Question about Digital Galaxy Dg-737 Hd 1080i Hdmi Lcd Projector
My bulb doesn't come on, blinking green light
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
https://www.youtube.com/watch?v=_ONPuB5L-x4
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
www.fixya.com/.../t26028385-after_replacing_bulb_wd_82738_still_no...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
www.tomsguide.com/.../id.../mitsubishi-82738-blinking-green-light.html
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Amazon.com: Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
My right signal doesn't blink but the bulb lights are on
If the left signal light is affected as well then the flasher can is faulty.
The flasher can is located under the dash.
Jan 08, 2013 | 1995 Buick Park Avenue
Magnavox tv when the power button is pressed the green light comes on but nothing else happens; there's no picture or sound or nothing; but the green light simply stays lit (no blinking).
first, press the channel -/+ button on the TV. If that doesn't turn on the TV, then it means you have to replace the bulb of your TV. The bulb is most likely dead.
Replace the bulb and your TV should be restored.
Let me know if you need further assistance.
Regards.
Aug 12, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
My blinkers are not blinking , i check the Relay, fuses , bulbs still nothing ..... Please help me fing the problem
Did you check the signal flasher or the light relay? If the green dash indicator arrow is coming on when you operate the level for the signal lights but doesn't flash , you have a bad flasher if the indicator does not light up you have a power supply problem.
May 19, 2011 | 1996 Lexus GS 300
I turn on the 4805,green led blinks & bulb does not come on?
After a few minuets does the green blinking light turn to a red blinking light?
If so the problem is the lamp did not strike.Either the lamp has failed (most likely) or there is a problem with the power supply (less likely)
Feb 12, 2009 | InFocus ScreenPlay 4805 Multimedia...
New Bulb Doesn't Light
color wheel or light engine,call for service and save your money.
Aug 04, 2008 | Samsung HLN467W 46" Rear Projection HDTV
Samsung HLM507W Blink Lights
beings the connectors were different on the new bulb the spark gap maybe different also if it is the lamp wont work in that unit
Apr 12, 2008 | Televison & Video
Sony LCD projection TV - bulb problem
Hi! sweet123,
Please answer this question. Were the 4 bulbs visabley bad; say broken or did they have a milkey look, or broken wire inside? In other words did the bulbs you replaced look as good as a new unused bulb? Please reply.
toprol
Nov 15, 2007 | Televison & Video
Digital Galaxy Dg-737 Hd 1080i Hdmi Lcd Projector Logo
27 people viewed this question
Top Digital Galaxy Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Digital Galaxy Office Equipment and Supply Expert? Answer questions, earn points and help others
