer require help. I found out that the model tea kettle of mine is no longer made and they do not have filters for it.
Apr 08, 2009 | Tefal T-FAL Avante Stainless Steel...
Teakettle handle came off
The Tea Kettles have a 3-year warranty - if you are within the 3 years, call Cuisinart for an in-warranty replacement. 1-800-726-0190. No one sells the handles separately, so if you are out-of-warranty, you will either need to screw it back on or buy a new tea kettle.
Mar 23, 2009 | Cuisinart Kitchen Appliances - Others
Sediment in my electric tea kettle
it is very hard to get rid off ass the sediment comes from the tap water untill you boil the water you dont see this sediment and take it for granted that the water is clean but as soon as you put it in a electric kettle this sediment builds up on the element then it brakes off and floats around in the kettle most new kettles have a filter near the spout so when you pour the water out it traps it in the filter then this can be removed and cleaned but the sediment floating in the kettle is hard to get out you can clean the element and descale it and then just keep pouring water in and out of kettle till its all out but it will soon build up again there are two ways to stop sediment one is filter all the water before putting in kettle but this can be slow process so not worth doing or the best sollution is buy a kettle that has a filter by the spout of the kettle and clean this regularly hope this is some help to you............................................
Nov 17, 2007 | Bodum (5600-01USA) CURL Electric Kettle
Hamilton Beach Black & Decker Smartboil KE1020S Electric Kettle Logo
Top Hamilton Beach Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
ken skalski
Are you a Hamilton Beach Kitchen Appliances - Other Expert? Answer questions, earn points and help others
