Question about Jensen Car Audio & Video
Which set of rca jacks goes from my jenssen car stereo to my amp
2 Suggested Answers
pctech1
  • 1940 Answers
SOURCE: I have a sony explod car stereo without rca jacks
INPUT:
SCOSCHE FAI-3A - SONY XPLOD HEADUNIT
A1 - Grey (Right Front +)
A2 - Grey/Black (Right Front -)
A3 - White (Left Front +)
A4 - White/Black (Left Front -)
A5 - Green (Left Rear +)
A6 - Green/Black (Left Rear -)
A7 - Violet (Right Rear +)
A8 - Violet/Black (Right Rear -)
OUTPUT:
SCOSCHE FAI-3A - AMPLIFIER
B1 - Right Front + (Not Used if using RCA)
B2 - Right Front - (Not Used if using RCA)
B3 - Left Front + (Not Used if using RCA)
B4 - Left Front - (Not Used if using RCA)
B5 - Left Rear + (Not Used if using RCA)
B6 - Left Rear - (Not Used if using RCA)
B7 - Right Rear + (Not Used if using RCA)
B8 - Right Rear - (Not Used if using RCA)
Right Rear Output - REAR RCA IN (White)
Left Rear Output - REAR RCA IN (Red)
Right Front Output - FRONT RCA IN (Red)
Left Front Output - FRONT RCA IN (White)
Note: Be sure to connect the Remote Turn-On from the Sony Xplod (Blue/White) to the Amplifier's Remote Terminal. All that's left is to connect the 12-volt power wire to the Amplifier's Power Terminal and a Ground wire to the Amplifier's Ground Terminal. Also, switch the FAI-3A to Line Out using the switch on the left side of the device, and ground the FAI-3A using the device's ground wire.
If you need any more help, let me know.
Posted on Jun 08, 2011
What can be connected to te audio output jacks on the back of this set?
You didn't include make and model TV; so only generalized answers are possible.
Typical RCA phono jacks like those shown in the blue box of the stereo amplifier below:
25998201-ac5bgneb45fvu53muoueauti-3-0.jpg will accept cables to connect to other audio devices. The audio RCA jacks are color coded RED (right) and WHITE (left) for low level stereo signals. Some have YELLOW jacks for Standard Definition video, ORANGE jacks for AC3 Digital audio and newer amps have HDMI jacks.
Connect the TV's audio OUTPUT jacks and a stereo pair of unused audio INPUT jacks on the amplifier with cables that have ends that match each. Turn on the stereo & TV and select the input on the amplifier that matches the stereo pair of inputs you used to connect to the TV. Adjust the volume to hear the audio over your stereo system's speakers.
Use the HDMI or AC3 sources for superior audio - including 5.1 (or better) Dobly Digital when possible. Otherwise, a standard 2 channel stereo program will be heard.
I hope this helps & good luck!
Dec 08, 2015 | Televison & Video
Jvc KW-AV50 subwoofer amp hook up
very good ! there is nothig wrong with your system, buy a stereo to mono RCA jack (Rs10/-) and connect the subwoofer (if single coiled) L+ & R-- of your existing amplifier. NB: Please go through the manual of amplifier
Apr 08, 2012 | Car Audio & Video
I am getting engine noise? i have a mono block amp for my bass and another amp for my mids. How do I hook up the stinger SGN20 ground loop isolator?
It goes between the source and the amplifier , I don't know if it will work with guitar pickups, but no harm in trying. Also designed for stereo, but you could try dual mono I suppose. Not sure if that will work either but here are the instructions. You will need 2 mono female Jack to male RCA and 2 mono female RCA to male Jack adapters, (unless your guitar output is stereo in which case you will need 1 stereo Jack to 2 RCA etc. Good luck, it might work but I don't think it was designed for the use you have in mind. Will you let us know how you get on?
Mar 07, 2011 | Stinger Sgn20 Ground Loop Isolator
I have a boss bass 1200 low profile amplified sub that isn't working. my power wires connected and receives juice, my ground is grounded, and my remote is hooked up. also my rcas are connected and the...
+ positive from battery ground is of course - anywhere on body put it on last.to avoid sparks if + is powered up! U can put a link between remote and positive it should then be on. Led normally goes blue rca s need a signal from stereo make sure its a amp out or sub out not an input on stereo set all knobs to middle and if speaker is connected to amp speaker + - it should be on, try an mp3 player with jack to rca for testing a known signal.amp may have loop rca make sure its on inputs.some have high inputs too using speakers wire stick with rca
Jan 17, 2018 | Boss Car Audio & Video
I have a Y-cable (dual RCA plugs one end and
you have a stereo rca plug set to a mono audio plug.
you need a stereo rca plug set to a stereo audio plug
Oct 07, 2009 | Pioneer DEH-P690UB CD Player
How Do I Wire An Amp To A Factory Stereo Without Rca Jacks
Hello jon101478,
Purchase a line output converter (LOC) such as the PAC SNI-45T shown here. Tap the LOC inputs into your rear channel speakers and run RCA's from the LOC to your amp. The unit shown in the link also has a trigger wire that you connect to the remote terminal of your amp. You can get a cheaper LOC and just run a switched 12V source to the amp if you wish.
Hope this helps.
Jul 17, 2009 | Car Audio & Video
Im tryin to hook my speakers to my computer
I don't have a picture to show you but will tell you the easiest way.
There is a cable that has headphone jack on one end and two rca jacks on other end. The headphone jack goes to computer and the rca jacks go to your stereos input jacks. Then turn on your stereo and set it to the input setting. That is all there is to it.
Apr 14, 2009 | Harman Kardon HK695 Computer Speakers
My amplifier has one pair of rca inputs. radio only has 1 output
Subwoofer signals should be MONO - not stereo (hence the single Component out on the radio)
Only use one RCA to send signal to your amplifier.
If you use a Y splitter - the signal voltage will be cut in half - deteriorating the quality, and therefore amplifying "dirty" signal.
If you require further help, simply reply to this thread.
Thanks for using FixYa - a FixYa rating is appreciated for answering your Question.
Apr 09, 2009 | Jensen Car Audio & Video
No stereo signal out from yamaha p 2500 s
It's unclear what type of connectors are on the end of the cables(s) coming from your computer.
This amp only works with mono 1/4" TRS and XLR connectors, not standard RCA connectors.
Did you try the Right one in the Left Channel to see if the Left Channel worked?
Refer to the following manual and read up on the connectors (page 7) and the use of the Stereo/Parallel/Bridge Switch (page 8). When it is NOT in Stereo Mode the unit only uses the Right Channel controls and input.
http://img3.musiciansfriend.com/dbase/pdf/man/m_480824.pdf
STEREO/PARALLEL/BRIDGE switch
Use this switch to select the operating mode.
• STEREO mode
Channels A and B operate independently (as with a conventional
stereo amplifier). The Channel A input goes to the Channel
A output jacks, and the Channel B input goes to the
Channel B output jacks.
• PARALLEL mode
The Channel A input signal is output through both the Channel
A and Channel B output jacks. The Channel B input jacks do
not function. Channel A and B volumes can be independently
adjusted.
• BRIDGE mode
The Channel A input signal is output from the BRIDGE output
jacks. To adjust the volume, you must use the Channel A volume
control knob.
Apr 03, 2009 | Yamaha P-2500 Amplifier
Hooking to amps to a power acoustik ptid-7250n
Can you post a bit more about the components, as in the make and model of each?
  1. Head unit in the dash
  2. Sub amp
  3. Stereo amp
Feb 13, 2009 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
29 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
