Question about Sport & Outdoor - Others
Fan will not shut off - Sport & Outdoor - Others
Heater fan runs for a few min then shuts down
Check the afc Automatic fan control is shut off too soon .
Apr 29, 2017 | Vulcan Heating & Cooling
Furnace fires up and heats to desired heat setting and burner shuts down , but the main blower continues to run on.
its the fan control AFC not shutting off , it comes on at temp rise say 150f drops back to 130f with fan on , burner shuts off fan runs untill temp falls to 100f the fan shuts off in this case it keeps running
Nov 13, 2010 | Dayton Gas Furnace Heater
When Thermostat is satisfied and shuts down the furnace, the furnace fan will not shut off. It is supposed to continue to run but only for a short time. This one will not shut off at all.
Your thermostat has a feature for the fan AUTO or ON. If it is in the AUTO position and still won't shut down then I would check the Fan relay. Newer models have a control board with the relays built into them so the control board would be suspect. Older models use a Fan/limit. The limit has a probe in it. As the heater warms the bi-metal inside it twists around and the fan comes on at about 110f. When the thermostat is satisfied the burner shuts down but the fan still runs till the heater cools down the bi-metal cools off and shuts down that fan. These will hang up with age.
Nov 11, 2010 | Heating & Cooling
Turned on the furnace last evening to warm things up. When reaching the auto, shut off temperature, the fire/heat shut off OK..but not the fan. Had to shut the power off in order to shut off the fan. ...
Turn the syestem to off-no heat or cool and the fan to auto, turn the power back on, if the fan comes on you probably have a bad fan limit switch.
Sep 08, 2010 | Heating & Cooling
The fan on my 96 acura tl comes after i cut the car off and runs loudly
The fan on a 1996 Acura RL will normally run for a short period after the engine is shut off if the temperature sensor determines the engine is too hot. However, if it is running constantly and not shutting off after you shut off your engine, then you will need to replace the fan relay. It is most likely stuck in a closed position. If your fan does shut off after running for a period of time when you shut off the engine but you have a noisy fan, then most likey the fan bearings are wearing out and it is more cost-effective to replace the whole fan. Thanks for using Fixya.
Aug 23, 2010 | 1996 Acura RL
Computer is a Lenovo TC M52 P4 / 3.2 - I have added a sound card, a PCI express Geforce graphics card and a NIC card. The problem seems to be overheating as it only shuts down like this during the summer...
The case fan should start running as soon as you turn on the computer. I would replace the fan with a higher capacity (CFM). If you have a case that can take 2 case fans, I would install the send fan. Also with the case off, check that the CPU cooler fan is functioning. With the quick shut off, I would suspect that the CPU cooler fan is not functioning. I could be impeded by dust. Vacuum and blow out any dust on the motherboard, fans and battery fan while you have the case off.
This should aleviate the shutoff problem due to overheating.
Let me know if this solves the problem.
Please rate this solutution. Thanks.
Jun 23, 2010 | Lenovo ThinkCentre M52 8212 - Pentium D...
Fan won't shut off
Try hook up the rad fan wires to the wires that power the headlights so that when the vehicle is running the fan would come on, or even try a toggle switch. If this aint working take the car in to the mechanic. hope I could have been some assistance. Charles H
Aug 21, 2009 | 1992 Volkswagen Jetta
BLOWER FAN WONT SHUT OFF WHEN THERMOSTATE IS OFF
The compressor coming on when the contact is pushed is o.k. they all do that. As for the blower fan not shutting off, some brands (Payne for example) the heating fan relay is a n.c. (normally closed ) relay. so if the time delay relay or thermal link are bad or not connected, the fan will blow even when it is turned off.
Aug 19, 2007 | Honeywell CT87B ROUND HEATING&COOLING...
Sport & Outdoor - Others Logo
74 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
