Question about Panasonic PV-GS31 Mini DV Digital Camcorder
Using the PV-GS31 as a web cam
When I turn the camera to "camera" while connected to the pc, it shows that it's in webcam mode, but I can't seem to pull an image from it. I just moved...can't locate the owner's manual. Any advise on how to actually get it to work?
  • bidzo Dec 10, 2007
    I ned software for pv-gs31
Go to menu. Under playback, go to USB Function, more than likely, it say Web Camera  next to it. Pan right and select DV Studio.
MENU
PLAYBACK->SEARCH
                     12 bit AUDIO
                     audio out
                     USB FUNCTION -> web camera
                                                  DV STUDIO
This should work.
Posted on Oct 25, 2007
SOURCE:
Pc camera dose not work properly even if software is installed.
there is a web cam mode in the camera settings put it on webcam mode check the settings in camera , and then connect it to ur computer actually u are connecting in usb mass storage mode it will only allow u to copy pics to ur PC for webcam if ur camera supports it u should have this mode in ur camera menu check and then connect it thru usb see if it works ok
pls vote fixya if i fixed ur problem
regards
zohail
Feb 02, 2009 | Vivitar ViviCam 5355 Digital Camera
Jazz Camera DV 146
Install DRIVERS from CD before connecting to the PC
Do the wizard stuff.
Connect cam to PC using USB cable
Press on button
Select DSC/DV mode button to read "PC camera" on LCD
Do new hardware wizard stuff
(Be sure to click "Continue Anyway" when windows kicks the install. Wizard will run again)
Finish wizard
Turn on cam
select "PC Camera"
Open "My Computer"
Double click on the Camera Icon to start webcam!
This works for XP SP2. It does seem to crash Firefox when trying to connect to Blogtv which was all I
troed using it on. It may have other issues! I actually use a cheap "Gear Head Quick Webcam Basic" that I got at Big Lots for $13 for video conferencing
Giggle!
Anonymous Troll
Nov 07, 2008 | Jazz DV150 Camcorder
Panasonic PV-GS31
Sound like the wires running to the screen have a short or they become disconnected
Jun 23, 2008 | Panasonic PV-GS31 Mini DV Digital...
No Web Cam
I e-mailed the company and they gave me an answer. It works because the manual that comes with the camera doesn't tell you how to put the camera in Web Mode. This is a strait copy and paste of their answer:
Please note that you will have to set the camera to PC Camera mode before using the webcam function.
1. Press POWER/MENU.
2. Press FLASH/SET or showletter?box=inbox&msgid=3629_1629343_4317_1647_12263_0_114552_28869_2428414296&bodypart=2&yy=51794&y5beta=yes&y5beta=yes&order=down&sort=date&pos=0&view=a&head=b&idx=0
3. Press POWER/MENU to select the icon showletter?box=inbox&msgid=3629_1629343_4317_1647_12263_0_114552_28869_2428414296&bodypart=3&yy=51794&y5beta=yes&y5beta=yes&order=down&sort=date&pos=0&view=a&head=b&idx=0 shown on the LCD.
4. Press showletter?box=inbox&msgid=3629_1629343_4317_1647_12263_0_114552_28869_2428414296&bodypart=4&yy=51794&y5beta=yes&y5beta=yes&order=down&sort=date&pos=0&view=a&head=b&idx=0 or showletter?box=inbox&msgid=3629_1629343_4317_1647_12263_0_114552_28869_2428414296&bodypart=5&yy=51794&y5beta=yes&y5beta=yes&order=down&sort=date&pos=0&view=a&head=b&idx=0 to select the icon showletter?box=inbox&msgid=3629_1629343_4317_1647_12263_0_114552_28869_2428414296&bodypart=6&yy=51794&y5beta=yes&y5beta=yes&order=down&sort=date&pos=0&view=a&head=b&idx=0 shown on the LCD.
5. Press FLASH/SET orshowletter?box=inbox&msgid=3629_1629343_4317_1647_12263_0_114552_28869_2428414296&bodypart=7&yy=51794&y5beta=yes&y5beta=yes&order=down&sort=date&pos=0&view=a&head=b&idx=0. .
Connect the camera to your computer. Open webcam enabled application, such as Instant Messenger or Net meeting. Position the came.
May 23, 2008 | Sakar 81480 Digital Camera
Please help with panasonic PV-GS31 !!
The driver for Win 200 will work fine under XP. Vista of course is another monster all together.
What I would suggest under Vista is the following.
Use the same Win2000 Drivers...
  1. Extract the drivers to a folder.
  2. Plug the camera into the USB port and Vista will detect it. At this point (if you are really lucky) Vista will have drivers in it's catalogue and install them.
  3. If it does not have them it will pop up a box and ask what you want to do.
  4. Choose select the driver from a list.
  5. When the window pops up, choose Have Disk and browse to the folder you extracted the files into.
  6. Pick the right INF file and then select OK.
  7. It will then begin to try and install the drivers.
  8. Follow any other prompts you see, and make sure to read each one clearly.
Hope that helps =)
Apr 11, 2008 | Panasonic PV-GS31 Mini DV Digital...
Please Help with Panasonic PV-GS31
I just added this to your original post as well.
Ok follow along once more =)
  1. Open device manager
  2. Right click the device and select - Update Driver
  3. Select - No Not This Time press Next
  4. Select - Install From a Specific Location Press Next
  5. Select - Dont Search , I will choose the driver to install Press Next
  6. There is now a check box with - Show Compatible Hardware - Remove the tick from that box
  7. Browse to where the INF file is and selct it.
  8. The list should now show all the hardware listed in that INF.
  9. Select the one you want and click NEXT
  10. You may get a warning about it not being the right driver etc etc, just ignore it and keep pressing Next.
Sorry for the late reply, but the email servers here are not telling us when responses have been posted at this time.
Using PV-GS35 as web cam
I use an USB video adapter plus the program:
ulead video studio 8.0 se dvd
and it does work on my skipe.
I hope it helps
Jan 15, 2008 | Panasonic Palmcorder PV-DV53 Mini DV...
PV-GS31 often disconnects from vista
I called Panasonic directly today & asked about the Vista driver for the GS31. No such driver exists, but they are trying to develop a driver specifically for Vista users of this camcorder. Finally the mystery is correctly answered & solved for us Vista owners! woooohooo !
Nov 17, 2007 | Panasonic PV-GS31 Mini DV Digital...
Disable standby mode
i have a panasonic. its not the same kind as yours but i was trying to use it as a webcam as well and had the same issue. i read the manuel and it said that it goes in auto standby if its on pause for more than 5 minutes. so i figured id just take the tape out. its not on pause so it wont stand by. i didnt think it would make a difference. but it did. i can use it as a webcam now. hope this helps
Sep 15, 2007 | Panasonic Palmcorder PV-GS70 Mini DV...
Panasonic PV-GS31 video to PC trouble.
The usb is only used for the still pics and for the webcam. You need a DV cable to upload vid.
Nov 28, 2006 | Panasonic PV-GS31 Mini DV Digital...
Panasonic PV-GS31 Mini DV Digital Camcorder Logo
412 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
