Question about Raysonic CD228 Tube CD-Player
My Raysonic CD228 CD player does not start and just shows the "no disc" signal in the display.
    Habit-Forming:
  • 99 Answers
Try cleaning the optical lens.........
Posted on Mar 29, 2014
I have a cd stuck in the radio & it won't eject it (states no cd), makes a clcking sound. how to fix it?
Usually there is a hole in close to the cd slot, where a pin can be inserted in order to push out a cd manually or a similar manual override.
Which CD player/ radio are you using?
Jul 01, 2017 | 2004 Chevrolet Avalanche
2005 Corolla cd player "ate"
try disconnecting the battery for a few minutes to reset the radio. Sometimes a microprocessor will lock up. You can reset it by disconnecting the battery.
Jun 01, 2011 | Car Audio & Video
I have a Sony CDP-CX350. I recently discovered the remote will not control anything on the player. The remote has fresh batteries and displays that a signal is sent out. The same display usually shows...
If you have turned it back on then this would indicate the receiving module that picks up the infrared signal is not working and has become defective, but I would double check your manual so nothing was over looked.
Jan 30, 2011 | Sony MegaStorage CDP-CX355 300-Disc CD...
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
CD player does not recognise some CDs. When placed in the drawer the deck displays "no disc" if another CD player is used the disc works fine
I have two of these Tascam CD-A500 players, and one more than the other has this problem of not reading some CDs that will play fine in other players. I'm starting to loose faith in this Tascam product. Anyway, seems the consensus is to open it up and check for dirty laser optics. If that doesn't fix the problem, then send it in for repair or scrap it and buy a different brand. I've not had this problem with any other brand CD player, but very suspicious that the same problem happens on BOTH of my Tascam CD-A500 units.
Nov 15, 2009 | Tascam CD-A500 CD Player
Discs won't play.
please change laser unite then solve your problem
Jul 16, 2009 | Sony DVP-NS575P DVD Player
Will not record disc-to-disc
The first thing to try is cleaning the lenses,sounds obvious,but i think thats why its continuing to try :initialising: if that fails the lense that reads the disc or both likely need realigning most problems that acure whith any cdplayers ect are down to the lenses.
Apr 04, 2008 | Philips CDR796 2-Disc CD Recorder
Error nd after entering cd and pressing play
Have you tried cleaning the Lens? nd means No Disc, indicating that the Lens is not picking up the signal, and so is indicating a 'No Disc'
Oct 22, 2006 | GE Slim Spacemaker 7-5295 CD Shelf System
Raysonic CD228 Tube CD-Player Logo
105 people viewed this question
Top Raysonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Raysonic Audio Player and Recorder Expert? Answer questions, earn points and help others
