Question about Fellowes Office Equipment & Supplies
Fellows os-8cs shredder just don't come on. The power light is not lit, nothing. Nothing jammed in the head, no broken parts that I can see. Is there a reset button that I can't see? Maybe the circuit board is faulty? Where can I get repairs done in Edmonton Alberta? (my power outlet is fine)
5 Suggested Answers
t_vinson57
  • 58 Answers
SOURCE: My shredder won't work at all!!
If it would be the on/off switch, you can try some WD-40, its clean the contact inside the switch, just spray the switch two or three times & work it, if the problem in the switch, this will help, some have fuse in the back side of them some where.
Good luck
Posted on Mar 31, 2009
  • 541 Answers
SOURCE: SHREDDER WILL NOT POWER UP. NO LIGHTS, NO POWER
you will need to open it and test the on/off switch, door switch, fuse all for continuity. turn the machine off and unplug it . unscrew it from the base. flip it over, unscrew the bottom. now test with a dm. if you are needing a tech i michigan please call 248-677-8112
Posted on Oct 23, 2009
FixinFax
  • 3085 Answers
SOURCE: how to oil a fellowes os 8cs shredder
Oil straight down into the feed slot. 3-in-1 oil or Marvel Oil are OK to use.
Posted on Jan 05, 2010
  • 1218 Answers
SOURCE: My paper shredder, Royal 15 mx does not go in
Dont know if even Royal will have a schematic for the PCB,...most of these are "replace/throw away" pcb's in consumer machines...anyway you can contact Royal at 1-800-524-0799 and see what they say.
Posted on Nov 08, 2010
Parts for fellows sb-97cs
Check eBay for parts or Craigslist for a shredder you can cannibalize. Sometimes Fellowes can give you the part number which can help you search.
Jul 03, 2014 | Fellowes Manufacturing Powershred SB-97CS...
Fellows PS-70 shredder basket ajar light is on
Here is some general advice. Shredders have an interlock to be sure they don't run while the basket is not in place. They don't want you holding the head unit and it starts running and shreds your fingers. So you need to look for the switch that tells the head unit that it is in place over the basket. I'm guessing here but it might be something like a little plastic protrusion that pushes into the head unit to activate a swith. It is possible that the little plastic piece is broken and is not activating the head unit. That would explain why the display thinks that the basket is ajar or misaligned. BE CAREFUL if you tinker with the interlock and be sure it is unplugged!! That is an ORDER!
Apr 22, 2014 | Fellowes Powershred PS-70
Staples Shredder SPL-TXC22A always has the jam light lit and will not work even though there is nothing jammed. It works if I press and hold the down button twice. It also works continuously if I turn off...
Home office shredders get jammed because the mechanism is not self cleaning. If you remove power and expose the mechanism you may find that, indeed, a shard of paper is triggering the jam sensor. These shredders require periodic removal of the bits of paper from the mechanism, an exercise that can consume hours of picking with tweezers while thinking there must be a better way.
Dec 10, 2013 | Office Equipment & Supplies
My fellows jbo1 jamed and then stopped running is there a reset buton?
Chances are it's over heated.
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled. See oiling instructions below.
From fellow's website: http://www.fellowes.com/fellowes/site/support/support_troubleshooting.aspx#jammed
Dec 15, 2010 | Fellowes Office Equipment & Supplies
THE SHREDDER ISNT SHREDDING ANYTHING ANYMORE, the power still runs and it will still take the paper but its not shredding anymore???
You wil need to Have the shredding head rebuilt or replaced. and or a new machine. A new head is very expensive. Here is the number for fellows 800-955-0959. Check on parts if they are still available. Hope this helps your friendly service tech (colorado).
May 06, 2010 | Fellowes Powershred 220 Shredder
How to oil a fellowes os 8cs shredder
Jan 05, 2010 | Fellowes Office Equipment & Supplies
I have a fellows 420 cc power shredder that will not start when paper is inserted
if ther are no red warning lights lit, then you will have to replace the auto feed senors or the main power switch.
May 13, 2009 | Office Equipment & Supplies
Fellows S701CM shredder won't respond
unplug in and check the fuse in the back side of the shredder
good luck
Jan 24, 2009 | Fellowes 3011001 Shredder
Fellows ps60c-2
took schreder apart: The plastic driven gear it striped is that gear serviced
Apr 01, 2008 | Fellowes PS60C-2 Shredder
62 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
