Question about Ovens
Simpson oven timer keeps ticking we are unable to stop this it's very enoying. Gerry
2 Suggested Answers
SOURCE: ge double oven
I believe this is because it takes a while for your oven to cool down (the cleaning cycle uses a very high temperature to burn up the grease and food). The timer is how long it takes before it will be cool, at which time the oven will unlock.
Posted on Aug 31, 2008
I need a owners manual for Simpson Concorde fan forced oven?
I recently helped a friend fix the oven in his secound home, turned out the timer was shot. But, in order to find this out, we had to pull the oven from the wall, and there was a wiring diagram in an envelope on the back of the oven. That is all that it took to figure out the problem.
Dec 14, 2014 | Ovens
Simpson Neptune, atlas series electric oven isn't working.
Hi If you have Simpson Neptune 3U 602 then it may be to do with the timer function. This also happened with my oven.
There is a red section on the face of the clock. The oven seems to work if it shows the hand icon. I'm not sure what it symbolises yet, as it's a new oven for me, but it is now working. You can change the icons by turning the left nob left and right. Hope this helps.
Jul 07, 2012 | Ovens
I have an old Simpson fabulous 300 bench top stove in our beach house. We are unable to get the oven to work at full power. We have fiddled with the timer dials in the past and always get it going but it...
First of all, thank you very much Lindsay for choosing FIXYA today for your online technical support needs.
I'm Joe, and I will be more than happy to assist you with your service request.
Unfortunately a User's Manual for that particular SIMPSON appliance is no longer available.
However the problem is most likely that your TIMER has been set to AUTO which will prevent the oven from functioning. The timer needs to be set in the MANUAL mode.
Here are a few links to some other online resources which describe the various procedures for setting the clock and switching the timer mode which may help with your particular problem:
http://reviews.ebay.com.au/Things-to-check-if-your-electric-oven-won-apos-t-heat-up?ugid=10000000001213735
http://john.daltons.info/appliances/Simpson%202001%20Instructions.html
http://product.electrolux.com.au/Public/File/14880 (SELECT OPEN FILE)
http://www.simpson.co.nz/FAQs (SELECT ELECTRIC COOKING FOR APPLIANCE TYPE)
http://www.ehow.com/how_7382695_set-timer-simpson-wall-oven.html
Just use your mouse to click on the links, which are the underlined and blue highlighted sections of text just above. This will open a new web browser page automatically for you and allow you to view the information at the websites indicated.
I truly apologize Lindsay for not being able to provide you with the exact support documentation that you requested, but unfortunately on occasion the desired material is simply not available online.
I still hope this was at least somewhat helpful to you.
Good luck and take care.
Joe.
Jan 15, 2012 | Stoves Ovens
Have shifted house, my Simpson Apollo ceramic oven won't work. The elements are fine. The timer and auto lights are flashing. I can't seem to make it stop. I have no user guide to help fix this error,...
The timer needs to be set to manual mode for the oven to work. Turn the oven control on. Play with the buttons on the timer. Try all combinations. It may take 5 or more minutes. When the oven indicator light comes on you will know it is on manual and the oven is working.
Feb 26, 2011 | Ovens
Moffat Stove with a self-cleaning oven. I would like to know how to clean the oven using the "self cleaning" feature
hi there! I have a moffat stove and hopefully these instructions help you.
First clear out the racks in your oven. Take them out and remove any excess chunks at the bottom.
Then close your oven door and lock it by pulling the lock latch.
Now looking at your oven knobs [not your burner knobs] turn both of them so they are both on the arrow knob [your oven knobs should have small pictures on them and both should have arrows]
Now you need to set the time so in the middle of your oven their should be a timer and one start and stop timer on top of each other. Both timers go in increments of half an hour. So if you are starting your self cleaner at 3 move the dial to 3 or if you are starting at 3:30 move the dial to one tick after 3. Once you set your start timer, you need to set your stop timer.
Setting your stop timer, it is recommended to set it for 3-5 hours. I set mine for 4 hours. So then set stop timer to time you want the cleaning to be. If you set your start timer at 3:30 put your stop timer at 7:30.
The oven will start cleaning according to the time you set. The oven will get very hot. I recommend to not used the burners as the temperature goes to 500 degrees! You will smell an odor and that is your oven cleaning.... Hope this helps...
Sep 13, 2010 | Ovens
Turn off the timer on an old imperial st george
I have this exact same oven and this "feature" annoys me no end. To turn it off ... turn the clock dial to PAST the time that the timer dial shows. EG: If your timer dial is showing 6, turn the clock dial so that it rolls past 6 o'clock. This will pop out the timer dial and thus turn off the timer, allowing you to use the oven normally.
To stop accidentally pushing/turning that timer dial, I removed the knobs. Good luck.
Jan 23, 2010 | Ovens
Timer is making ticking noise cant turn it off.
My same oven makes a ticking sound when you tell it to start pre-heating the oven. The oven continues to make this ticking sound until you stop the oven and it completely cools down. This ticking sounds to be coming from the oven control panel. I have no solution, but I'm glad I wasn't the only one who had a problem with this ticking sound!
Jul 15, 2009 | Ovens
Automatic button on lower oven
This is how I reset my U1420NOGB/FD7907 NEFF double electric oven that I inherited also without an instruction book.
There are 4 buttons in a row and then a timer knob that moves left and right.The first button is black,second has an arrow,,third has an arrow and fourth a hand symbol on it.Hold down together, the black button and the arrow button next to it.Without releasing either,twist the timer knob clockwise(to the right)until correct time is showing.Do not release the other buttons at all ,until time is ok.If you miss correct time keep going ,dont go backwards.When time is correct,,release black and arrow buttons and auto will stop flashng ,and oven work.If auto doesn,t stop flashing at this point press the button with hand symbol (manual)on it once.
Aug 27, 2008 | Ovens
Ge double oven
Mar 17, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Ovens Logo
59 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
