Question about Kenwood KDC-MP635 CD Player
COLOR CODE FROM STERIO TO HARNIS - Kenwood KDC-MP635 CD Player
I need the color code scheme for a JVC WMA MP3 KD-G510 car sterio can you help ?
the colors are the same for all aftermarket stereos. yellow =constant power + for memory, red=ignition + to turn it off and on, black = ground - , blue= power antenna wire, the restare speaersin pairs, grey fr, green rr, white fl, purple rl, and sometimes an orange for headlight dimmer.
Jul 12, 2014 | 1994 Ford Probe
Need to know the color code on sterio to hook up a new one it is a 98 voyager sterio cassett
Try this link, it should help.
http://www.the12volt.com/installbay/stereodetail/676.html
Jul 30, 2010 | 1998 Plymouth Voyager
Need color code diagram for sterio
I'm not sure what year you have but this color code works for 87-93 mustangs.
Radio Connector:
Light Green / Yellow - Hot at all times (Fuse 8)
Yellow / Black - Hot in ACC or Run (Fuse 11)
Light Brown / Red - Goes to instrument panel dimming rheostat (Fuse 4)
Red - Ground
White / Purple - Hot in ACC or Run (Fuse 11)
Speaker Connector:
White / Light Green - (+) Right Instrument Panel & Door Speaker
Dark Green / Orange - (-) Right Instrument Panel & Door Speaker
Brown / Pink - (+) Right Rear Speaker
Pink / Light Brown - (-) Right Rear Speaker
Pink / Light Green - (+) Left Rear Speaker
Tan / Yellow - (-) Left Rear Speaker
Light Brown / White - (+) Left Instrument Panel & Door Speaker
Orange / Light Green - (-) Left Instrument Panel & Door Speaker
Hope this helps.
Jun 19, 2009 | Ford Escort Cars & Trucks
I need the colors for the wireing on an after sterio for mercury
the best thing to do is to buy a wiring harness the it made for your vehicle, it costs about $7 and theres no hassle just hire the same colors together, there are two of the same color for most of the wires just look for the black stripe and make sure there the same
Jun 15, 2009 | Car Audio & Video
Sterio wireing
you will need to get a cord that connects to the sterio and then you need to match them up with these wires
the colors for the radio that are hooked up to the car are
  • orange is power
  • red is egnition
  • blue is power antena
  • black is ground
other ones will most likely be the sterio wires you just need to find colors that look a like and they will most likely match
hope this helps
Apr 07, 2009 | 2000 Ford Focus
After market stereo install
  • orange is power
  • red is egnition
  • black is ground
hope this helps
Dec 12, 2008 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
Need sterio wiring diagram for 1997 1500 gmc p/u ,factory harness
DON'T REMOVE FACTRORY CONNECTORS!!!!!!!!!!!!!! Spend $15 and buy a wiring kit. It plugs right into your vechile wires and the kit tells you what wires are what. Splicing the wires will lead to headaces down the road!!!
Dec 08, 2008 | 1999 GMC Suburban
Kenwood KDC-MP635 CD Player Logo
20 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
