Question about Garden
Husqvarna gth200 hydrostatic transmission whining and will not move.
youcandoit2
  • 11 Answers
SOURCE: I HAVE HUSQVARNA 1548 RIDING MOWER HYDROSTATIC
You may have a drive belt that is worn or broken. Check the drive belt for slack condition see if it is not slipped off idler pully wheels or the belt tensioner. I had one that was streched out and was very slack on the pully wheels - I had it replaced with new one and was fine to go. There is a device on the back of your tractor to release the transaxle for manual pushing your tractor about with out starting the engine. Make sure the device is positioned correctly for running mode (engine) - There is a symbol on the back to help you know what to do. The tractor manual has good trouble shooting info and if you don't have one, try googling for it with the model number of your tractor - you will be able to download one free to your computer for viewing it.
Posted on Jul 17, 2009
youcandoit2
  • 11 Answers
SOURCE: just purchased Husqvarna YTH2348 Purged
As for whining sound I believe this normal. The purging instruction using the bypass valve ingaged on low engine running. Next with the bypass disengaged followed by the fwd with fast breaking and or rev with fast breaking actions to get the wheels to turning and getting better responce takes time. This does take some time to do - in my case 15 minutes or more. My tractor had 65 hours on it before it showed signs of not pulling a slight hill. I had to remove the transaxle and put in 50 wt. motor oil and with the purging I was able to bring new life back to this tractor. The original 30wt. motor oil is fine for a brake in oil and I did drain it and took the bottom cover pan off and cleaned the metal particals on the magnets and cleaned the filter. These transaxle are sealed but have a vent plug at the top of the case. That little plug is hard to get off with out damaging it. My tractor whins in forward and reverse but has good hydrostatic power now. So I say the whin is good!
Posted on Aug 03, 2009
  • 4 Answers
SOURCE: Husqvarna, GTH2454T Hydrostatic power loss.
If it's like mine the transmission is sealed and cannot be serviced. A local repair shop told me most likely the problem isn't with the transmission but rather the engine pulley is worn. He said if sand or debris gets between the belt and the pulley which has a definite "V" shape to it that it will wear down to a "U" shape. Now mine has a foot clutch on the left side so he had me pull back on the pedal which manually tightens the belt. I did this and it works like a champ. This winter I'll change the pulley.
Posted on Sep 16, 2009
stevestroud2
  • 4 Answers
SOURCE: Husqvarna YTH 2448 Hydrostatic stuck in neutral
There is a brake assy. located on your transaxle right rear side. There is a nut with a cotter pin. First check to make sure there is no debris clogging the assy. Clean it first. you can use a garden hose. If that does not work remove cotter pin and turn nut clockwise until slotted nut lines up with hole. replace cotter pin. Start mower and see if it will engage. these transaxles are notorious for not having the pads snug enough to catch. Good luck. Hope you don't need a new transaxle.
Posted on May 02, 2012
  • 6468 Answers
SOURCE: Sears garden tractor hydrostatic transmission whines and can't go up hill. What's the fix???
is the signs of oil leaks on the rear axle and the fluid level is low
Posted on May 28, 2012
Heal lever won't press down to engage transmission on hydrostatic transmission
Hydrostatic Drive Problems?? - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
May 30, 2006 - Hydro-Gear Transaxle:218-3010L I got this tractor as part of the deal when I ... After spraying the heck out of it and pressing the brake pedal down several ... I pull on the handle in the back and it moves the lever but still won't move. ..... while in the air and turning the wheels with the transmission engaged? mtd lawn tractor wont pull hills
Oct 18, 2009
briggs trouble
Jul 5, 2008
Peerless transaxle repair, Husqvarna mower
Oct 13, 2006
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Missing: heal
HYDROSTATIC TRANSMISSIONS - Small Engine Information
smallengineinformation.com/?page_id=370
Jan 14, 2016 | Garden
Husqvarna 24hp VTwin Hydrostatic 48' cut riding lawn mower will not move either direction.
I would check the drive belt going to rear end if not that I would check fluid level in transmission.
Aug 04, 2013 | Husqvarna 24HP VTwin Hydrostatic 54" Cut...
How to fill hydrostatic transmission fluid on Poulan Pro
How do I check the transmission
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Fill Hydrostatic Transmission in Lawn Tractor
http://husqvarna.custhelp.com/app/answers/detail/a_id/387/~/maintenance---what-type-of-oil-is-used-in-the-hydrostatic-transmissions%3F
Craftsman Hydrostatic Transmission Fluid Change
Jul 28, 2012 | Poulan Garden
MY TRANSMISSION IS VERY WEAK, MOVER WILL SOMETIMES STOP, WONT MOVE, OTHER TIMES IT WILL CREEP ALONG. ITS ONLY HAS 300 HRS ON IT.
noted for frequent failure of hydrostatic transmissions, just search this site. you have to buy another transmission or lawn mower.
Sep 01, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Mower will not move foward or backwards belt ok and turning fan and pully.
then the hydrostatic transmission is shot, look around for a new one or a used one. good luck as a new transmission will cost as much as another mower.
Apr 14, 2011 | Husqvarna Yard Tractor
I have a 15.5 h.p. lawn tracctor with a hydrostatic transmission. I bought it from an older gentleman who serviced it religiously. It is a 2005. The transmission whines some which I understand is normal,...
Most hydrostats have a internal, or external disc brake it is very important that the brake is not adjusted too tight, follow the linkage from the foot pedal to the gearbox, slacken off the brake rod, so as when you put the hrdro in bypass ( push mode ) you can push it easily, if you cannot oush it the brakes are definatley binding.
Feb 05, 2011 | Garden
Just purchased Husqvarna YTH2348 Purged transmission perinstruction in manual when recieved.Ran fine for about 2 hours.Now transmission whine while driving forward.In reverse no whining.Does anybody have...
Apr 06, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
