My I LIVE Sound Bar Model ITP231B went off and it won't turn on when you push the power button. It is a couple years old.
  • 68 Answers
SOURCE: f32650/atc113ca1
This could cause a problem, because modern TVs and most other entertainment electronic goods, have a small kind of computer chip, but there should be a Reset button probably inside the set! If you feel confident about computer chips you may be able to find the button by tracing the circuit.(Disconnected from the mains). Another idea is if there is a small button cell or battery inside, then try disconnecting it for a day. Good Luck!
Posted on Dec 02, 2006
  • 87 Answers
SOURCE: Blinking power button
You likely have bad convergence output IC's that have caused one of the supply fuses to blow. This repair will have to be performed by a qualified technician. If you were in our area and has us repair this the total cost of the repair would be about $340 if I am correct about the cause of your problem.
Posted on Aug 02, 2007
SOURCE: delphi roady 2 won't power up
You have a bad power plug on the unit. The solder connection are loose. The one have is doing the same thing. The power plug pins have came lose and need to be resolder. Working on how to take the unit apart to solder the connection.
Posted on Dec 09, 2008
SOURCE: 2 year old machine...new noise in beater bar area
I have a dyson 17 animal and have a loud noise comming from the beater bar area.Also I don't think the hight adjuster is working properly.
Posted on Jun 02, 2009
heatman101
  • 43501 Answers
SOURCE: MY Keurig is about a year old and it won't
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 15, 2011
How to reset ilive model ITP231B soundbar after power outage
Reset only works with programmed things. When removing the power cord, and reinserting. and after that switching on again not changes the state the sound bar is in, you have to assume it is defect.
Feb 16, 2015 | Office Equipment & Supplies
No power. Died when turning on to watch TV.
unplug for a couple of minutes then plug back in and try
Oct 29, 2009 | Niko SV3206 32 in. LCD Television
Camera LCD - black pictures
When I take a picture, there will be know image. Black. I went into the "share" and the image is black. I kept my smart card and the other images are ok but the knew ones are black. Camera has power. I took the smart card off. Still the problem, black. Took the old images off and took some more shots. All black!! MMMMM?
Sep 02, 2008 | Kodak EasyShare DX4330 Digital Camera
RCA Projection TV
that would be the inverter board, supplies power to the bulb, you would need to replace this part, but don't touch the board without wearing rubber gloves, as it can store a lot of voltage when they fail . when you get the board out discharge the capacitors to make it safe. cross the live and negative on the capacitors.
Jul 08, 2017 | RCA Televison & Video
TV will not turn on when power button is pushed.
check the main fuse in the tv. test it with a multimeter, not visually. if its the thermistor that blew the fuse, it is very difficult to see the break in the wire. replace if blown. if unit blown fuse again withing a couple of weeks replace the thermistor in the degausing circuit. good luck.
Jan 09, 2007 | RCA F36665 36" TV
23 people viewed this question
 Grubhead
Grubhead
