Question about John Deere Garden
John deere 4045 flywheel torque - John Deere Garden
4 Suggested Answers
wireguy212
  • 1627 Answers
SOURCE: Hello, does anybody know the torque setting for
I found the tech manual one lin but it can"t be opened since deere is updating it.I will see if we have the book"tm1974" at the dealership in the morning and get back to you.
Posted on Oct 28, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
nova2nv
  • 197 Answers
SOURCE: torque spec on a 425 john deere head
Initial torque-115 inch pounds,final torque-186 inch pounds.Intake manifold is 53 inch pounds on all 8 screws.Valves set at 0.010 on all 4.If you go with the new style valve cover gasket {the flat one} be sure to leave the old o-ring in valve cover to keep the new gasket from splitting.
Posted on Feb 09, 2010
John deere timing
Hey Ronald,, what John Deere are we talking about...???
Need some more details...
Timing the magneto
John Deere Valve and Flywheel timing
Jul 14, 2017 | John Deere Garden
Torque for tightening flywheel
Generally 50nm is sufficient. Clutches tend to be a clockwise thread to remove them so the tend not to unwind when running.
Apr 15, 2016 | John Deere Cs36,cs40 Chainsaw Owners...
John deere 4 cylinder engine model 4045 will crank but not run
Nickole, there have been many versions of the 4045 made, all with different fuel systems on them, so the diagnostic process is different.
On the engine serial number tag there will be a model designation, something like: 4045HF275 or 4045TT078.
If you can provide this information, it will help a lot.
Dec 11, 2015 | John Deere Garden
My John Deere z225 was operating normally until my son snagged an old carpet and stalled the engine. Pulled the carpet out, now the engine turns over, but won't engage. Help?
If it is engine that is not starting you may may have a sheared flywheel.
Depending how that Briggs 310000 series may have the key that shears easily. The flywheel and crankshaft were redesign in July 2012 because of this. If your engine is before this then a steel key and torquing the flywheel to 110 ft-lbs should solve this.
Apr 12, 2015 | John Deere Garden
How to replace pto clutch on John Deere x320
Removal and replacement fairly straight forward, you just need to prevent the engine crankshaft from turning. This can done either holding the flywheel or using a piston stop. Also some clutches have a set of flats that a 1-3/8 open end wrench will fit.
When reinstalling the center bolt torque to 50-55 ft-lbs. Also make sure the anti-rotation device is engage into clutch assembly or it will rip the wires out at the first startup.
Apr 07, 2015 | John Deere Garden
What torque do I use when replacing the cylinder head on a John Deere 110, Briggs and Stratten 19.5 hp
Stuart,
Do an internet search for torque specs 2011 John Deere D110. You should be able to find the service manual for this product easily.
Sep 29, 2014 | John Deere D110 42 in. 19.5 HP...
John deer 4045 diesel engine timing diagram
and you can't just follow the fuel lines from pump why ??
cyl 1 is always one most forward
Dec 02, 2013 | John Deere 4020 Gas & Diesel Tractor...
How is crankshaft end float controlled and when refitting flywheel does it go hard in, thanks
By the thickness of the base gasket. No just set it on and tighten nut/bolt to correct torque.
Sam
Jul 29, 2009 | John Deere A,b,g Tractor Carburetor Float...
Garden Logo
52 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
