Question about Bernina Artista 170
I have a Bernina Artista 180 with embroidery module. I can send a design to the machine with no problem, is goes over in seconds. But once I select the design for stitching out, the Artista is taking a really long time to prepare the design. It used to only take a minute or so, but no it is taking up to 5 minutes. I checked the memory useage and I am right at 13 % (I have only two designs stored on the memory. Does anyone know why this is happening now and is the a way to fix it?
SOURCE: artista 180 driner
hi you need to get the right software for artista 180.I have just sold
my 180 and i still have the software on my computer. You need
the software called CPS 4.1...EMAIL me at lfr6@bigpond.com i might be able to get a copy off my computer for you
Lawrence
Posted on Apr 29, 2008
SOURCE: DOES THE BERNINA BERNETTE DECO 600 ACCEPT .ART
Not sure if you found anything out, but Deco 600 uses PES format only.
If you have the software (Deco Wizard) sometimes you can change it to PES and save the design.
Good luck
Posted on Feb 15, 2010
  • 1116 Answers
SOURCE: bernina artista 180 keeps warning to check top thread
Refer to your manual for maintenance and clean the machine as indicated. A sensor may be blocked by lint.
If this continues, the machine will need to be serviced by an authorized Bernina repair tech.
Posted on Mar 25, 2010
  • 28 Answers
SOURCE: when stitching the design the upper thread keeps
The tension is not properly set for embroidery, try to rethread totally new. Sometimes it is also caused by broken thread inside the machine, you can open it with the supplied L-shaped tool on the left side of the machine where the lamp is located and than take it out with a tweezer.
Posted on Apr 11, 2010
  • 22 Answers
SOURCE: Bernina 180 with Firmware 2.08 - can it run DesignerPlus 5 or 6?
You will need to update the software in the machine, to a min of version 3.08 this can be done at BERNINA dealer (usually free of charge) once this is complete you designer will fully be compatible. WHEN YOU TAKE YOUR MACHINE IN TO BE UPDATE DO NOT FORGET TO TAKE THE EMBROIDERY UNIT IN AS WELL AS IT CONTAINS ITS OWN SOFTWARE
Posted on May 03, 2010
Is bernina artista 180 embroidery module compatible with bernina artista 170
Yes, The BERNINA Artista 180 and the BERNINA Artista 170 do in fact use the same Embroidery Module.
Sep 28, 2015 | Bernina Artista 170
I have a Bernina Artista 180 with embroidery module. I put in the plug in the wrong direction once and now it will not connect the module to the sewing machine. Can this be fixed?
It is very likely that when you attempted to connect the embroidery unit with the plug out of alignment that you would have bent some of the pins on the male side of the plug. It is possible, though not advisable, to straighten the pins in this pug. However, if not done perfectly, this could cause further damage to both the male and female sides of the plug. I would recommend taking it in to a local BERNINA dealer and repair center to have that cable replaced just to be safe.
You can find a nearby dealer at: http://www.bernina.com/en-US/Where-to-Buy-US/Store-Locator
Sep 22, 2015 | Bernina Artista 180
Bernina Artista 180 firmware question: I sold a Bernina Artista 180 sewing/embroidery machine. This machine was from 1999 and never had any firmware updated. The embroidery module was damaged in sh
I'm not exactly sure what you need but I'll give you a web site where I believe you will have good results:
http://www.ebay.com/bhp/bernina-software
Dec 15, 2014 | Bernina Artista 180
With embroidery card inserted into module, no motifs appear on the display screen.
Here are two other possibilities other than electrical problems with your Bernina. There are embroidery design cards that were made for the 200 & 730 that simply do not work in a 180. There is nothing marked on the card or the packaging that will tell you what model machine the card will work in. I sold a bunch of my design cards on eBay last winter and I tested all of them in both a 730 and a 180 before making the ad discription. I found that most of the design cards worked in the 180 & 730, but there were a few that only worked in the 730. So if your design card is one of those that won't work in a 180, that could be your problem.
You did not say if you have other design cards that do work or there is only one you tried. Possibly the card itself is bad.
A static shock to the card could possibly damage it.
So if you take your machine to a dealer to have it looked at, take your design card along.
The 180's memory for storing designs is located in the embroidery module, not the machine itself. If that memory is filled up with other designs this can cause a problem.
So your problem is most likely with the design card or with the embroidery module. Should you need to get another embroidery module, that module needs to be the same version number as your machine or it will not work. I have a. video posted on YouTube that shows you how to check the version number of your machine and module. That information is in my "Bernina check hours 165, 170, 180, 185" video. Put that in the YouTube search box and you will find my video. Plus I have other helpful Bernina videos posted.
Aug 14, 2014 | Bernina Artista 180
Lost dongle bernina 180 artista version 3
Unfortunately, your dongle is like a Key that is made just for your machine. You could try contacting Bernina or the place where you bought the machine originally and ask if they can send you a replacement. I've afraid it will be very expensive though.
Good luck.
Mar 15, 2014 | Bernina Artista 180
Bernina artista hoop not recognized
Calibrate the embroidery hoop
Note
The embroidery hoop can only be calibrated with the oval hoop.. You'll find the instructions for each machine in the relevant user manual.
Aug 15, 2012 | Bernina Artista 180
I would like to delete 2 files from the embroidery memory in the 180 module, not the card. I open the file, go to Layout 1, select DEL and nothing happens. This is as per the directions in the manual. What...
If you have the machine connected to the computer you can delete the embroidery from your machine, Artlink software is for this machine to write designs or read designs from your machine.
May 05, 2010 | Bernina Artista 180
Mar 22, 2010 | Bernina Artista 180
Embroidery
If you doing an embroidery, it has to have something to do with the way the design was digitized. We have a BERNINA ARTISTA 180 and have never come across this problem. The embroidery machine only reads what is on the disk. Try putting your design through the computer.
Sep 07, 2006 | Bernina Artista 180
Sewing Machines Logo
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
