Question about Dometic DM2652 Americana Fridge Refrigerator Refer 2-Way Small Double
Works on electric but not on gas - Dometic DM2652 Americana Fridge Refrigerator Refer 2-Way Small Double
    Top Expert:
  • Dometic Master
  • 8,688 Answers
Check LP lines for cobwebs
Posted on May 27, 2016
Why doesn't my dometic refrigerator work on gas, but works with electric?
if works with gas but not electric bad heater element if doesn't work on gas but ok on electric clean out LP burner
Feb 24, 2016 | Dometic Refrigerators
I have a gas dryer is it also electric dryer also
Up to my knowledge, GAS dryers work with gas
Sep 11, 2015 | Dryers
Suburban sw12 water heater will not work on gas or electric
Both gas and electric wtr htrs require electricity to work. Check your breaker or fuses to see if that may be the issue.
Sep 19, 2014 | Suburban Gas and Electric Water Heater, 12...
Gas but have only electric hookup
Sorry, but there is no conversion from gas to electric. (only natural gas to LP gas or back again) You will have to get an electric dryer or have a gas line run to the dryer.
May 25, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
The dryer runs but does not heat up
Depending on your heat source (gas or electric), your problem could be one of the following:
* if electric: heat element, thermostat or timer
* if gas: gas coils, radiant sensor, thermostat or timer
Note: In either case, check to ensure that the dryer is receiving the proper amount of electricity (110 volts for gas & 208-220 volts for electricity).
Feb 19, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Works good on electric. The freezer freezes on
make sure your gas level is right. low gas levels can cause your problem
Aug 07, 2009 | Dometic RM2652 Refrigerator
Our Dometic RM2193 cools on gas but does not work on electric
It could be as simple as a blown fuse at the fridge. Also check to make sure you have turned on the electric switch that allows the fridge to run on AC. Note, you can only operate the fridge on EITHER gas OR electric, but not both sources at the same time, thus, you have to turn off the gas switch before you can run on electric.
When this unit is running on electricity, it has to have the thermostat set for it to run.
Here's a link to the Dometic manual for your model.
http://www.alcovr.com/DATA/MANUEL/DometicRefrigeratorModelsRM2191&RM2193.pdf
Just follow the steps for running on electric and you should be OK.
Hope this helps.
Jul 30, 2009 | Dometic RM2193 Compact Refrigerator With...
Electric or Gas?
Pressure washers are either electric or gasoline powered. Electric pressure washers are low maintenance and quiet. These generally are for light duty. They are handy where you need to work on small confined area, however you need to run power to them and have a pressurized water source. Also the National Electrical Code and Underwriters Laboratories now require ground fault circuit interrupters (GFCIs) be use when operating an electric pressure washer. Gas models are recommended for tasks that require more power, such as paint prep, heavy vehicle cleaning, or cleaning heavily soiled concrete.. Gas models start with PSI of 1750 and go as high as 4000. They also offer more portability, as they are not limited by electric cords. Also some gas models can draw water from a source other than the garden hose, which allows you to work away from a water line. All gas models have 4-cycle engines and run on regular unleaded gas.
Aug 27, 2008 | Briggs & Stratton Power Products 1539...
Will my gas boat fridge work with out power
Power to drive a gas refrigerator comes from one of two places. Electrical or LP gas. That is if your system is dual powered. It must be shifted over to gas if the electrical is turned off or disconnected.
A separate thermostat controls the gas end and an electric thermostat controls the electrical end. You must manually change the operating mode from one to the other. When in the gas mode no electrical power is necessary.
Apr 29, 2008 | Refrigerators
Dometic DM2652 Americana Fridge Refrigerator Refer 2-Way Small Double Logo
56 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
